Motherboard: MS 16K51 Ver 1.1
MSI GS73 Stealth Model: MS-17B5 Bios needed
Re: MSI GS73 Stealth Model: MS-17B5 Bios needed
Full bios https://www.msi.com/Laptop/support/G...-8RE#down-bios -
I need the bin file for the bios chip. Bios model is Winband 25Q80DVComment
https://download.msi.com/bos_exe/nb/E17B5IMS.110.zip
Extract zip, rename E17B5IMS.110 to E17B5IMS.bin
The dump you posted isn`t the bios,the bios chip will be 25Q128Last edited by SMDFlea; 01-03-2020, 09:45 AM.Comment
You were right i did get the wrong chip. I found the 25Q128 one, dumped it and i did put the E17B5IMS.110 bios on it but it doesn't work. This is the 16MB from the dumpAttached Filesif you find these attachements useful please consider making a small donation to the site
try...Attached Filesif you find these attachements useful please consider making a small donation to the site
Every donation made will go towards server fees and maintenance costs.Comment
Bios from MSI home page.Attached Filesif you find these attachements useful please consider making a small donation to the site
https://www.badcaps.net/donateComment
by cekconsGigabyte G1 Assasain motherboard Bios IC model needed !
Bios ic fried and I cant read the model on top.
Thanks !-
by macabookHello everyone,
🧩 Initial Issue- Board powers on (fans spin, keyboard lights up and can be adjusted, caps lock led lights), but no display or backlight
- External display (HDMI) shows
Channel: BIOS Requests ONLY!
07-24-2025, 02:17 PM -
If anyone can help with a BIOS for this laptop it would be greatly appreciated (I even promise a forum donation!) - basically after battery removal, I powered on and got a brief flash of a message about making a recovery BIOS USB (which I have tried multiple times, to no avail) but then just a black screen. Since attempting a BIOS recovery, I don't even now get that brief message, so whether it did actually start trying to update or not I'm not sure, but nothing appeared on screen at any point.
I've now removed the chip from the board and taken a dump file from it...-
by TyMercerApologies if this is the wrong forum, but I'm not looking for a specific BIOS file, I'm trying to understand how one makes a clean BIOS file. So here's the background. I have 2 HP EliteDesk 800 g2 mini 35w pcs. One is working fine; the other doesn't have display out or working USB's nor does it have any flashing error lights. The CPU does get worm enough to cause the fan to spin up, so I think it's posting, but I just don't know. I had it working at one point but trouble started when I tried to put in a drive caddy that had a cooling fan on it. I thought it would be compatible but wasn't...
by DynaxSCHi, I have an MSI PRO B660M-G DDR4 board with damaged BIOS and i need a bios dump from a real board, along with MAC, UUID and Serial Number info (eg. a BIOS screenshot and pictures from the board stickers).
I need to reconstruct the bios on my board, based on another bios image form a real board - meaning a bios image containing MAC address, UUID and Serial number. A stock BIOS is not suffiecient, as it is impossible to discover where the MAC, UUID and SerialNumber are stored. Tried with a similar board, but there are too much differences, and the stock BIOS is missing a lot of...11-17-2023, 10:56 AM - Loading...
