Dell Latitude 7400 Bios Password
Re: Dell Latitude 7400 Bios Password 8FC8 Suffix
Until will appear generator for this suffix, 8FC8 working with BIOS patch for now.Joe's KMX1 Pro S, RevelprogIS, TL866II, CH341A, Vertyanov JIG 3.1, Eakins Microscope, Gordak 952, 30V/5Ah PSU, 890C+, T2L Thermal Camera, SVOD 3, etc.Comment
They are generators for all previous tags but not for this :/
Best shot is to downgrade it and then use generator on old prefix / tag
Of course if booting is possible not everything locked !!!
Good luckComment
@Gobbla
As far as I've read, 8FC8 suffix is totally new and not an upgrade like 6FF1 (upgraded from 1D3B or 1F66), or BF97 suffix upgraded from 6FF1, so downgrading the bios will not do any good in my opinion, at least not for 8FC8.
@Karol
Probably your best bet is to register computer at Dell while still under warranty, then contact them in a few days to ask for the master password.Comment
Hello
i will post the bios for Dell Latitude 7400 Soon wait and see
(i think that i have it in my collection )Comment
A couple of questions...
First, how would one go about figuring out a password for the bios if it is generated from a combination of the prefix and the suffix? I have the source code for the password generator that works for the older bios suffixes and I have looked at the code but I don't really understand everything that is going on there. I compiled the code and ran the app, of course it didn't work for the 8fc8 suffix so I have been checking back on this thread regularly. I have been a programmer of sorts for quite a while, but I'm only just now learning C, something I should have done many years ago but didn't. The question is however, what do you have to have and what do you have to do once you have the required pieces in order to figure out how to generate the password?
Second, to reprogram an EEPROM or similar chip, do you have to de-solder the chip from the motherboard and then place it into an external programming device, or can it be flashed somehow while it is still soldered on the motherboard?
I'm just trying to learn some of these things, at the same time I need to be able to access bios on this PC I picked up at an auction and currently I cannot. Any help or advice is greatly appreciated. Thanks.A wise man once said that an error doesn't become a mistake until you refuse to correct it. I subscribe to that philosophy.Comment
mod edit: Do not links to paid services.
If you ask for any money here you will be banned
************************************************Last edited by SMDFlea; 07-29-2020, 06:01 AM.Joe's KMX1 Pro S, RevelprogIS, TL866II, CH341A, Vertyanov JIG 3.1, Eakins Microscope, Gordak 952, 30V/5Ah PSU, 890C+, T2L Thermal Camera, SVOD 3, etc.Comment
As I said in previous deleted post, here on badcaps forum, all I do is for free.
@dimkka you have the file in private. Please confirm here if you succeed to unlock your Dell.
And please tell if I asked for money.
Cheers!Joe's KMX1 Pro S, RevelprogIS, TL866II, CH341A, Vertyanov JIG 3.1, Eakins Microscope, Gordak 952, 30V/5Ah PSU, 890C+, T2L Thermal Camera, SVOD 3, etc.Comment
thanks a lot, dell unlocked, @Karol helped for freeComment
Last edited by Karol; 08-17-2020, 03:00 AM.Joe's KMX1 Pro S, RevelprogIS, TL866II, CH341A, Vertyanov JIG 3.1, Eakins Microscope, Gordak 952, 30V/5Ah PSU, 890C+, T2L Thermal Camera, SVOD 3, etc.Comment
by berrylinxDell Latitude 7400 2-in-1 bios with absolute persistence lock, Service Tag: HRPJN53
Can someone please assist with this please. I've provided two dump files using Xgeco T48, one is the read and default saved and other is the Flash saved option, they're labeled according.
Thank You....-
Channel: BIOS Requests ONLY!
by gizahaDell latitude 5580, motherboard cdp 80 la-e151p
Since ssd is replaced and had clean install windows, i've... -
by jhanraHi there masters, recently i got a dell 5400 chromebook and wanted to install windows, i searched the internet and i found out other people also wanting a UEFI bios for this model, i searched there is a R/W legacy, but there are bugs like keyboard/trackpad not working, and hard to install.
in windows 11 sound driver compatibility, but overall its ok, for me i can deal with it, 😅😅😅...-
by anlsmithI am trying to remove the BIOS password for a Dell Latitude 5430 motherboard LA-L591P. So far I think that I have located the BIOS chip but NeoProgrammer says that is detects 3 chips. I have attached the dump from each one. Are any of these the BIOS file? Service Tag: 1DMC1T3. If nyone knows the exact location of the bios chip as well I would greatly appreciate it...
by YOUCEF4787Hello everyone,
I'm working on a Dell Latitude 5490 with a LA-F401P motherboard that has a very peculiar issue, and I would appreciate your insights.
Initial Problem:
The laptop was completely dead, no signs of life, no power LED.
Action Taken:
I flashed the main BIOS chip with a clean dump. This brought the machine back to life, but with a strange limitation.
Current Situation & The Main Issue:
The laptop now works perfectly when powered through the USB-C port. It charges the battery, powers on, boots into the OS, and functions 100% correctly.... - Loading...
