HP ProBook 450 G3
  • Blaze Tech
    Learner
    • 217
    • Ghana
    #181
    Originally posted by Echoo
    Hello!
    HP Proboook 450 G3 - two long and two short beeps, won't start. I am asking for help to fix the bios!
    SN: 5CD6411MN8
    CPU: i5-6200u
    try
    • Kwiss Beats
      • Sep 2024
      • Netherlands
      #182
      I cannot find the chip on the board lol, does any of you know where it is located?
      I have it right in front of me
      • dscomputer
        • Aug 2022
        • 11
        • pakistan
        #183
        Need Maestro-EBook11v2 bios bin
          • 22293
          Off topic. Start your own thread......
          • kinoxa
            • Dec 2011
            • 29
            • Kyiv
            #185
            Hi!
            HP Probook 450 G3
            DAX63CMB6D1
            ​SN: 5CD62204LC
            The laptop is working, the fan is spinning at maximum. Fix the BIOS.
            • tuyen821991
              • Oct 2024
              • 51
              • Viet Nam
              #186
              I NEED unpass bios . Not have serial
              thanks
            • shamaia2010
              • Feb 2025
              • Philippines
              #187
              Hi please help me fix my laptop bios, caps lock blinking i think 15 times
              Tried almost bin files on this thread but no luck, fan spins at max speed without display
                • 22293
                Please read https://www.badcaps.net/forum/troubl...before-posting ,then type the laptop serial number
                • shamaia2010
                  • Feb 2025
                  • Philippines
                  #189
                  Model : HP Probook 450 G3
                  Board : DA0X63MB6H1 REV:H
                  S/N : JPH62445T2
                  • mactouch
                    • Nov 2018
                    • 100
                    • Abu Dhabi
                    #190
                    HP ProBook 450 G3 - Only fan spinning no display plz help to fix the bios!
                    SN- 5CD6514DCZ
                    • Alpha_B
                      • Mar 2017
                      • Portugal
                      #191
                      Can you please fix my bios?
                      450 g3
                      SN: 5CD5459RJJ
                      i5 6200
                      AMD gpu
                      • Ahari
                        by Ahari
                        I...
                        08-13-2025, 06:12 AM
                      • mkdj
                        by mkdj
                        Dear all,
                        10-19-2025, 04:41 AM
                      • Habble7
                        by Habble7
                        Suspected Cause:
                        Troubleshooting Attempts:
                        05-22-2025, 07:28 AM
                      • studdy05
                        Bricked HP Probook 450 G7 Bios questions
                        by studdy05
                        Hp Probook 450 G7 s# SCD0348W35 had a locked BIOS. Bought BIOS and EC chips off Ebay that were supposed to match this machine - the 450 G7. Flashed in the BIOS on chip i bought using a CH341. BIOS unlocked next boot. Some error to contact HP. Entered BIOS and reset to system defaults and rebooted. Machine worked fine but every cold boot the contact HP message popped and everything else worked as fine. Assumed the error was from EC chip not matching BIOS that i just flashed in. So i flashed in the EC that was supposed to match from the EBay chip i bought and instant brick.
                        Ive got...
                        07-08-2025, 09:24 PM
                      • haitham sharabati
                        by haitham sharabati
                        Hello engineers 😀,
                        🔧 Device Info:
                        - Model: HP 15-da2007ne
                        - Product Number: 8XF55EA#ABV
                        - Serial Number: CND0338P0D
                        - CPU: Intel Celeron N4000
                        💀 Problem:😅
                        08-07-2025, 04:54 AM
