EFIBIN File MacBook Air A1466 (EMC 2632) 820-3437-B
Re: EFIBIN File MacBook Air A1466 (EMC 2632) 820-3437-B
Hi, i got a macbook air a1466 emc 2632 its locked with Efi lock can somebody please help me, i will be very grateful. first attempt on a MacBook
RegardsAttached FilesComment
try..Attached FilesDue to a lack of donations, server free space at a critical level, and possible closure of Bios Requests all donations are welcome, click:
Every donation made will go towards server fees and maintenance costs.Comment
my a1466 has EFI password...please help me to removedAttached FilesComment
serial: C02N24W6G086Please watch this Video carefully, I learnt all from this video... Fsys & Checksum has to be corrected in order for the notebook to work. Or send me the Notebook serial # & the EMC # of your notebook, I will send you a good updated working file, Just you have to program it to the SPI BIOS & solder it.. Nothing else you have to do.
check this useful youtube video https://www.youtube.com/watch?v=poA8HByYqTM
emc: 2632
if you could do send me a good working file so i can program it to the spi i would really appreciate it.
can anny one clean my biosBr. LLCOOLRComment
Here you are----------------------------------------------------------------------------------------------------------------------------------------------------------
Become a Badcaps supporter
Thanks to all supporters.​
----------------------------------------------------------------------------------------------------------------------------------------------------------Doctrina est fructus dulcis, radicis amarae..Comment
Sorry i know this is an old topic...
I'm trying to edit this efi firmware, but I'm facing some problems. I was able to edit SN and the last 4 digits, but I can't find Fsys checksum part, to correct.
The logic board version, is the same of this topic.
The problem: if i let the macbook rest for about 10/15*min, when I try to boot, the fan spins only 1/4 and stops. I press again the power and the fan spins normally, but there is no boot, neither image. So I have to shut down, and when i press the power button again, it boots normally.
Best regards!Comment
09 27 A7 C3 ,open the bios with UEFITool it will tell you what the checksum should be
https://www.badcaps.net/forum/showpo...43&postcount=5
4.3. Apple
For 2017 and older machines, serial number is stored in Fsys store of BIOS and can be edited with hexadecimal editor. Fsys checksum needs to be fixed afterwards
Search for "ssn", edit the serial number, save, open dump in UEFITool, go to the Fsys store and write down the suggested checksum in the panel on the right. Checksum is 4 bytes at the end of the Fsys store, between one zone of 0x00 either Gaid or another zone of 0xFF, it must be written in reverse order (so last 2 characters from UEFITool must be written first).
See: https://www.youtube.com/watch?v=poA8HByYqTMComment
Thank's for the quick reply.09 27 A7 C3 ,open the bios with UEFITool it will tell you what the checksum should be
4.3. Apple
Yes, i'm following exactly that video. With UEFITool, i was able to find the checksum. What a can't find, is the part on bin file "Gaid". Like the tutorial video, on min 5:55. It appears like i send in the last picture.Comment
Listen carefully to the video from 6 minutes,piernov explains that newer bios versions have no gaid string. Watch the next part at 7:20Comment
Hi! I have a problem with an 820-3437 card. I bought from China. She has outdated bios and I don't have the serial. Because I installed a new version and forgot to save the original firmware. I'm a beginner and I made this mistake.
I have the board that works. But I don't have her original serial. Do you have a solution to my problem?Comment
post the original bios and S / N on the case.Hi! I have a problem with an 820-3437 card. I bought from China. She has outdated bios and I don't have the serial. Because I installed a new version and forgot to save the original firmware. I'm a beginner and I made this mistake.
I have the board that works. But I don't have her original serial. Do you have a solution to my problem?Due to a lack of donations, server free space at a critical level, and possible closure of Bios Requests all donations are welcome, click:
The problem is that I don't have the original firmware. As I said before.
I writed over. There was my mistake. That's why I don't have the serial number for the board. I have a firmware that turns on but starts very slow.Comment
peste asked you for the serial number on the case (the metal base,there`s a serial number on it),do you have the full laptop or only the motherboardsComment
by psdavid65I received a 2013 Macbook Air A1466 820-3437-B motherboard with serial number C02L6GQ9FSV8 that came in WITHOUT a bios chip. I got a new bios chip and reprogrammed it. Macbook now powers on but doesn't boot the SSD. I've flashed a ton of bios but still same problem. Windows installation works with this Macbook but never a mac installation. Unfortunately, since I didn't receive this macbook with a bios chip, I don't have the original bios. What can I do now?...
by m1ch43lzmHi everyone
There's also an extra OTP Secu.R...-
Channel: BIOS Requests ONLY!
by echothegamerHello all,
Working on my wife's 13' Macbook air. It's been in a box since she upgraded but I figured it could be good practice.
Details:
Macbook 13' A1466
Board (820-3209-A)
Battery OEM 7.3v 50Wh 6700 mAh (020-7379-A)
Pictures below of Boardview and schematic...
I don't know how to test the voltage on a MacBook battery. I just assumed it had an enable pin but the best I could read was 300 something mV poking around the battery connector.
It's an older model and it is very likely that battery has become... -
by kenzo2I need dump file for nand A2159 512GB with 2 Nand chips >.I upgraded 128gb to 512gb..I use P13 there are only 4Chips...
I need dump file MACBOOK PRO A2159
TSB4232(256)
TSB4229(256)
Thanks​ -
by dbuergiHi all,
i got a A1466 with serious water damage. I was able to clean the whole board and only found a fuse with a coroded trace. Cleaning and resoldering did the job and the macbook started normal but after some time the screen began "flashing" like turning on and off while the Macbook was still running. I checked the board again but was not able to find the problem until now.
Any ideas where to look?... - Loading...
