mec 16xx dump with info block
  • dimah77
    • Sep 2016
    • 147
    • ALGERIA
    #301
    Re: mec 16xx dump with info block
    Originally posted by coolshrimp
    Ok now that that is solved ill share my diagram and instructions.
    T14s - MEC-1663 - Jtag - Pinout - Bios Password Removal
    Now next issue setting Serial / Model / Etc.
    Lenovo T14s (NM-B891)
    Iv Tried to Use Lenovo Maintenance Utility 1.89 (i7tm38us)
    But I get and error *EEPROM Overflow
    Same issue here: https://www.badcaps.net/forum/showth...EPROM+overflow
    You are using MEC-1633#ISP in RT809H Settings, the resulting file is 192k, is this the correct size? shouldn't it be 256 or 290?
    • coolshrimp
      • Nov 2016
      • 54
      Using MEC-1633#ISP Worked for me and others recommended but there is a MEC-16xx 256k option that could be selected instead.
      • dimah77
        • Sep 2016
        • 147
        • ALGERIA
        #303
        I work on a T14 G1, I tested your settings, and also with 256K, I got a 256K file with more data then the 192k at the end of the file
        • coolshrimp
          • Nov 2016
          • 54
          I looked at my file and you’re right there is more info at the end that was cut off.
          On mine the cut off was just blank padding no content so likely why it had no effect.
          So the 256k would be a better option.
          Depending what MEC chip your Reading the size may be different.
          • dimah77
            • Sep 2016
            • 147
            • ALGERIA
            #305
            I looked at my file and you're right there is more info at the end that was cut off.
            it's a MEC-1663 , after read-erase-wait 2 mn without power-write-put back resistor , still password there. (192k file), not tested to write 256k yet
            • ymifdal
              • Jan 2022
              • 116
              • Morocco
              #306
              to my knowledge, choosing either 192k or 256k is fine, same result
              and so if you did the "read erase remove all power sources including cmos batt" and the password is still there, then it is probably not a bios password you are dealing with, just remove the SSD it should work fine it's a hard disk password
              • dimah77
                • Sep 2016
                • 147
                • ALGERIA
                #307
                Using RT809F, choosing MEC1633-256K , unlock done.
                Don't choose MEC1633#ISP , it provide 192K file and password is not removed after write back.
                • dinarte
                  • Sep 2021
                  • 13
                  • Brazil
                  #308
                  has someone figuered out how to unlock the AMD version as well?
                  • couillu76
                    • Jan 2022
                    • 39
                    #309
                    that it! after weeks of trying to unlock my x13 gen 1 laptop with my svod4 i finally manage to unlock it with an rt809h it was easy thank for all your infos on this website it help, but i did it with the rt809h not with the svod4
                    • ajbernasko
                      • Mar 2022
                      • 229
                      • ghana
                      #310
                      Hello, This board is for the Lenovo X1 Yoga gen 5, I need to read the MEC1663 chip but I am asking if the indicated red button is the JTAG pins outs ?
                      Also I knocked out one resistor and i believe it is 10K 0201 resistor.
                      thank you in advance.
                      • anhbanxoi
                        • Sep 2021
                        • 173
                        • VN
                        #311
                        Yes, somebody connected like the attachment photo.
                        • ajbernasko
                          • Mar 2022
                          • 229
                          • ghana
                          #312
                          Thank you for your reply, I have the same cable with RT809H, I will try it out and let the forum know.
                          • AHMED14NET
                            • Nov 2019
                            • FRANCE
                            #313
                            How did you make jtag for t490 mec 1663
                            • dimah77
                              • Sep 2016
                              • 147
                              • ALGERIA
                              #314
                              Originally posted by ahmed14net
                              how did you make jtag for t490 mec 1663
                              like this ... without RST
                              • ajbernasko
                                • Mar 2022
                                • 229
                                • ghana
                                #315
                                Please can you help me label which one it is TMS, RST, TDI, TDO and GND. Thank you
                                • dimah77
                                  • Sep 2016
                                  • 147
                                  • ALGERIA
                                  #316
                                  like this :
                                  • ajbernasko
                                    • Mar 2022
                                    • 229
                                    • ghana
                                    #317
                                    like this :
                                    Yes I saw the flying configuarions from previows post and or on the RT809H but this is different. On your image looks like the jtag pin number 5 is GND but on the x1 Yoga Gen 5 pin number 6 is GND
                                    • javieromex
                                      • Apr 2016
                                      • 78
                                      • México
                                      #318
                                      Hello!
