mec 16xx dump with info block
  • pokyss1
    • Mar 2019
    • 58
    • TUNISE
    #441
    Originally posted by volinakis
    Vous devez fournir votre fichier MEC et votre numéro de série. Il existe quatre versions pour ce modèle.
    Numéro de série Carte système : L1HF9C300MT
    Numéro de série de l'unité système : pf216zhf
    • pokyss1
      • Mar 2019
      • 58
      • TUNISE
      #442
      SYSTEM BORD SERIAL NUMBER:L1HFC9300MT
      SYSTEM-UNIT SERIAL BORD NUMBER:PF216ZHF
      • pokyss1
        • Mar 2019
        • 58
        • TUNISE
        #443
        good ficher
        • hoaca388
          Badcaps
          • Jan 2022
          • 12237
          #444
          What is your problem ? Both files are full 00, reading failed.
          • pokyss1
            • Mar 2019
            • 58
            • TUNISE
            #445
            i cant read this file i always ihave errors to read vertyanovo and ht809 houw can do .
            thax
            • pokyss1
              • Mar 2019
              • 58
              • TUNISE
              #446
              good file naw for unlock
              • hoaca388
                Badcaps
                • Jan 2022
                • 12237
                #447
                Try
                • pokyss1
                  • Mar 2019
                  • 58
                  • TUNISE
                  #448
                  Try
                  i try this bat the laptop not turne on
                  • hoaca388
                    Badcaps
                    • Jan 2022
                    • 12237
                    #449
                    Does the laptop work with the original file ?
                    • pokyss1
                      • Mar 2019
                      • 58
                      • TUNISE
                      #450
                      SORRY I HAVE errer
                      sorry i have errer withe file this fil withe machin working good
                      • hoaca388
                        Badcaps
                        • Jan 2022
                        • 12237
                        #451
                        SORRY I HAVE errer
                        This is what you read, from top to bottom.
Name:	2025-04-15 16_27_48-HxD - [F__MEC1633_256K_20250415_15118.BIN].png
                        • nesredin
                          • Feb 2018
                          • 39
                          • ethiopia
                          #452
                          Originally posted by vuquanghoanh
                          I followed Maxpower3's instructions and it worked. Follow him, you will also succeed.
                          Let's thank Maxpower3.
                          hello how to read and write with rt809f mec1663 with this x1 carbon
                          NM-B861 REV 1.0​
                          • pokyss1
                            • Mar 2019
                            • 58
                            • TUNISE
                            #453
                            NM-B861 REV 1.0​
                            yes
                            • khaledmosa99
                              • Dec 2014
                              • 75
                              • egypt
                              #454
                              hello i got thinkpad t14 gen1 20s0 with burn mec1663 i replaced it with a new one i got the jtag connection with my vertyanove programmer try to cut ec when i write it i got blinking white led 3 times only can some one help me to fined the file flash+epperom
                              nm-c931 rev 1.0 my s/n PF2A58EN
                              thank all for help
                              • saman mawlod
                                • Apr 2022
                                • 56
                                • iraq
                                #455
                                [QUOTE=hoaca388;n3615433]
                                lenovo p52
                                type 20ma-s6hh00
                                sn pf-1ns7hl
                                mec1653
                                can unlock
                                • jaglion19
                                  • Oct 2017
                                  • 102
                                  • TURKEY
                                  #456
                                  I have a Dell e7440 la-9591p motherboard, no matter what I did on the device, I couldn't start it. It uses MEC5075. On the first page, someone shared the jtag paths for tx390, I searched from the schematic and found the same legs. Can I make this read by soldering it in the same way as SWOD? or with rt809f? or what are its legs? Also, I think the place where it says rp1 is for jtag, but there is a resistor with 103 written on it. Can I remove it, solder the 5 paths and 3 gnds and read it?
