Dell Latitude 7400 Bios Password
Hello!
My machine is in manufacturing mode. I enter the service tag, but it does not record it. Alt+f does not exit manufacturing mode. The service tag field is empty every time it is switched on!โAttached FilesComment
Since I looked at the file W25Q256JV@WSON8_unlocked.bin you made a mistake with the offset address.
00048900 = 2400 FCAA 5900 0000 0000 00FF 35B2 2AA6
00048900 = 2400 FCAA 0000 0000 0000 00FF 35B2 2AA6
Instead of FCAA 59 you changed FCAA 59 to FCAA 00.
You changed the 59 to 00 that would explain your problem.โComment
please Dell Latitude 7400 Unlock Bios
ST FLGFZY2
tryAttached FilesComment
1st boot, press F2, write service tag, disable Absolute, save (Apply changes), restart. 2nd boot press Alt+F to exit manufacturing mode.Attached FilesComment
Can someone help remove BIOS password? There are 2 chips and I am not sure which is the BIOS.
Dell Latitude 7400
Service Tag: 847W633
Files Attached:
-ServiceTag_847W633_UT2_winbond_25080DVS1G2006.zip
-ServiceTag_847W633_UT6_AH2003_25080CS1G_EA3970.zip
Thank you in advance
Dell Latitude 7400
Files Attached:
Thank you in advanceโต
โhttps://www.badcaps.net/donateComment
Latitude 7400
Service Tag: 656P0X2
โAttached Filesโต
Service Tag: 3NBFZY2
please help thank you so much in advanceAttached FilesComment
Please follow this format
Model:
Serial Number:
Motherboard Code:
Backup.binโComment
Hi guys, please, can someone help me unlock this bios? It's from a Dell Latitude 7400, service tag CZB1733.
Many thanks.Attached FilesComment
by berrylinxDell Latitude 7400 2-in-1 bios with absolute persistence lock, Service Tag: HRPJN53
Can someone please assist with this please. I've provided two dump files using Xgeco T48, one is the read and default saved and other is the Flash saved option, they're labeled according.
Thank You....-
Channel: BIOS Requests ONLY!
by gizahaDell latitude 5580, motherboard cdp 80 la-e151p
Since ssd is replaced and had clean install windows, i've... -
by YOUCEF4787Hello everyone,
I'm working on a Dell Latitude 5490 with a LA-F401P motherboard that has a very peculiar issue, and I would appreciate your insights.
Initial Problem:
The laptop was completely dead, no signs of life, no power LED.
Action Taken:
I flashed the main BIOS chip with a clean dump. This brought the machine back to life, but with a strange limitation.
Current Situation & The Main Issue:
The laptop now works perfectly when powered through the USB-C port. It charges the battery, powers on, boots into the OS, and functions 100% correctly.... -
by jhanraHi there masters, recently i got a dell 5400 chromebook and wanted to install windows, i searched the internet and i found out other people also wanting a UEFI bios for this model, i searched there is a R/W legacy, but there are bugs like keyboard/trackpad not working, and hard to install.
in windows 11 sound driver compatibility, but overall its ok, for me i can deal with it, ๐ ๐ ๐ ...-
by anlsmithI am trying to remove the BIOS password for a Dell Latitude 5430 motherboard LA-L591P. So far I think that I have located the BIOS chip but NeoProgrammer says that is detects 3 chips. I have attached the dump from each one. Are any of these the BIOS file? Service Tag: 1DMC1T3. If nyone knows the exact location of the bios chip as well I would greatly appreciate it...
- Loading...
