HP ProBook 450 G3
  • Blaze Tech
    Learner
    • 205
    • Ghana
    #181
    Originally posted by Echoo
    Hello!
    HP Proboook 450 G3 - two long and two short beeps, won't start. I am asking for help to fix the bios!
    SN: 5CD6411MN8
    CPU: i5-6200u
    try
    • Kwiss Beats
      • Sep 2024
      • Netherlands
      #182
      I cannot find the chip on the board lol, does any of you know where it is located?
      I have it right in front of me
      • dscomputer
        • Aug 2022
        • 11
        • pakistan
        #183
        Need Maestro-EBook11v2 bios bin
          • 20977
          Off topic. Start your own thread......
          • kinoxa
            • Dec 2011
            • 24
            • Kyiv
            #185
            Hi!
            HP Probook 450 G3
            DAX63CMB6D1
            ​SN: 5CD62204LC
            The laptop is working, the fan is spinning at maximum. Fix the BIOS.
            • tuyen821991
              • Oct 2024
              • 44
              • Viet Nam
              #186
              I NEED unpass bios . Not have serial
              thanks
            • shamaia2010
              • Feb 2025
              • 3
              • Philippines
              #187
              Hi please help me fix my laptop bios, caps lock blinking i think 15 times
              Tried almost bin files on this thread but no luck, fan spins at max speed without display
                • 20977
                Please read https://www.badcaps.net/forum/troubl...before-posting ,then type the laptop serial number
                • shamaia2010
                  • Feb 2025
                  • 3
                  • Philippines
                  #189
                  Model : HP Probook 450 G3
                  Board : DA0X63MB6H1 REV:H
                  S/N : JPH62445T2
                  • mactouch
                    • Nov 2018
                    • 86
                    • abudhabi
                    #190
                    HP ProBook 450 G3 - Only fan spinning no display plz help to fix the bios!
                    SN- 5CD6514DCZ
                    • DynaxSC
                      by DynaxSC
                      11-17-2023, 10:56 AM
                    • ktcar214
                      Need help for HP ProBook 445R G6 Secure boot key removal from BIOS dump
                      by ktcar214
                      Hello.
                      I tried to add a custom secure boot key (for secure booting Linux) to my bios, but after this, my laptop bricked. After adding secure boot key (via PowerShell) and enabling secure boot my laptop turns on, shows HP logo, and after 5 seconds it turns off and on, and it repeats forever.
                      My goal is to either turn off secure boot or remove my custom key from BIOS dump.
                      I'll attach my bios dump (version R79_011700) from my bios chip 25b127dsig, my keys (PK/KEK/db), and bios dump from another HP ProBook 445R G6(I found it on this forum. URL: https://www.ba...
                      12-07-2021, 08:57 AM
                    • DynaxSC
                      Who has a MSI Z590 PRO WIFI - Need BIOS dump ?
                      by DynaxSC
                      I need a BIOS dump for MSI Z590 PRO WIFI from a real physical board, along with MAC address and serial no.
                      It must be a dump from a physical board, as it contains personalized data eg. MAC Address, UUID, Serial no.
                      I have a board which has lost the BIOS contents, I have the MAC and serial to this board, and need to insert it into the another BIOS image. To do it, I need to have a real image from a real board, as the images from the MSI site are without this data. The only way to find where MAC/UUID/Serial is located in the BIOS is to have a bios...
                      11-06-2022, 05:22 PM
                    • Buzzfuzz2k
                      Bios password removal on a Unowhy dump
                      by Buzzfuzz2k
                      Hi Everyone,
                      I'm facing a problem with a locked bios with a password and i can't find how to remove it...
                      The small computer is only booting on a M2 ssd Windows partition and i get a "signed partition error" if i try to boot on the same SSD with another Os (linux for example).
                      the Computer is a Unowhy small pc
                      N° UYM6524702229
                      After failling trying to boot on other "none Windows" partition, i wanted to try to remove the bios password.
                      My first attempt was to get the bios dump from windows...
                      11-13-2023, 07:37 AM
                    • AHmad_Salal
                      Need BIOS Dump/ROM for Lenovo Thinkstation p500
                      by AHmad_Salal
                      Hello all,
                      I have a Lenovo Thinkstation P500 that is stuck at post with no display, it happened after I changed the memory timings in bios. I can not clear CMOS using the jumper on the motherboard, also tried re-flashing bios suing a USB stick but it also doesn't work. The only solution that I can think of right now is re-flashing the bios chip using an external programmer but the problem is that I don't have the bios dump of p500 for flashing externally and I don't know the location of bios chip. If someone can provide the bios dump and bios chip location it would be really helpful....
                      11-28-2023, 05:28 AM
