Need ThinkPad Config Information Update v1.02 or Lenovo Maintenance Utility V2.02
  • tuxstevo
    • Oct 2024
    • 14
    Thanks for posting the utility Coolshrimp. Just used it to set the ID on a new motherboard for a P53 and it worked perfectly.
    • DynaxSC
      ASROCK Z270 GAMING-ITX/AC - IR35201 - NEED THE VRM CONFIG FILES
      by DynaxSC
      I have an ASROCK Z270 GAMING-ITX/AC motherboard with a fried VCORE controller IR35201 (International Rectifier, currently Infineon).
      This chip is unfortunately programmable, so after replacing the chip, it needs to be programmed with a config file, which I do not have, as the chips is not readable any more (total short on power supply pin).
      Some of you maybe know, it is possible to read out the config file from a board with a working chip using the USB005 I2C adapter and IR/Infineon software called PowIRCenter. The software is available freely at Infinion...
      02-10-2025, 04:52 PM
    • brandon.bragg
      Full ThinkPad Maintenance Utilities / Golden Key for P15 Gen 1
      by brandon.bragg
      I’m working on a Lenovo ThinkPad P15 Gen 1 (Machine Type 20ST-004DUS), and recently replaced the motherboard (planar).
      I successfully booted into the Golden Key U1 Tool (v3.5.78), and it launches ThinkPad Maintenance Utilities v1.20(x64) — but my version appears to be missing the full Set System Identification menu (it only shows Add/Read/Delete S/N options).
      Here’s what I’ve already done:
      • The EEPROM has been initialized successfully
      • The U1 tool loads and detects the ThinkPad fine
      • The current MTM/SN/UUID fields are blank
      • When trying to enter
      10-31-2025, 04:32 PM
    • bseinfo
      Brother MFC-J480DW printer stuck in maintenance mode
      by bseinfo
      I have a Brother MFC-J480DW printer stuck in maintenance mode (BHL2 USB Maintenance). The screen only shows white bars, and it’s completely unresponsive. The official Firmware Update Tool doesn’t detect it, and I’ve tried multiple versions.
      I’m looking for the raw firmware file LZ5313_L.blf (or .djf), compatible with FILEDG32.exe, so I can attempt a manual recovery.
      If anyone has a full dump of this model (or a compatible one like MFC-J485DW or J885DW), or knows a private Discord or Telegram group where this kind of firmware is shared,...
      07-05-2025, 10:53 AM
    • ibo
      Lenovo Thinkpad T580 Maintenance Utility
      by ibo
      I need maintenance utility for T580 to write serial number,
      can somebody share this?
      04-24-2020, 03:55 PM
    • x16
      Help with Thinkpad Maintenace Utility on T590
      by x16
      i unlocked my T590 with SVOD4 and wrote new ec from lenovo site. Now password is gone but dmi is missing now. So i have to write it back with Thinkpad Maintenace Utility.
      I now have newest version of lenovo U1 golden key software (3.5.52) for USB boot stick. This tool starts the Thinkpad Maintenace Utility V1.20.
      But i can't initialize eeprom. It says: "ERROR: Written data is unmatch."
      So i can't write sn number without initializing it first.
      Any ideas?
      12-02-2023, 11:41 AM
