Please I need bios for Asus FX705G
  • Sami Wahid
    • Oct 2015
    • 77
    • Morocco
    Hello all friends
    I need bios for Asus FX705G, Motherboard Number : ( FX505GD/MB REV:2.0 ) Size : 16MB
    Thank you.
  • peste
    • Dec 2016
    • 12748
    • ROMANIA
    Re: Please I need bios for Asus FX705G
    try..
    • Sami Wahid
      • Oct 2015
      • 77
      • Morocco
      Originally posted by peste
      try..
      Thank you for reply, but the file does not work
        • 20810
        Post your bios backup .
        • Sami Wahid
          • Oct 2015
          • 77
          • Morocco
          Hi my friend, I kept a backup of the same device, and now that I need it, All my file is encrypted with virus ransomware, but I still have the file, but it is encrypted
          • Murtaza527
            • May 2018
            • 257
            • Malaysia
            just rename your file cut all the content after BIN then u can use again this file.
            if the file size same then it should work
            • Sami Wahid
              • Oct 2015
              • 77
              • Morocco
              My brother, I tried this solution before I put the topic in the forum, but to no avail.
              The file algorithm has changed completely.
              Thank you.
              • bachir2004
                • Feb 2015
                • 437
                • maroc
                Have you tried any of the kaspersky utilities.
                • Sami Wahid
                  • Oct 2015
                  • 77
                  • Morocco
                  Yes my friend but no result
                  • ruipnt2
                    • Nov 2012
                    • 5
                    • Portugal
                    try..
                    worked for me. thanks
                    • salawayon
                      • Nov 2012
                      • 568
                      • philippines
                      try..
                      i tried your file and it's working but i need to wait for almost 20seconds for the display to appear. could you clean the ME region? thanks...
                      • rielfreak
                        • Jul 2017
                        • 23
                        • Philippines
                        upload your backup.
                        • salawayon
                          • Nov 2012
                          • 568
                          • philippines
                          And with problem on NVIDIA chipset.. i can't install the driver... i attached my backup that if it's still fixable.. thanks.
                          • peste
                            • Dec 2016
                            • 12748
                            • ROMANIA
                            try..
                            • salawayon
                              • Nov 2012
                              • 568
                              • philippines
                              try..
                              Tried but it won't power up. you just cleaned my backup? my dump is somewhat a damage file.. maybe it needs to be repaired first. i compared it on your file that you previously posted. but your file had a delayed image on startup and i can't install the nvidia chipset driver.. thanks
                                • 20810
                                Post the silkscreened motherboard part number and revision, also post pictures of any barcode or QR code stickers on the motherboard
                                • peste
                                  • Dec 2016
                                  • 12748
                                  • ROMANIA
                                  try..
                                  • salawayon
                                    • Nov 2012
                                    • 568
                                    • philippines
                                    try..
                                    This one is working and the startup is now normal... i'll try if it fixes the nvidia driver issue.. thank you very much for your efforts...
                                    • salawayon
                                      • Nov 2012
                                      • 568
                                      • philippines
                                      try..
                                      with this file it can't detect HDD nor SSD nor M.2 SSD.
                                      • rbvndonh
                                        • Mar 2021
                                        • 162
                                        • B
                                        Guys, what effect of bad BIOS do you had on this board? No light, no switch on reaction or something?
                                        • razor_amd
                                          by razor_amd
                                          12-15-2020, 07:07 PM
                                        • grimacelord
                                          by grimacelord
                                          07-10-2025, 02:52 PM
                                        • throwaway327
                                          by throwaway327
                                          Model No: RC72LA
                                          Serial No: SBNVKD001014459
                                          06-18-2025, 05:52 PM
                                        • jbonavita
                                          by jbonavita
                                          Some issues
                                          Things I tried
                                          04-29-2025, 09:38 PM
                                        • lrouw84
                                          by lrouw84
                                          Hi there,
                                          01-28-2023, 01:31 PM
