Need ThinkPad Config Information Update v1.02 or Lenovo Maintenance Utility V2.02
  • kondou
    • Mar 2017
    • 9
    • japan
    I need ThinkPad Config Information Update Utility v1.02(or later) or Lenovo Maintenance Utility V2.02(or later).
    These software can write MEC1633 eeprom.
    X240,X250,T440,T450,etc... serial number can fix.
    I have serial invalid X1 Carbon 5th.
    I want repair it.
    This ThinkPad is MEC1653.
    I want try that.
    Thanks.
  • KvnTM
    • May 2018
    • 434
    Re: Need ThinkPad Config Information Update v1.02 or Lenovo Maintenance Utility V2.02
    I attached the hardware maintenance disk 1.9.. Later versions are unavailable..
    Maybe this works, give it a try!
    • kondou
      • Mar 2017
      • 9
      • japan
      Thanks.
      But can't write serial.
      EEPROM Overflow error.
      I need newer software.
      • KvnTM
        • May 2018
        • 434
        As i said.. Later versions are unavailable as far as i know.
        • kondou
          • Mar 2017
          • 9
          • japan
          I found Lenovo Maintenance Diskette v2.02 MD_2.02.zip in VLab(Russian repair forum).
          But I can't download.
          I don't know fake or true.
          • KvnTM
            • May 2018
            • 434
            Mostly all of these Russian forums are pay sites. They want their users to pay for downloads... vlab is no exception. Could be legit but i won't trust it to be honest.
            I don't recommend supporting them by giving them money. Knowledge should be free to access and charging money for some companies intellectual property is a fraud. Plus these tools are intended for service people who work for the company and aren't public. Thats why it is so hard to get them.
            I'll look around if I find something and let you know...
            • kondou
              • Mar 2017
              • 9
              • japan
              I learned a lot today. Thanks so much.
              • poolo
                • Oct 2014
                https://download.lenovo.com/pccbbs/mobiles/n1ctm02w.zip
                from: https://www.reddit.com/r/thinkpad/co..._189_download/
                Note: VLab doesn't charge except for schematics. Just upload 5 bios dumps or something else of interest in the appropriate sub-forum and you can download whatever you want besides the schematics.
                • DanielR76
                  • Apr 2022
                  Can i use this tool for a L590?Unfortunately, the software does not start from the stick.
                  • coolshrimp
                    • Nov 2016
                    • 54
                    Did you ever figure this out?
                    I tried both tools on my T14s and I get same error *EEPROM Overflow
                    Any solution? Also what about clearing a preset OA3.cfg how can I clear it.
                    • coolshrimp
                      • Nov 2016
                      • 54
                      I fixed the issue for the *EEPROM Overflow and not being able to write C0.
                      To set the Serial Number, Model on my Lenovo T14s:
                      I Used "ThinkPad Config Information Update Utility v1.11" attached
                      -Extract and run "usbfmtpw.exe" this will format your USB and copy the files over.
                      (check that the files copied after format. if not manually copy them to the root of the usb).
                      -Insert to laptop and boot to USB FDD it is EFI not Legacy (USB you just created).
                      -Now go 1, then use 2 to read current keys. record any keys shown, take a photo of them they will be erased if there not already.
                      -Now go back to main menu and choose initialize EEPROM, this clears all keys plus UUID and now the overflow error wont happen.
                      -Now go 1, then use 1 again to add new info, enter C0 then Enter.
                      -Now enter serial and model in long form will start with 1S so (1STTTTMMMMCCSSSSSSS)
                      -Enter and Key is stored.
                      -If you like can add more or go back and use option 3 for a few more config details. (I set my brand name there)
                      -Once all info is set go to assign UUID, and say Yes.
                      (once you generate the UUID you cannot edit the serials unless you initialize and do them all over again.
                      -Reboot and check bios screen your info should be there no more beeps on boot.
                      Product ID: TTTT-MMMMCC
                      Serial#: SS-SSSSS
                      TTTT = Machine Type
                      MMMM = Model Type
                      CC = Country Code
                      SSSSSSS = Serial Number
                      • aowc02
                        • Nov 2022
                        • United Kingdom
                        Hello, hope all is well with you all,
                        I am unable to get the Product Name correct.
                        C0 and B0 are registered and working fine. but I cant get the Product Name.
                        I have entered the Brand Name, T14s Gen 2 - but i keep seeing 2202: Product Name Invalid on load up.
                        any help would be most appreciated.
                        best,
                        A
                        • coolshrimp
                          • Nov 2016
                          • 54
                          best,
                          A
                          I had same issue, from main menu I think it' option 3, set product name.
                          Name should be “Lenovo ThinkPad T14s Gen 2” or “ThinkPad T14s Gen 2”.
