hp 840 g6 6050A3022501-MB-A01
  • rex98
    • Feb 2023
    • 1239
    • Mandaue CEBU, Philippines
    #381
    Originally posted by trunguntilyou
    please help me!
    serial number?
    • trunguntilyou
      • Aug 2022
      • 307
      • Vietnam
      #382
      Originally posted by rex98
      serial number?
      Can't see anything on the lid,,, can't get into the bios
      • Muhammad umair154
        • Feb 2023
        • 11
        • Pakistan
        #383
        Anyone plzz help me to fix this issue.
        6050A3022501 -MB-A01
        Serial: 5CG025F59C
        • rex98
          • Feb 2023
          • 1239
          #384
          Serial: 5CG025F59C
          follow these instructions.
          First boot press f10 reset bios to factory defaults and exit, 2nd boot reset security settings to defaults.
          use BCU permanently disable the absolute there.
          here's your DMI info:
          Serial Number: 5CG025F59C
          Product Number: 4YD61AV
          CT Number: PHWHB00WBDS7OK
          Description: HP EliteBook 850 G6
          build_id: 19WWCFCT601#SABA#DABA
          Feature Byte: 3X476J6S6b7B7H7M7Q7W7m7saBaEapaqauawbUbhcAdUdpdqfAfPfXgShKjhk8.72
          MAC Address: BC-E9-2F-CC-55-46
          • pdacha
            • Sep 2012
            • 8
            • serbia
            #385
            Hello,i need help, it's a locked laptop hp 840 g6, which after unlocking gives an endpoint security error, I've tried almost all files from the forum. it doesn't work, it throws an error, I'm sending you the original locked files. please unlock them, and remove the endpoint error.
          • rex98
            • Feb 2023
            • 1239
            #386
            only flash this main do not touch the EC.
            Serial Number: 5CG0338WNT
            Product Number: 4WG30AV
            CT Number: PHWGH00WBE3D13
            Description: HP EliteBook 840 G6
            build_id: 19WWCFCT601#SABD#DABD
            Feature Byte: 3X476J6S6b7B7H7M7Q7W7m7saBaEapaqauawbUbhcAdUdpdqfPfXhKhkjhk8.y8
            MAC Address: 84-2A-FD-C7-EB-84
            • pdacha
              • Sep 2012
              • 8
              • serbia
              #387
              Great work REX98, thank you so much. now is ok.
              • rayshine03121408
                • Feb 2018
                • 91
                • Phillipines
                #388
                Good Day Masters! Anyone can remove computer trace on my BIOS Bin? Thanks in Advance
                Model: HP 840 G6
                Board: 6050A3022501-MB-A01
                S/N: 5CG9341GFK
                • rex98
                  • Feb 2023
                  • 1239
                  #389
                  Model: HP 840 G6
                  S/N: 5CG9341GFK
                  First boot press f10 reset bios to factory defaults and exit, 2nd boot reset security settings to defaults and exit.
                  Use BCU to fill these DMI info. you can permanently disable absolute in BCU​
                  Serial Number: 5CG9341GFK
                  Product Number: 7UA41UC#UUF
                  CT Number: PHWGH00WBCN7NX
                  BuildID: 19WWCFAT603#SUUF#DUUF
                  Feature Byte: 3X476J6S6b7B7H7M7Q7W7m7saBaEapaqauawbUbhcAdUdpdqfPhKhkjhk8.gn
                  MAC Address : 04:0E:3C:40:56:41
                  • black0hackers
                    • Jul 2020
                    • 365
                    SOme one help me fix this file. not detect ssd
                    board code: 6050A3022501-MB-A01
                    This no have serial number
                    • rex98
                      • Feb 2023
                      • 1239
                      #391
                      here
                      • black0hackers
                        • Jul 2020
                        • 365
                        here
                        hi. thank you for your help. now ssd detected. but laptop can boot to windows or cant boot from usb to install new windows
                        • rex98
                          • Feb 2023
                          • 1239
                          #393
                          again try
                          • black0hackers
                            • Jul 2020
                            • 365
                            again try
                            ssd not detect again and me firmware error
                            • rex98
                              • Feb 2023
                              • 1239
                              #395
                              here
                              this bios is tested and working. maybe you have problem with your installer.
                              • compuline
                                • Jun 2023
                                • 30
                                • egypt
                                #396
                                hello friends i need remove password and clean me hp elitebook 840 g6
                                and i have this message
                                hp endpoint security controller problem
                                i need resolve this message
                                • hoaca388
                                  Badcaps
                                  • Jan 2022
                                  • 11226
                                  • Viet Nam
                                  #397
                                  • rajnbb
                                    • Dec 2021
                                    • 7
                                    • Austri
                                    #398
                                    Hello Guys,
                                    my HP 840 G6 did and automatic BIOS Update and then it failed somehow..
                                    When i try to Power it ON the Caps Lock stays on the whole time and nothing other happens.
                                    Here are my 2 Bios Dump Files (32MB Chip and 16MB Chip)
                                  • rajnbb
                                    • Dec 2021
                                    • 7
                                    • Austri
                                    #399
                                    Im sorry!!
                                    SN: 5CG936B5D5
                                    • hoaca388
                                      Badcaps
                                      • Jan 2022
                                      • 11226
                                      • Viet Nam
                                      #400
                                      Originally posted by rajnbb
                                      Im sorry!!
                                      SN: 5CG936B5D5
                                      The 16MB file is corrupted
