mec 16xx dump with info block
  • Aditya11ttt
    Adi
    • Feb 2019
    • 186
    • India
    #221
    Re: mec 16xx dump with info block
    Originally posted by couillu76
    and this what i have with the svod4
    its blocked and can't be accessed try mass erase if it gets unlocked than possible.
    • couillu76
      • Jan 2022
      • 39
      #222
      mass erase? on my svod ?i have got erase option is it the one?, could it be the 10k resitor not soldered properly
      and if i erase i dont have a back up of the chip unless you have got one ?
      • Aditya11ttt
        Adi
        • Feb 2019
        • 186
        • India
        #223
        It's protocol is locked you can't do anything!!
        Another way is change the Ic and do !
        • volinakis
          • Jan 2021
          • 2872
          • N/A
          #224
          So I see many have problems updating Model No. for Lenovo.
          A simple way is to extract bios files from bios_update.exe and using CMD type winuptp.exe -m xxxxxx (Model No.) I used this fot an M70q and worked.
          • volinakis
            • Jan 2021
            • 2872
            • N/A
            #225
            Originally posted by EvilBzyk
            Pinout to:
            X1 YOGA GEN5
            CARBON X1 GEN8
            mobo: GX4A0 GYG50 NM-C881 REV:1.0
            Hi, tell me where you solder RST wire - pin 7 to RT809H? Thank you.
            • RethoricalCheese
              • Mar 2013
              • 1519
              • Estonia
              #226
              You dont. You just need to find reset resistor and solder it from pull-down to pull-up.
              • volinakis
                • Jan 2021
                • 2872
                • N/A
                #227
                Many thanks. Do you have a valid EC dump for yoga x1 4th gen. mb FX490 NM-B861? I downloaded bios update and extracted files and EC is 257kb and I think it should be 290kb.
                • AAAC
                  • Jan 2020
                  • 458
                  • Mexico
                  #228
                  @volinakis
                  This is what have worked for me: take the EC file and remove 30h (48) bytes from the header, then add as many FFh bytes as needed at the end of file until file size is 290kB (296,960 bytes), save changes and file is ready to use.
                  You can try if you have a backup of a ThinkPad EC file, you will end up with exact copies, one read from EC/KBC chip and the other extracted from the BIOS update for same EC firmware version.
                  • volinakis
                    • Jan 2021
                    • 2872
                    • N/A
                    #229
                    Originally posted by AAAC
                    @volinakis
                    Thanks for advice I will try. I don't have a dump, MEC1663 was protected to read - "Chip may be damaged or encrypted"message - but I was able to erase and after erase I was able to read, write - I wrote the 257kb EC extracted from bios update just to verify if allows me - and after I wrote the 257kb file when I read again it saved as 290kb file.
                    Anyway, I'm new in using RT809H and many thanks to all users from this forum who are willing to share from their experience, hat off!
                    • volinakis
                      • Jan 2021
                      • 2872
                      • N/A
                      #230
                      @volinakis
                      So, I had to cut only 32bytes from EC file, not 48. Figured out when I saved bin from EC and compared with what I wrote and gave me 16bytes more in length. Now I have to figure out how to use Lenovo Maintenance Utility, MTM is xxxx-xxx and mine is xxxx-xxxxxx and I don't know what to do with 16 characters serial number, any advice is wellcome, thank you.
                      • RethoricalCheese
                        • Mar 2013
                        • 1519
                        • Estonia
                        #231
                        Scan the barcode. You need codes starting with 1S (bottom case sticker) and 8S (motherboard sticker)
                        • AAAC
                          • Jan 2020
                          • 458
                          • Mexico
                          #232
                          @volinakis
                          It’s good that you figure it out, I couldn’t find my notes at the moment and just kind of guess it how many bytes needed to cut.
                          About Lenovo Maintenance Utility, make sure you are using latest version that is available.
                          • myjunaid
                            • Nov 2019
                            • 32
                            • Spain
                            #233
                            Can Someone please explain me how to read the mec properly
                            as i used the isp pins from the top area but it gives error MEC Chip ID: 0xFFFFFFFF. 090: ID verification error.
                            but if i use the isp colorful cable then can someone explain me which pins are TMS, TDI, RST on Rt809h plz see the picture
                            also i moved the resistor now to left side is this okay ?
                            also pin no 6 there is no resister can i remove from the same board from other location and use here if i really need to ?
                            will appreciate your time as i have spent hours and got nothing i am first time using rt809h
                            • volinakis
                              • Jan 2021
                              • 2872
                              • N/A
                              #234
                              I want to share my 1st experience with MEC1663 from Yoga X1 4th gen.
                              Many thanks to AAAC, RethoricalCheese, EvilBzyk, their shared knowledge helped me a lot.
                              1. Connected jtag pins as in picture, no pull up resistor needed. Moved 10k resistor from pull-down to pull-up. Chose MEC1633#ISP. power on motherboard.
                              2. Got message "Chip may be damaged or encrypted, the data is not valid" I did try other options, MEC1653#ISP, MEC1633_256k, same result.
