Hp elitebook 840 g5 bios password
Hi all i need clean file for tHis bios dump Hp elitebook 840 g5. i5 8 generation sn 5CG92229D3
yours
emergencyComment
HP EliteBook 840 G5 Base Model Notebook PC↵
https://www.badcaps.net/donateComment
Hello everyone, need help in Bios unlocking this Lenovo 840 G5. I tried with the HP unlock tool on the larger Bios chip but it didn't work. So I am uploading both bios chips could anyone remove the bios lock? Many thanks!Comment
try.. The 16 MB one remains the same.Attached FilesDue to a lack of donations, server free space at a critical level, and possible closure of Bios Requests all donations are welcome, click:
Every donation made will go towards server fees and maintenance costs.Comment
Not sure if this is important, but when I boot and press F10, before getting the Bios Administrator Password screen, I get this screen which say PROPERTY OF GHD then the HP logo and then the message Protected by HP Sure Start.
I tried looking for the string "PROPERTY OF GHD" in both the 16MB and 32MB files but did not find anything. Not sure what to try next?Comment
Ok, so figured it out and will post the solution in case someone has the same issue. Unlocking the 32MB file did not to the trick. Used RcUnlocker on the 16MB chip and that did the trick it is now unlocked. Many thanks to all of you and thanks Peste!
I have a HP 840 G5 that is admin password locked (abandoned from a company). I have been trying a good way to unlock it and reading up on almost the entire thread here it seems reading out the 32MB chip patching it with RCUnlocker is what most people say. I did this (was a Winbond 25Q256JVEQ chip) and to my surprise RCUnlocker told me that the 32MB file was not compatible and I should try a 16MB file. My two questions to anyone who could bring more insight:
1. Is RCUnlocker indeed not compatible with 32MB BIOS files? It seems a lot of people have run it successfully
2. Is it so that SOME 840 G5 are password locked in the 32MB BIOS and others in the 16MB? It seems very inconcistent.
Thanks in advance!Comment
Read the previous post to yours. I mistakenly reported it as a Lenovo 840 G5 but it is an HP 840 G5. Good luck!Hi everyone,
Thanks in advance!Last edited by rddube; 01-27-2025, 09:11 PM.Comment
That is what led up to these questions, I suspect you are right, but in other replies in this thread it is clearly stated to be the 32Mb chip that should be patched (which seems impossible to me using RCUnlocker). Seems a bit inconsistent and would be interesting to understand if this is different in different versions of the 840 G5.Comment
rddube I was hoping to not have to desolder the 16MB chip (since I successfully connected to the 32Mb using wires). Just to double check: How did you connect to the 16Mb chip? Desolder? Clip? Wires? It seems that with wires my flash device says (no connection to IC) and at the same time a LED is flashing yellow on the motherboard (probably powered backwards from the chip flasher).Comment
The 16mb chip is on the other side of the motherboard, so you are going to take the motherboard out. I always desolder the bios they are so easy to desolder and use one of these attached SOP8 to DIP8 (I have different sizes) and resolder onto the board. You can always use the little board that comes with the CH341 programmer - just make sure you've got pin 1 on pin 1, etc. I never use the clips they are junk as far as I'm concerned.rddube I was hoping to not have to desolder the 16MB chip (since I successfully connected to the 32Mb using wires). Just to double check: How did you connect to the 16Mb chip? Desolder? Clip? Wires? It seems that with wires my flash device says (no connection to IC) and at the same time a LED is flashing yellow on the motherboard (probably powered backwards from the chip flasher).Comment
OK, so everything worked out just fine, let me share my learnings from this:
1. HP 840 G5 more often that not seems to have password configured in the EC chip on the backside of the motherboard, in my case a Winbond 25Q128JV SMD chip.
2. This chip can't be read or programmed when connected to the motherboard, there seems to be a protection kicking in. Must be desoldered.
3. The chip can easily be read and programmed with CH341A programmer when desoldered, and RCUnlocker worked on the first try.
4. Beware to read more than once and compare readouts, also after programming, read back several times and file compare.
5. Be very careful when resoldering to use enough flux and flow the connecting pins and pads generously.
All in all it worked great, but it was tricky to arrive at this solution due to the contradictory information in this thread. At least this procedure should work for all devices with the same motherboard type than mine.
Thanks rddube for the help to arrive at the right answer.Comment
hi, please help me remove the admin lock.
840 g5
sn: 5CG9152N96
THANKS IN ADVANCEAttached FilesComment
Read the post above yours, use RCUnlocker https://www.badcaps.net/forum/troubl...23#post1622423Comment
Looking to remove password from this HP 840 G5 bios.Attached FilesComment
RULES UPDATE for BIOS requests/offers AVOID BANNING, READ BEFORE POSTING
You MUST:- Provide the full machine model number, serial number (or Service tag, SNID) and the board model number (see https://www.badcaps.net/forum/showthread.php?t=88758 ) ,The serial number, make, full model number, motherboard model and revision (except QR codes) must be written/typed at your request as per the rules. Not as a picture, part of the file name and so on.
Try and GIVE feedback
First boot load bios factory defaults, save and exit and then at the next boot disable security options
You must fill your DMI manually.Attached FilesComment
							Channel: BIOS Requests ONLY!
			by traxformaniaHello,
I'm using TONGFANG "GM7TG7P" model laptop for over 3 years and i'm entering the same bios administrator password everyday. My laptop has Aptio BIOS (American Megatrends, AMI).
But today it's not accepting my password. I'm %100 sure i'm entering the correct password.
I'm trying to reset my bios without success.
I tried :
-I removed the BIOS battery and main battery. Waited for a long time but it didn't work. They already stated in the user manual that the password will not be reset even if the batteries... -
			by tlindiSublect line continuation: ... Jaguar IDS PC aka Panasonic
>Read BIOS guides, methods, resources and tools
Ack
>Try the method at BIOS guides, methods, resources and tools before requesting help
Ack
>Explain you were not able to succeed with the methods at BIOS guides, methods, resources and tools
python ./main.py "/mnt/c/temp/205605f9e1b60403a41787efeffe9cad-flas_maybe5.BIN" --output-dir "/mnt/c/temp/205605f9e1b60403a41787efeffe9cad-flas_maybe5.txt"
			by NopslideHello everyone, I come here to tell you my problem regarding the power-on password. It is not a bios reset demand, and i can't have any access to windows. This is the bios and power-on password that is blocking all other things.
My Omen 15-dh0052nf purchased second-hand was configured with the bios password upon purchase (very simple password :P ).
Having decided to sell it in order to get something more powerful, I reset all BIOS settings and set a blank administrator password. But the power-on password cannot be changed to a blank one so I let the actual password set....-
			by WutruHi guys,
If someone would be able to provide some expertise, I'd be very grateful.
BIOS Corruption - Cause
So I managed to corrupt my machine by installing linux and enrolling custom secure boot keys. I did choose to enroll the Microsoft keys as well, to prevent any potential bricking due to 3rd party drivers from HP being signed with those keys.
After doing that, and rebooting(it did boot, powerLED, fanspin etc.), the laptop did not give any video output on the LCD or video connectors. I think I was able to get in BIOS and trigger the beeper by pressing ESC....-
 - Loading...