                          The tool I think automatically adds the first “thinkpad” part when entering the name of you let it.
                          • G_Thing
                            • Mar 2023
                            • Israel
                            Work Like a charm on E490 :-)
                            • feherhollo
                              • Nov 2019
                              • 110
                              • Hungary
                              How can you remove or edit OA3.cfg?
                              • babydoll8867
                                • Nov 2014
                                • 96
                                • romania
                                Hi, i have a similar situation with T14 Gen 2, no matter what i do i get the product name error. I have written both serial numbers and brand name.... all seems ok but keep getting the error
                                • hpboy
                                  • Jan 2021
                                  • 53
                                  Did you manage to solve this - I have the same issue!! After changing the serial number I now have 2022 - Product Name Error
                                  • hpboy
                                    • Jan 2021
                                    • 53
                                    Originally posted by hpboy
                                    Did you manage to solve this - I have the same issue!! After changing the serial number I now have 2202 - Product Name Error
                                    I have now fixed this - If anyone else has the 2202 Product Name error, use the Gold Key to reprogramme
                                    (Gold Key listed here - https://www.badcaps.net/forum/showthread.php?t=103526)
                                    • jamer
                                      • Jul 2021
                                      • 7
                                      • philippines
                                      Hello Guys. I need Lenovo Ideapad Config Information update
                                      • andrew25
                                        • Feb 2016
                                        • 224
                                        • Malawi
                                        Serial#: SS-SSSSS
                                        TTTT = Machine Type
                                        MMMM = Model Type
                                        CC = Country Code
                                        This is straight forward instructions, thanks alot... i had a problem with t480 without serial number and model name... thanks bro
                                        • DynaxSC
                                          ASROCK Z270 GAMING-ITX/AC - IR35201 - NEED THE VRM CONFIG FILES
                                          by DynaxSC
                                          I have an ASROCK Z270 GAMING-ITX/AC motherboard with a fried VCORE controller IR35201 (International Rectifier, currently Infineon).
                                          This chip is unfortunately programmable, so after replacing the chip, it needs to be programmed with a config file, which I do not have, as the chips is not readable any more (total short on power supply pin).
                                          Some of you maybe know, it is possible to read out the config file from a board with a working chip using the USB005 I2C adapter and IR/Infineon software called PowIRCenter. The software is available freely at Infinion...
                                          02-10-2025, 04:52 PM
                                        • brandon.bragg
                                          Full ThinkPad Maintenance Utilities / Golden Key for P15 Gen 1
                                          by brandon.bragg
                                          I’m working on a Lenovo ThinkPad P15 Gen 1 (Machine Type 20ST-004DUS), and recently replaced the motherboard (planar).
                                          I successfully booted into the Golden Key U1 Tool (v3.5.78), and it launches ThinkPad Maintenance Utilities v1.20(x64) — but my version appears to be missing the full Set System Identification menu (it only shows Add/Read/Delete S/N options).
                                          Here’s what I’ve already done:
                                          • The EEPROM has been initialized successfully
                                          • The U1 tool loads and detects the ThinkPad fine
                                          • The current MTM/SN/UUID fields are blank
                                          • When trying to enter
                                          10-31-2025, 04:32 PM
                                        • bseinfo
                                          Brother MFC-J480DW printer stuck in maintenance mode
                                          by bseinfo
                                          I have a Brother MFC-J480DW printer stuck in maintenance mode (BHL2 USB Maintenance). The screen only shows white bars, and it’s completely unresponsive. The official Firmware Update Tool doesn’t detect it, and I’ve tried multiple versions.
                                          I’m looking for the raw firmware file LZ5313_L.blf (or .djf), compatible with FILEDG32.exe, so I can attempt a manual recovery.
                                          If anyone has a full dump of this model (or a compatible one like MFC-J485DW or J885DW), or knows a private Discord or Telegram group where this kind of firmware is shared,...
                                          07-05-2025, 10:53 AM
                                        • ibo
                                          Lenovo Thinkpad T580 Maintenance Utility
                                          by ibo
                                          I need maintenance utility for T580 to write serial number,
                                          can somebody share this?
                                          04-24-2020, 03:55 PM
                                        • x16
                                          Help with Thinkpad Maintenace Utility on T590
                                          by x16
                                          i unlocked my T590 with SVOD4 and wrote new ec from lenovo site. Now password is gone but dmi is missing now. So i have to write it back with Thinkpad Maintenace Utility.
                                          I now have newest version of lenovo U1 golden key software (3.5.52) for USB boot stick. This tool starts the Thinkpad Maintenace Utility V1.20.
                                          But i can't initialize eeprom. It says: "ERROR: Written data is unmatch."
                                          So i can't write sn number without initializing it first.
                                          Any ideas?
                                          12-02-2023, 11:41 AM
