MSI GS73 Stealth Model: MS-17B5 Bios needed
  • zenny95
    • Aug 2017
    • 28
    • romania
    Motherboard: MS 16K51 Ver 1.1
    • 21211
    Re: MSI GS73 Stealth Model: MS-17B5 Bios needed
    Full bios https://www.msi.com/Laptop/support/G...-8RE#down-bios
    • zenny95
      • Aug 2017
      • 28
      • romania
      Originally posted by SMDFlea
      I need the bin file for the bios chip. Bios model is Winband 25Q80DV
        • 21211
        https://download.msi.com/bos_exe/nb/E17B5IMS.110.zip
        Extract zip, rename E17B5IMS.110 to E17B5IMS.bin
        The dump you posted isn`t the bios,the bios chip will be 25Q128
        • zenny95
          • Aug 2017
          • 28
          • romania
          You were right i did get the wrong chip. I found the 25Q128 one, dumped it and i did put the E17B5IMS.110 bios on it but it doesn't work. This is the 16MB from the dump
          • peste
            • Dec 2016
            • 12973
            • ROMANIA
            try...
            • nissimezra
              • 177
              Originally posted by peste
              try...
              Hello, I tried this one but black screen.
              Regards
              • hoaca388
                Badcaps
                • Jan 2022
                • 11901
                Regards
                Bios from MSI home page.
                • nissimezra
                  • 177
                  Thank you I will try and report back
                  • nissimezra
                    • 177
                    thank you. Still black screen. all power supplies working.
                    • iv4nosky
                      • Jun 2013
                      • 13
                      • Spain
                      try...
                      Thank you , its working ok. GPU Not detected at device manager , anyway it has bios password , do you know it?
                      • peste
                        • Dec 2016
                        • 12973
                        • ROMANIA
                        try post #8 ... it's after the MSI website..
                        • iv4nosky
                          • Jun 2013
                          • 13
                          • Spain
                          Some genius removed the gpu mosfet. Now its working again.
                          Anyway I need that bios password
                          • cekcons
                            Gigabyte G1 Assasain motherboard Bios IC model or Schematic needed !
                            by cekcons
                            Gigabyte G1 Assasain motherboard Bios IC model needed !
                            Bios ic fried and I cant read the model on top.
                            Thanks !
                            07-16-2025, 01:22 AM
                          • macabook
                            by macabook
                            🧩 Initial Issue
                            07-24-2025, 02:17 PM
                          • themosttogain
                            ASUS ROG G513** BIOS needed - board model G513-6050A3249301-MB-A03
                            by themosttogain
                            If anyone can help with a BIOS for this laptop it would be greatly appreciated (I even promise a forum donation!) - basically after battery removal, I powered on and got a brief flash of a message about making a recovery BIOS USB (which I have tried multiple times, to no avail) but then just a black screen. Since attempting a BIOS recovery, I don't even now get that brief message, so whether it did actually start trying to update or not I'm not sure, but nothing appeared on screen at any point.
                            I've now removed the chip from the board and taken a dump file from it...
                            12-08-2023, 04:29 PM
                          • DynaxSC
                            by DynaxSC
                            11-17-2023, 10:56 AM
                          • iulik17d
                            Intel Arc A380 videocard power limit remove - BIOS needed
                            by iulik17d
                            Hello everyone!
                            The Asrock A380 low profile card (ID 8086 56A5 - 1849 6006) have an power limit of 45W. Intel removed the possibility to increase power using the software utility, anyway the card is in an proxmox machine that doesn't run windows.
                            The same hardware is in another form by the name Asrock A380 Challenger that have the same VRMs and the power limit is at 60W. I searched online and found on another website an .bin bios file from the Challenger variant, that I flashed using an CH341a. Flashng worked well, I put the card in PC and booted. GPUz shows that new device ID is 8086...
                            01-10-2025, 02:33 PM