                                  • djacksod
                                    • Jan 2017
                                    • UKRAINE
                                    #457
                                    I am posting the mec1663 Lenovo T14 nm-c931 1st gen intel 10th that I read, the eeprom address where the password is located is at offset 0x300.
                                    • Maxpower3
                                      Bad Veteran
                                      • Feb 2018
                                      • 1315
                                      • France
                                      #458
                                      lines 350 and 360 should not be deleted
                                      It's easier to find your way around with the decrypted file
                                      • antongoikoetxea
                                        • Aug 2019
                                        • Valencia
                                        #459
                                        Thanks to everyone for the help.
                                        My case was a ThinkPad X1 Carbon Gen 7 with motherboard NM-C661. I used an SVOD3 and the pinout from the picture I’m attaching. The reset is not needed when using the pull-down resistor.
                                        In the SVOD software I selected EEPROM, and once the dump was read I changed the data from 0x300–0x34F to FF. After reprogramming, the password issue was solved.
                                        Many thanks again to all, and I hope this can help anyone else who has the same model.
                                        • osman68i
                                          • May 2015
                                          • 348
                                          • The Netherlands
                                          #460
                                          Hi Badcaps Team,
                                          T15 Gen1 with bios lock.
                                          SN: PF2RVTMS
                                          I have checked the dump but I cant find the location of the pass
                                          • Habble7
                                            by Habble7
                                            Suspected Cause:
                                            Troubleshooting Attempts:
                                            05-22-2025, 07:28 AM
                                          • Mephysis
                                            DUMP DVR HIKVISION DS-7208HGHI-K1 (80389 Rev 1.3 Firmware)
                                            by Mephysis
                                            Hello guys i really need help, i recently updated my DS-7208HGHI-K1 and it somehow got bricked, I've got it up and working now by flashing a new dump file i found but the serial number is really wrong and the uploader of the dump file probably intentionally did it.
                                            I still have the bricked dump file is it possible to transfer the serial number of the "bricked dump" to the "working dump"?
                                            03-27-2025, 02:34 AM
                                          • Citymin
                                            by Citymin
                                            S/N : 5RNK9FFT70...
                                            08-05-2025, 05:12 AM
                                          • hyperwood
                                            [REQUEST] 2MB BIOS Dump for Lenovo NM-E471 Rev 2.0 (Winbond 25Q16JWSIQ Chip)
                                            by hyperwood
                                            I’m looking for a 2 MB BIOS dump for a Lenovo IdeaPad 5 16ARH7H / Legion 5 with mainboard NM-E471 Rev. 2.0.
                                            The BIOS chip is a Winbond W25Q16FW (1.8V, 2MB) and it's completely unresponsive / bricked. I tried recovery via USB but no success. Now I want to reflash it externally using a CH341A programmer.
                                            I already found 32MB dumps (e.g. from Vinafix and Badcaps), but they are too large for the chip – and the last 2MB in those files are just FF FF FF....
                                            ✅ What I need:
                                            • A working 2MB BIOS dump
                                            • Matching NM-E471 Rev. 2.0, e.g. JY575
                                            06-25-2025, 02:28 PM
                                          • Andreas_de
                                            Power supply Manson NTP-5561 (5661) LCD controller dead - PIC18F87K90 HEX dump required
                                            by Andreas_de
                                            Hello!
                                            i got a damaged Manson NTP-5561 (60V, 1,6A DC output) and and the main issue is that the controler IC for the LCD display has a short. The controler IC PIC18F87K90 is mounted on the back of the back of the LCD. Vss-Vdd = 3 Ohm. The 5V and 3,3V power line was killed as well, but that is not a problem. A new LDO 3,3V and 5V 7805 is already ordered.
                                            Replacing the PIC18F87K90 is necessary but that makes no sense without having the HEX dump of the new controler.
                                            Does anybody have such a power supply and could do a HEX dump of the Flash and EEPROM memory?
                                            04-12-2025, 10:38 AM
