EFIBIN File MacBook Air A1466 (EMC 2632) 820-3437-B
  • dennis akumu
    • Mar 2018
    • 113
    • kenya
    #141
    Re: EFIBIN File MacBook Air A1466 (EMC 2632) 820-3437-B
    Macbook air model A1466 emc 2632.s/n# C17N34DTG085
    ISSUE IS DELAYED DISPLAY (45SEC). THEN TAKES LONG TO BOOT
    ATTACHED IS THE ORIGINAL FILE.
    HELP ME WITH A CLEAN ME FILE PLEASE.
    • peste
      • 13619
      • ROMANIA
      #142
      try..
      • ranzoo
        • Jun 2015
        • 17
        • algeria
        #143
        Re: MacBook Air A1466 (EMC 2632)
        Originally posted by ranzoo
        help plz i recieved macbook air with appel logo in screen and power off , serial : C1MSN7QDH3QD
        i need good dump pls thx
        Macbook air model A1466 emc 2925.s/n# C1MSN7QDH3QD
        ISSUE IS DELAYED DISPLAY . THEN TAKES LONG TO BOOT and power off
        sorry for bad english
        • dennis akumu
          • Mar 2018
          • 113
          • kenya
          #144
          Originally posted by peste
          try..
          working
          • reformatt
            • Feb 2020
            • 1507
            Upload for @ACS-Repair
            • RichBon
              • Apr 2019
              • 54
              • Ghana
              #146
              try..
              please these my bios contain lock please can these be unlock for me. a1466 820-3437 b
              serial number C02KX1GSFMRL. EMC 2632
              • MuertoGB
                • Sep 2021
                • 94
                #147
                EFI lock invalidated, VSS cleaned. Try this and write back.
                • ibro99beck
                  • Aug 2018
                  • 7
                  • Nigeria
                  #148
                  the posted bios is not ok ... try this ..
                  Work perfectly for 2 different macbook A1466 i just programmed
                  • mnciks11
                    • Aug 2019
                    • 345
                    • south Africa
                    #149
                    Hello Guys
                    I have a macbook air A1466 with a faulty bios, can someone please assist cleaning the file for me, my bios clean up does not work, below i will post my backup.
                  • navigatore58
                    • May 2024
                    • 7
                    • italy
                    #150
                    Good morning.
                    I need help. My old mac book air model A1466 EMC 2632 serial C02M6TLEF5V7 is password locked on the firmware. I tried to make some attempts with the ch341a programmer but, not being an expert, I can't solve it. The programmer tells me that the chip is a 25 spi flash winbond w25q64fv. I didn't understand how to remove psw. I worked on the disassembled board. How do I know if it's ok?
                    Thanks for your help. I managed to save a copy of the bin file but the post won't let me load it with a bin extension.​
                      SMDFlea commented
                      Editing a comment
                      post it in a zip or rar
                  • navigatore58
                    • May 2024
                    • 7
                    • italy
                    #151
                    I apologize if I repeat the post but I'm not very expert in the forum rules
                    Good morning.
                    I need help. My old mac book air model A1466 EMC 2632 820-3437 serial C02M6TLEF5V7 is password locked on the firmware. I tried to make some attempts with the ch341a programmer but, not being an expert, I can't solve it. The programmer tells me that the chip is a 25 spi flash winbond w25q64fv. I didn't understand how to remove psw. I worked on the disassembled board. How do I know if it's ok?
                    Thanks for your help. I managed to save a copy of the bin file,but I'm not sure what I did.
                    In any case, would it be possible to have a new firmware with serial insertion?​
                    • peste
                      • 13619
                      • ROMANIA
                      #152
                      Good morning.
                      try..
                      • navigatore58
                        • May 2024
                        • 7
                        • italy
                        #153
                        Thank you. I'll try as soon as possible because my ch341a programmer clamp no longer works and I've ordered another one.
                        • peste
                          • 13619
                          • ROMANIA
                          #154
                          don't use the clamp... remove the bios chip from the board before writing or reading, or stick wires between the chip and the programmer..
                          • navigatore58
                            • May 2024
                            • 7
                            • italy
                            #155
                            Thank you for your trust but it's the first time I've done a job like this and pliers seemed like the simplest solution also because I wouldn't know how to remove chips. However, I discovered by taking a photo of the motherboard that the chip is the one in the photo I attach, therefore not a Windbond but by searching online it looks like a Micron. Does the bin file change in this case?
                            • peste
                              • 13619
                              • ROMANIA
                              #156
                              here is a video as a model.. this chip is removed, put in an adapter and then in the programmer.. you can find an adapter for this chip on the internet..
                              https://www.youtube.com/watch?v=DWWigscuQDY
                              • navigatore58
                                • May 2024
                                • 7
                                • italy
                                #157
                                Thank you but I don't have the necessary dexterity to remove chips. As soon as I get the new caliper I'll try again to see if it recognizes the chip automatically.
                                • nesredin
                                  • Feb 2018
                                  • 39
                                  • ethiopia
                                  #158
                                  macbook air a1466 emc 2632 can someone unlock this file
                                • nesredin
                                  • Feb 2018
                                  • 39
                                  • ethiopia
                                  #159
                                  macbook air a1466 emc 2632. 820-3437-b. serial=C02M40LYF5V7
                                  • peste
                                    • 13619
                                    • ROMANIA
                                    #160
                                    try..
