Dell g3 15 cal53 la-f611p rev:1.0
Become a Badcaps supporter
Thanks to all supporters.​
----------------------------------------------------------------------------------------------------------------------------------------------------------Doctrina est fructus dulcis, radicis amarae.. -
Good Day, hello guys need help for this bios only stuck on dell logo but the caps lock working when you press it.
ST: B6PM7T2
Thanks in advance...Attached FilesComment
Good day every one, please can someone assist me in fixing this bios file, No display the fan spin on high speed, below is the backup file
DELL G3 La-F611p Rev 1.0 Bios
Service Tag:GWK7DX2
​Comment
hello. the situation is like this. the cooler spins at 100% and there is no image. can you fix the bios? I am attaching the bios fileAttached FilesComment
Every donation made will go towards server fees and maintenance costs.Comment
sorry for taking so long to answer. laptop
Dell G3 3579​ dell p75f(p75f003), board cal53 la-f611p rev 1.0, service tag- 91nf803.
Thank youAttached FilesComment
Hello People Please Need Help ?Dell CAL53 LA-F611P REV 1.0.. No Display Fun Spinning Fast And Caps is on but NO DISPLAY PLEASE HELP
SN: J8VYBV2Attached FilesComment
----------------------------------------------------------------------------------------------------------------------------------------------------------​Comment
HERE IS THE FILEAttached FilesComment
Hi there,
I would like to request a bios rebuild, unit turns on, fans run at full speed. no picture.
Dell G3 3579
MB : LA-F611P REV 1.0
ST : D8KGYQ2
please see attached biosAttached FilesComment
Service Tag: D8KGYQ2​Attached Files
I forgot to save my original dump, SERVICE tag is 9T5J8T2,can someone put my service tag into the clean ME flash?
i tried flashing the dumps from here, and few of them work, but only once...and the laptop is super slow and once you restart or turn off , next time only fans spin and no image...Comment
I need a new bios file. Mine do on and trip off within few seconds without display. It hardly turns on after tripping off.
Cal53 la-f611p rev 1.0
GHJ0YR2​Attached FilesComment
Bought a faulty laptop from eBay. Fault is when I press power button, the keyboard backlight comes on. About 5 seconds or so later, the fans come on at full speed along with the white LED. The white LED remains solid white for a bit and then goes off. Screen is black with no backlight (not even a flicker). Laptop does not reboot by itself (I've waited long enough). To turn off, I have to force power off by pressing/holding the power button. Did all the basics (such as removing non-essentials, testing new RAM and different RAM configs, resetting CMOS) but it still occurs. So I am wanting to test out flashing a new BIOS with my CH341A (1st time using it) programmer. I've soldered the IC to the CH341A, read it and saved 2 backups. It did both without error. Now I am stuck on getting a BIN file so I can flash a new BIOS with the CH341A. I tried going to Dell but they only offer .EXE and .RCV files. I am not sure how to convert them to .BIN. So I am hoping someone here might be able to create a new BIOS from my backup. I am not sure if the BIOS is causing this fault, but it is something I want to test to see since there's no shorts on the board and it does appear to be getting power.
Some info:
Laptop Model: Dell G3 3579
Motherboard Model: CAL53 LA-F611P Rev 1.0 (A00)
Service Tag: 6PH2YR2Attached FilesComment
by BowlineMy question pertains to understanding the control circuity inside a Dell PT434 type battery used in Dell E6400, E6410 and other Dell notebooks?
I have tried multiple different Dell power adapters. My Dell... -
by F R 2568Hello all,
this is my first post, so if I make mistakes please do not hesitate to point them out, thank you in advance.
I got a Dell Latitude 5420 (Service Tag: 7RFM6D3, Motherboard: GDF40 LA-491P Rev.: 2.0 (A01)) which does not start and I want to repair it. These are the symptoms:
If the laptop is only connected to the AC adapter (battery removed):
When I press the power button, the keyboard backlight and the display backlight are turning on. Caps key light is lightning, but key does not respond to pressing it.
The power/battery... -
by diamonI have a Dell Latitude 5530 with a damaged RJ45 network connector. See the attached pictures.
Have already searched on Farnell / Aliexpress / Ebay and had contact with several suppliers on Aliexpress and Ebay, but they cannot deliver this connector.
Is there someone inside the EU, who has these connector(s) or perhaps defective motherboard(s) for these laptop models I have mentioned in the topic title.
Pictures of these boards:
Dell Latitude 5520 https://www.ebay.com/itm/256052956663
Dell Latitude 5530 https://www.ebay.com/itm/125844181534
Dell...4 Photos -
by lalle-Hello!
I have a problem with a Dell G5 SE 5505 laptop that I hope someone can give me a few pointers on.
[OK, it's not really a laptop, I'm running the motherboard on my desktop with only cooling, RAM and an M2 drive attached.]
I had some performance issues, so I decided to update my BIOS from 1.7.0 to the latest version, 1.20.0.
The computer restarted and the update dit not want to continue without a battery connected, even though I used dell's method of bypassing this requirement.
I tried updating to a custom BIOS from Reddit user Satori_Nori https://www... -
by trix11I have a Dell Precision T1650 MT workstation (of the following spec.) that was bricked yesterday when attempting to update the BIOS from A27 to A28 per:
- https://www.dell.com/support/home/en...-t1650/drivers > Dell Precision T1650 System BIOS
- Dell Precision T1650 mid tower Workstation
- Xeon E3-1225 V2
- 32Gb PC3-12800E RAM
- 4Tb SATA HDD
- motherboard: Dell part: 0C3YXR CN-0C3YXR-72200-39C-01GR-A02
I see now that others have experienced like issues e.g.:
- https://www.dell.com/community/Prec...-
- Loading...
Unconfigured Ad
