mec 16xx dump with info block
 Re: mec 16xx dump with info block
 It's protocol is locked you can't do anything!!
 Another way is change the Ic and do !Comment
 So I see many have problems updating Model No. for Lenovo.
 A simple way is to extract bios files from bios_update.exe and using CMD type winuptp.exe -m xxxxxx (Model No.) I used this fot an M70q and worked.----------------------------------------------------------------------------------------------------------------------------------------------------------------------
 ----------------------------------------------------------------------------------------------------------------------------------------------------------------------Comment
 You dont. You just need to find reset resistor and solder it from pull-down to pull-up.Comment
 Many thanks. Do you have a valid EC dump for yoga x1 4th gen. mb FX490 NM-B861? I downloaded bios update and extracted files and EC is 257kb and I think it should be 290kb.----------------------------------------------------------------------------------------------------------------------------------------------------------------------
 @volinakis
 This is what have worked for me: take the EC file and remove 30h (48) bytes from the header, then add as many FFh bytes as needed at the end of file until file size is 290kB (296,960 bytes), save changes and file is ready to use.
 You can try if you have a backup of a ThinkPad EC file, you will end up with exact copies, one read from EC/KBC chip and the other extracted from the BIOS update for same EC firmware version.Comment
 Thanks for advice I will try. I don't have a dump, MEC1663 was protected to read - "Chip may be damaged or encrypted"message - but I was able to erase and after erase I was able to read, write - I wrote the 257kb EC extracted from bios update just to verify if allows me - and after I wrote the 257kb file when I read again it saved as 290kb file.@volinakis
 Anyway, I'm new in using RT809H and many thanks to all users from this forum who are willing to share from their experience, hat off!----------------------------------------------------------------------------------------------------------------------------------------------------------------------
 So, I had to cut only 32bytes from EC file, not 48. Figured out when I saved bin from EC and compared with what I wrote and gave me 16bytes more in length. Now I have to figure out how to use Lenovo Maintenance Utility, MTM is xxxx-xxx and mine is xxxx-xxxxxx and I don't know what to do with 16 characters serial number, any advice is wellcome, thank you.@volinakis
 You can try if you have a backup of a ThinkPad EC file, you will end up with exact copies, one read from EC/KBC chip and the other extracted from the BIOS update for same EC firmware version.----------------------------------------------------------------------------------------------------------------------------------------------------------------------
 Scan the barcode. You need codes starting with 1S (bottom case sticker) and 8S (motherboard sticker)Comment
 @volinakis
 It’s good that you figure it out, I couldn’t find my notes at the moment and just kind of guess it how many bytes needed to cut.
 About Lenovo Maintenance Utility, make sure you are using latest version that is available.Comment
 Can Someone please explain me how to read the mec properly
 as i used the isp pins from the top area but it gives error MEC Chip ID: 0xFFFFFFFF. 090: ID verification error.
 but if i use the isp colorful cable then can someone explain me which pins are TMS, TDI, RST on Rt809h plz see the picture
 also i moved the resistor now to left side is this okay ?
 also pin no 6 there is no resister can i remove from the same board from other location and use here if i really need to ?
 will appreciate your time as i have spent hours and got nothing i am first time using rt809hComment
 I want to share my 1st experience with MEC1663 from Yoga X1 4th gen.
 Many thanks to AAAC, RethoricalCheese, EvilBzyk, their shared knowledge helped me a lot.
 1. Connected jtag pins as in picture, no pull up resistor needed. Moved 10k resistor from pull-down to pull-up. Chose MEC1633#ISP. power on motherboard.
 2. Got message "Chip may be damaged or encrypted, the data is not valid" I did try other options, MEC1653#ISP, MEC1633_256k, same result.
 3. I hit "Erase" and laptop stops working, no power on/charge led lit.
 4. I took EC file from bios update and trim 32bytes, the same version it was in bios (I took a photo of info in bios before pulling off the motherboard) wrote the file into EC then power off motherboard. Waited few minutes an power on motherboard, power on/charge led lit. Moved the 10k resistor to pull down.
 5. schematics IS WRONG! TP1 IS REVERSED WITH TP5.----------------------------------------------------------------------------------------------------------------------------------------------------------------------
 don't use flashing port, use info from posts #46 and #31. don't wire #RST, just move 10k as in photo. You have to power on the motherboard to have 3.3V to feed EC.Can Someone please explain me how to read the mec properly
 will appreciate your time as i have spent hours and got nothing i am first time using rt809h----------------------------------------------------------------------------------------------------------------------------------------------------------------------
 you mean 10k resister on pin 7 line as in pictures
 also where can i get the 10k from the mainboard to do the job once done i can move back is that ok
 you can tell me the resistor number i have boardview i will find itComment
 No, RST resistor for MEC16xx as shown in picture of post #31. Don't wire "pin 7 line" #RST of programmer. Read previous posts of the topic you'll find all informations there. i don't know your laptop model you didn't specify, pic from post #31 is self explanatory.Last edited by volinakis; 07-30-2022, 04:06 AM.----------------------------------------------------------------------------------------------------------------------------------------------------------------------
 Sorry its T490s
 i have done exactly how you asked me to but i am getting ID Verification error MEC Chip ID: 0xFFFFFFFF
 also disconnected rst still nothing
 my cables are also less than 10cmComment
 Thank you very much for your time and for the pictures
 i have done the exactly the same before with connected RST to no 7 and without connected to pin7 to RST it gives error ID verification error
 it has usb C charger which i connected but i noticed i am not getting 3.3v on pin 7 but when i connect the wires and plug the usb c the laptop fan starts spinning and off for some time then on again but i have not connected the power button or i need to connect the power button and switch on by pressing it
 also posts #46 saying the some mainboard RST pin 7 is empty solder pad then add 10 k resister there and my mainboard pin 7 is not connected to resister as well
 also can it be a issue of RT809H Drivers ?Comment
			by mkdjDear all,
 I would appreciate if someone could take time to explain the issue, so that I can learn. But I would...-
							Channel: BIOS Requests ONLY!
			by Habble7The Samsung S49CG934SU monitor does not power on - no LED indicator activity and no response to power button. However, when 21V power is connected, it immediately draws 0.8A of current with no display output. The motherboard processor gets warm, and there is continuous reading activity from the W25Q128BV BIOS chip.
 Suspected Cause:
 Troubleshooting Attempts:
			by MephysisHello guys i really need help, i recently updated my DS-7208HGHI-K1 and it somehow got bricked, I've got it up and working now by flashing a new dump file i found but the serial number is really wrong and the uploader of the dump file probably intentionally did it.
 I still have the bricked dump file is it possible to transfer the serial number of the "bricked dump" to the "working dump"?
			by CityminHi all,
 S/N : 5RNK9FFT70...-
			by hyperwoodHi everyone,
 Iām looking for a 2 MB BIOS dump for a Lenovo IdeaPad 5 16ARH7H / Legion 5 with mainboard NM-E471 Rev. 2.0.
 The BIOS chip is a Winbond W25Q16FW (1.8V, 2MB) and it's completely unresponsive / bricked. I tried recovery via USB but no success. Now I want to reflash it externally using a CH341A programmer.
 I already found 32MB dumps (e.g. from Vinafix and Badcaps), but they are too large for the chip ā and the last 2MB in those files are just FF FF FF....
 ā What I need:- A working 2MB BIOS dump
- Matching NM-E471 Rev. 2.0, e.g. JY575
- Loading...
