Asus X441B BIOS
  • FrozenHaxor
    • Jun 2015
    • 260
    • Poland
    Asus X441B BIOS
    Motherboard marking is X441BA
    Dump is greatly appreciated.
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    Re: Asus X441B BIOS
    Post your bios backup here.
    • FrozenHaxor
      • Jun 2015
      • 260
      • Poland
      Re: Asus X441B BIOS
      Sorry for late response, I have the motherboard now.
      Verified dump in attachment.
      • mcplslg123
        • Jun 2015
        • 7262
        • india
        Re: Asus X441B BIOS
        Here is virgin bios from asus website. Infact, there is a complete bios in asus update. You only need to cut the header a bit. Post feedback.
        • FrozenHaxor
          • Jun 2015
          • 260
          • Poland
          Re: Asus X441B BIOS
          Yep, that one works. Thanks alot!
          • Vicksssgaber
            • May 2018
            • 8
            • Singapore
            Re: Asus X441B BIOS
            Perfect... Thankyou
            • noorikhsan
              • Jul 2020
              • 3
              • indonesia
              Re: Asus X441B BIOS
              thank you...
              • kodox
                • Jul 2017
                • 322
                • Indonesia
                Re: Asus X441B BIOS
                anyone know how to insert machine serial number in this model?
                • lapfix
                  • Mar 2020
                  • 2719
                  • my workshop
                  Re: Asus X441B BIOS
                  With Hxd , you find the line..select..copy/paste..that's all.
                  • kodox
                    • Jul 2017
                    • 322
                    • Indonesia
                    Re: Asus X441B BIOS
                    i don't have original dump because this machine has the bios chip replaced by someone with the wrong chip and when i read it with my programmer, it's empty!!!
                    i've tried using someone's dump here but still the SN not showed in bios, please advice...
                    • peste
                      • Dec 2016
                      • 12718
                      • ROMANIA
                      Re: Asus X441B BIOS
                      post the complete model of the laptop and the motherboard
                      • kodox
                        • Jul 2017
                        • 322
                        • Indonesia
                        Re: Asus X441B BIOS
                        here you go sir...
                        • lapfix
                          • Mar 2020
                          • 2719
                          • my workshop
                          Re: Asus X441B BIOS
                          here you go sir...
                          post the working dump too
                          • kodox
                            • Jul 2017
                            • 322
                            • Indonesia
                            Re: Asus X441B BIOS
                            i'm using file posted by @mcplslg123 at post #4
                            • kodox
                              • Jul 2017
                              • 322
                              • Indonesia
                              Re: Asus X441B BIOS
                              anyone...????
                                • 20781
                                Re: Asus X441B BIOS
                                anyone...????
                                Try this bios .
                                • kodox
                                  • Jul 2017
                                  • 322
                                  • Indonesia
                                  Re: Asus X441B BIOS
                                  Originally posted by SMDFlea
                                  Try this bios .
                                  Thank's, the unit has taken by the owner without SN. i'll tried it another time
                                  • apologized
                                    • Dec 2019
                                    • 12
                                    • morocco
                                    Re: Asus X441B BIOS
                                    Try this bios .
                                    thanks it's worked
                                    and updated to last ver 310 by EZ flash
                                    • laptopkurusak.com
                                      • Dec 2017
                                      • 3
                                      • indonesia
                                      Re: Asus X441B BIOS
                                      thanks
                                      • go to fix
                                        • Dec 2020
                                        • 6
                                        • INDONESIA
                                        Re: Asus X441B BIOS
                                        work perfectly on my case, power on but no switch on. Thanks a lot..
                                        • razor_amd
                                          by razor_amd
                                          12-15-2020, 07:07 PM
                                        • grimacelord
                                          by grimacelord
                                          07-10-2025, 02:52 PM
                                        • throwaway327
                                          by throwaway327
                                          Model No: RC72LA
                                          Serial No: SBNVKD001014459
                                          06-18-2025, 05:52 PM
                                        • jbonavita
                                          by jbonavita
                                          Some issues
                                          Things I tried
                                          04-29-2025, 09:38 PM
                                        • lrouw84
                                          by lrouw84
                                          Hi there,
                                          01-28-2023, 01:31 PM
