Dell g3 15 cal53 la-f611p rev:1.0
  • zurvanielle
    • Feb 2017
    • 137
    • Philippines
    HalOoh guys.... good day.... need help.. anyone who got a bios bin file for
    DELL G3 15 CAL53 LA-F611P REV:1.0
    thnks in advance
  • Marc97
    • Jan 2016
    • 189
    • Phillipines
    Re: Dell g3 15 cal53 la-f611p rev:1.0
    thnks in advance
    i also nid file for this canu help us
      • 20888
      Post your bios backup .
      • Marc97
        • Jan 2016
        • 189
        • Phillipines
        here is my copy back up invalid file
        • Marc97
          • Jan 2016
          • 189
          • Phillipines
          upload error me
            • 20888
            Post the file in a zip or rar .
              • 20888
              Try this bios .
                • 20888
                G3 15 ME clean
                • Francisco.s
                  • 686
                  • Spain
                  G3 15 ME clean
                  Does not works with this cleaned bios either.
                  It reboots a few times at first, but it's the same as before.
                  Time to moving on to other delayed works.
                  Thanks for all your efforts.
                  • roberthcor
                    • Apr 2019
                    • 8
                    • peru
                    Try this bios .
                    gracias
                    • Etx
                      • Jan 2019
                      • Egypt
                      Try this bios .
                      Can you please tell me where the EC dump is stored on this MB? Looks like my problem is due to EC incorrect FW.
                      • murlee
                        • Nov 2020
                        • 4
                        • china
                        really appricated.
                        • murlee
                          • Nov 2020
                          • 4
                          • china
                          my backup via a direct read from dell g3 3579 winbond 25Q128
                          • alilaptops
                            • Apr 2019
                            • 17
                            • Pakistan
                            pleas clear my bios password file working 100%
                            • AAAC
                              • Jan 2020
                              • 458
                              • Mexico
                              @alilaptops
                              Why you don't try to unlock it by code? I believe this model uses the BF97 suffix, I just checked the bios and that's what I found. BF97 generator has been already released.
                              • alilaptops
                                • Apr 2019
                                • 17
                                • Pakistan
                                bios have no display clear me
                                • lapfix
                                  • Mar 2020
                                  • 2721
                                  • my workshop
                                  Try and give feedback
                                  • digidoid
                                    • Jul 2018
                                    • 6
                                    • Moldova
                                    works - ok - thx
                                    • mferna14
                                      • Jun 2018
                                      • 1020
                                      Hi all, can anyone clean this Original BIOS of Dell G3 15 LA-F611 (Motherboard) Laptop. With the original BIOS the Fans are running 100% & NO DISPLAY, I tried the above BIOS Bin files & the status changed, it went through its self test mode, turning On & Off 2 times & then steady but still no display. If someone can help & kindly update these Bin files for me, I would appreciate. Thanks in advance.
                                      • hardware1
                                        • Sep 2021
                                        • 2930
                                        • N/A
                                        Here's your New bios file, try it and give me the results.
                                        Service Tag: BNZ9YQ2.
                                        all donations are welcome,
                                        • Bowline
                                          by Bowline
                                          06-11-2025, 10:13 AM
                                        • F R 2568
                                          Dell Latitude 5420 does not start (no post) need help to find the reason why
                                          by F R 2568
                                          Hello all,
                                          this is my first post, so if I make mistakes please do not hesitate to point them out, thank you in advance.
                                          I got a Dell Latitude 5420 (Service Tag: 7RFM6D3, Motherboard: GDF40 LA-491P Rev.: 2.0 (A01)) which does not start and I want to repair it. These are the symptoms:
                                          If the laptop is only connected to the AC adapter (battery removed):
                                          When I press the power button, the keyboard backlight and the display backlight are turning on. Caps key light is lightning, but key does not respond to pressing it.
                                          The power/battery...
                                          01-08-2025, 05:45 AM
                                        • diamon
                                          Looking for Dell Latitude 5520 / 5530 / 5540 RJ45 network connector replacement
                                          by diamon
                                          I have a Dell Latitude 5530 with a damaged RJ45 network connector. See the attached pictures.
                                          Have already searched on Farnell / Aliexpress / Ebay and had contact with several suppliers on Aliexpress and Ebay, but they cannot deliver this connector.
                                          Is there someone inside the EU, who has these connector(s) or perhaps defective motherboard(s) for these laptop models I have mentioned in the topic title.
                                          Pictures of these boards:
                                          Dell Latitude 5520 https://www.ebay.com/itm/256052956663
                                          Dell Latitude 5530 https://www.ebay.com/itm/125844181534
                                          Dell...
                                          02-28-2024, 12:51 PM
                                        • master3112
                                          by master3112
                                          07-29-2025, 01:55 PM
                                        • OntarioTL
                                          Dell 5410 greyed out BT
                                          by OntarioTL
                                          Well I've learned something new today. Of all the Dell laptops I've come across I have never seen bluetooth greyed out, and only to learn this is during the build from Dell factory. I've tried to pull the original BIOS and fix with another dell with the same issue on the forums, however the original was not recovered from the forum upgrade so I cannot do a comparison to attempt the fix on my own.
                                          If someone could help me out with this unit and I'll try the next one as so far I have 2 on my desk with this issue. Thanks in advance!
                                          Dell Lattitude 5410
                                          Service Tag...
                                          07-25-2025, 01:28 PM