                                      Anyone can help me?
                                      Lenovo: ThinkPad T14 Gen 1
                                      MB: NM-C931 with MEC1663
                                      Issue: Need to remove BIOS PASSWORD
                                      SVOD4
                                      I moved R8715 to R8716 position and solder the wires to the JTAG Port, I am getting this from the SVOD: (see image)
                                      And when clicking read, it reads the MEC but I cannot see any data on the HEX section. (The machine does power up)
                                      I am afraid to clic on erase and brick the computer!
                                      Any help?
                                      Thanks!
                                      • mazoot
                                        iFixit
                                        • Jan 2019
                                        • 41
                                        • Moldova
                                        #319
                                        MEC1663 has 290 kb not 192kb probably your svod4 cannot flash normal this chip,or settings not normal read manual
                                        Kill the state in yourself and you will be free like a wind...
                                        • javieromex
                                          • Apr 2016
                                          • 78
                                          • México
                                          #320
                                          Thanks four your answer
                                          I am able to "Confic MEC" with 288K but same result, when reading nothing appears on the HEX.
                                          How can I read manual?
                                          • Habble7
                                            by Habble7
                                            Suspected Cause:
                                            Troubleshooting Attempts:
                                            05-22-2025, 07:28 AM
                                          • Mephysis
                                            DUMP DVR HIKVISION DS-7208HGHI-K1 (80389 Rev 1.3 Firmware)
                                            by Mephysis
                                            Hello guys i really need help, i recently updated my DS-7208HGHI-K1 and it somehow got bricked, I've got it up and working now by flashing a new dump file i found but the serial number is really wrong and the uploader of the dump file probably intentionally did it.
                                            I still have the bricked dump file is it possible to transfer the serial number of the "bricked dump" to the "working dump"?
                                            03-27-2025, 02:34 AM
                                          • Citymin
                                            by Citymin
                                            S/N : 5RNK9FFT70...
                                            08-05-2025, 05:12 AM
                                          • hyperwood
                                            [REQUEST] 2MB BIOS Dump for Lenovo NM-E471 Rev 2.0 (Winbond 25Q16JWSIQ Chip)
                                            by hyperwood
                                            I’m looking for a 2 MB BIOS dump for a Lenovo IdeaPad 5 16ARH7H / Legion 5 with mainboard NM-E471 Rev. 2.0.
                                            The BIOS chip is a Winbond W25Q16FW (1.8V, 2MB) and it's completely unresponsive / bricked. I tried recovery via USB but no success. Now I want to reflash it externally using a CH341A programmer.
                                            I already found 32MB dumps (e.g. from Vinafix and Badcaps), but they are too large for the chip – and the last 2MB in those files are just FF FF FF....
                                            ✅ What I need:
                                            • A working 2MB BIOS dump
                                            • Matching NM-E471 Rev. 2.0, e.g. JY575
                                            06-25-2025, 02:28 PM
                                          • Andreas_de
                                            Power supply Manson NTP-5561 (5661) LCD controller dead - PIC18F87K90 HEX dump required
                                            by Andreas_de
                                            Hello!
                                            i got a damaged Manson NTP-5561 (60V, 1,6A DC output) and and the main issue is that the controler IC for the LCD display has a short. The controler IC PIC18F87K90 is mounted on the back of the back of the LCD. Vss-Vdd = 3 Ohm. The 5V and 3,3V power line was killed as well, but that is not a problem. A new LDO 3,3V and 5V 7805 is already ordered.
                                            Replacing the PIC18F87K90 is necessary but that makes no sense without having the HEX dump of the new controler.
                                            Does anybody have such a power supply and could do a HEX dump of the Flash and EEPROM memory?
                                            04-12-2025, 10:38 AM