                              3. I hit "Erase" and laptop stops working, no power on/charge led lit.
                              4. I took EC file from bios update and trim 32bytes, the same version it was in bios (I took a photo of info in bios before pulling off the motherboard) wrote the file into EC then power off motherboard. Waited few minutes an power on motherboard, power on/charge led lit. Moved the 10k resistor to pull down.
                              5. schematics IS WRONG! TP1 IS REVERSED WITH TP5.
                              • volinakis
                                • Jan 2021
                                • 2872
                                • N/A
                                #235
                                don't use flashing port, use info from posts #46 and #31. don't wire #RST, just move 10k as in photo. You have to power on the motherboard to have 3.3V to feed EC.
                                • myjunaid
                                  • Nov 2019
                                  • 32
                                  • Spain
                                  #236
                                  you mean 10k resister on pin 7 line as in pictures
                                  also where can i get the 10k from the mainboard to do the job once done i can move back is that ok
                                  you can tell me the resistor number i have boardview i will find it
                                  • volinakis
                                    • Jan 2021
                                    • 2872
                                    • N/A
                                    #237
                                    No, RST resistor for MEC16xx as shown in picture of post #31. Don't wire "pin 7 line" #RST of programmer. Read previous posts of the topic you'll find all informations there. i don't know your laptop model you didn't specify, pic from post #31 is self explanatory.
                                    • myjunaid
                                      • Nov 2019
                                      • 32
                                      • Spain
                                      #238
                                      No, RST resistor for MEC16xx as shown in picture of post #31. Read previous posts of the topic you'll find all informations there. i don't know your laptop model you didn't specify.
                                      Sorry its T490s
                                      i have done exactly how you asked me to but i am getting ID Verification error MEC Chip ID: 0xFFFFFFFF
                                      also disconnected rst still nothing
                                      my cables are also less than 10cm
                                      • volinakis
                                        • Jan 2021
                                        • 2872
                                        • N/A
                                        #239
                                        @myjunaid
                                        I hope you'll understand now.
                                        • myjunaid
                                          • Nov 2019
                                          • 32
                                          • Spain
                                          #240
                                          @myjunaid
                                          Thank you very much for your time and for the pictures
                                          i have done the exactly the same before with connected RST to no 7 and without connected to pin7 to RST it gives error ID verification error
                                          it has usb C charger which i connected but i noticed i am not getting 3.3v on pin 7 but when i connect the wires and plug the usb c the laptop fan starts spinning and off for some time then on again but i have not connected the power button or i need to connect the power button and switch on by pressing it
                                          also posts #46 saying the some mainboard RST pin 7 is empty solder pad then add 10 k resister there and my mainboard pin 7 is not connected to resister as well
                                          also can it be a issue of RT809H Drivers ?
                                          • Habble7
                                            by Habble7
                                            Suspected Cause:
                                            Troubleshooting Attempts:
                                            05-22-2025, 07:28 AM
                                          • Mephysis
                                            DUMP DVR HIKVISION DS-7208HGHI-K1 (80389 Rev 1.3 Firmware)
                                            by Mephysis
                                            Hello guys i really need help, i recently updated my DS-7208HGHI-K1 and it somehow got bricked, I've got it up and working now by flashing a new dump file i found but the serial number is really wrong and the uploader of the dump file probably intentionally did it.
                                            I still have the bricked dump file is it possible to transfer the serial number of the "bricked dump" to the "working dump"?
                                            03-27-2025, 02:34 AM
                                          • Citymin
                                            by Citymin
                                            S/N : 5RNK9FFT70...
                                            08-05-2025, 05:12 AM
                                          • hyperwood
                                            [REQUEST] 2MB BIOS Dump for Lenovo NM-E471 Rev 2.0 (Winbond 25Q16JWSIQ Chip)
                                            by hyperwood
                                            I’m looking for a 2 MB BIOS dump for a Lenovo IdeaPad 5 16ARH7H / Legion 5 with mainboard NM-E471 Rev. 2.0.
                                            The BIOS chip is a Winbond W25Q16FW (1.8V, 2MB) and it's completely unresponsive / bricked. I tried recovery via USB but no success. Now I want to reflash it externally using a CH341A programmer.
                                            I already found 32MB dumps (e.g. from Vinafix and Badcaps), but they are too large for the chip – and the last 2MB in those files are just FF FF FF....
                                            āœ… What I need:
                                            • A working 2MB BIOS dump
                                            • Matching NM-E471 Rev. 2.0, e.g. JY575
                                            06-25-2025, 02:28 PM
                                          • Andreas_de
                                            Power supply Manson NTP-5561 (5661) LCD controller dead - PIC18F87K90 HEX dump required
                                            by Andreas_de
                                            Hello!
                                            i got a damaged Manson NTP-5561 (60V, 1,6A DC output) and and the main issue is that the controler IC for the LCD display has a short. The controler IC PIC18F87K90 is mounted on the back of the back of the LCD. Vss-Vdd = 3 Ohm. The 5V and 3,3V power line was killed as well, but that is not a problem. A new LDO 3,3V and 5V 7805 is already ordered.
                                            Replacing the PIC18F87K90 is necessary but that makes no sense without having the HEX dump of the new controler.
                                            Does anybody have such a power supply and could do a HEX dump of the Flash and EEPROM memory?
                                            04-12-2025, 10:38 AM
