HP ProBook 450 G3
  • Blaze Tech
    Learner
    • 205
    • Ghana
    #181
    Originally posted by Echoo
    Hello!
    HP Proboook 450 G3 - two long and two short beeps, won't start. I am asking for help to fix the bios!
    SN: 5CD6411MN8
    CPU: i5-6200u
    try
    • Kwiss Beats
      • Sep 2024
      • Netherlands
      #182
      I cannot find the chip on the board lol, does any of you know where it is located?
      I have it right in front of me
      • dscomputer
        • Aug 2022
        • 11
        • pakistan
        #183
        Need Maestro-EBook11v2 bios bin
          • 20977
          Off topic. Start your own thread......
          • kinoxa
            • Dec 2011
            • 24
            • Kyiv
            #185
            Hi!
            HP Probook 450 G3
            DAX63CMB6D1
            ​SN: 5CD62204LC
            The laptop is working, the fan is spinning at maximum. Fix the BIOS.
            • tuyen821991
              • Oct 2024
              • 44
              • Viet Nam
              #186
              I NEED unpass bios . Not have serial
              thanks
            • shamaia2010
              • Feb 2025
              • 3
              • Philippines
              #187
              Hi please help me fix my laptop bios, caps lock blinking i think 15 times
              Tried almost bin files on this thread but no luck, fan spins at max speed without display
                • 20977
                Please read https://www.badcaps.net/forum/troubl...before-posting ,then type the laptop serial number
                • shamaia2010
                  • Feb 2025
                  • 3
                  • Philippines
                  #189
                  Model : HP Probook 450 G3
                  Board : DA0X63MB6H1 REV:H
                  S/N : JPH62445T2
                  • mactouch
                    • Nov 2018
                    • 86
                    • abudhabi
                    #190
                    HP ProBook 450 G3 - Only fan spinning no display plz help to fix the bios!
                    SN- 5CD6514DCZ
                    • Habble7
                      by Habble7
                      Suspected Cause:
                      Troubleshooting Attempts:
                      05-22-2025, 07:28 AM
                    • studdy05
                      Bricked HP Probook 450 G7 Bios questions
                      by studdy05
                      Hp Probook 450 G7 s# SCD0348W35 had a locked BIOS. Bought BIOS and EC chips off Ebay that were supposed to match this machine - the 450 G7. Flashed in the BIOS on chip i bought using a CH341. BIOS unlocked next boot. Some error to contact HP. Entered BIOS and reset to system defaults and rebooted. Machine worked fine but every cold boot the contact HP message popped and everything else worked as fine. Assumed the error was from EC chip not matching BIOS that i just flashed in. So i flashed in the EC that was supposed to match from the EBay chip i bought and instant brick.
                      Ive got...
                      07-08-2025, 09:24 PM
                    • haitham sharabati
                      [Request] Clean BIOS dump for HP 15-da2007ne (8XF55EA#ABV) - N4000 - BIOS Lock
                      by haitham sharabati
                      Hello engineers 😀,
                      I’m kindly requesting a clean and unlocked BIOS dump for the following HP laptop, as it’s bricked after flashing SP152727. The system now keeps rebooting, and the original issue was an Administrator / Power-On Password that I can no longer access.😏
                      🔧 Device Info:
                      - Model: HP 15-da2007ne
                      - Product Number: 8XF55EA#ABV
                      - Serial Number: CND0338P0D
                      - CPU: Intel Celeron N4000
                      - EC/BIOS Chip: [Add chip number from the motherboard or BIOS chip]
                      💀 Problem:😅
                      - Device shows “Administrator Password”...
                      08-07-2025, 04:54 AM
                    • Citymin
                      by Citymin
                      S/N : 5RNK9FFT70...
                      08-05-2025, 05:12 AM
                    • DynaxSC
                      by DynaxSC
                      11-17-2023, 10:56 AM
