Hp probook 640 g1 bios
  • cygron
    replied
    HP Probook 640 G1 BIOS Need
    Model: HP Probook 640 G1
    Board id: 6050A2566402 MB A03
    Serial: 5CG4340VDB
    PCID: A3009DD10303
    Product: D9R52AV
    Need bios. Please help.
  • profiler
    replied
    Re: Hp probook 640 g1 bios
    Maybe this is not a problem with the BIOS? A year ago I got this notebook and it had the problem described here. After cleaning the ME region, it suddenly works again. But after a few months it stopped working and the same problem like now appears. I had no time to fix it and leave it in this state until now. I resoldered my cable to the flash chip and readout and flashing incl. verifying works. So I tried the same procedure like that time but now I can't get it working again. Are there any other reason why caps lock is blinking 5 times followed by high speed CPU fan? I have read that this is happening when the embedded controller does not get the BIOS POST message within a certain time. So does this mean that it can't have anything to do with some power rails? The flash chip is getting 3.3V at VCC.
  • profiler
    replied
    Re: HELP BIOS HP 640 G1 corrupt
    Originally posted by rex98
    Use this it works i already tested.
    Hi rex98, thank you for the answer. I tried your BIOS, but the behavior keeps the same.
  • rex98
    replied
    Originally posted by profiler
    I have exact the same problem. I tried to replace the ME Region.bin and reflash the modified outimage, but it does not change anything.
    Mainboard: 6050A2566302-MB-A03
    Extracted BIOS and board images are attached.
    Thanks for help!
  • profiler
    replied
    Originally posted by Vesko356
    You must post the serial number.
    Read the rules before posting:
    Sorry, here is the serial: 5CG4384S7M
  • Vesko356
    replied
    Thanks for help!
  • profiler
    replied
    Originally posted by FP1975
    Good evening,
    my problem is the following: the screen stays black, the pc launches, I have flashes on the caps key (5) and the fan is running at full speed. I'm thinking a corrupted bios. Here is the extracted bios.
    Thank you in advance for your help.
    Thanks for help!
  • PacoGT
    replied
    Re: Hp probook 640 g1 uma
    Originally posted by peste
    try..
    Hello, I have problems with my bios, it only turns on the power led and it goes off quickly like a flash, I tried other bioses but it tries to turn on and nothing, I check my board and I thought if someone can repair my bios, I leave the backup here in case they can repair it, thanks
  • bembeno
    replied
    need help to repair this Hp 640 G1 bios file
    replied
    Originally posted by dachamcse
    I need reset password please, here is the file
    Read post #225
  • dachamcse
    replied
  • qayyum786
    replied
    Re: need to 6050a2566402-mb-a02 bios. thanks
    my bios.
    https://www.badcaps.net/forum/showth...2566402&page=4
    TRY FROM POST #61
  • yomal66
    replied
    my bios.
  • volinakis
    replied
    For this second file, nothing happens. The pc does not start. Here is some info from the pc:
    motherboard 6050A2566302-MB-A02
    I5 4300u
    SN: CNU41391D7
    SKU: D9R55AV
    CT: PEBHU001X6H192
    Thanks in advance
    try this bios and if it works then write DMI with BCU or wndmifit
    https://www.badcaps.net/forum/showpo...2&postcount=11
  • FP1975
    replied
    Originally posted by volinakis
    try
    I5 4300u
    SN: CNU41391D7
    SKU: D9R55AV
    CT: PEBHU001X6H192
    Thanks in advance
  • volinakis
    replied
    Hello, thank you for the file but:
    - the pc starts, black screen
    - 3 beeps (5 before)
    -fans running at full speed
    The problem is still here...
    Thanks in advance for the help
    try
  • FP1975
    replied
    try this
  • volinakis
    replied
    Good evening,
    try this
  • FP1975
    replied
    Good evening,
  • Discrete47
    replied
  • zenius
    by zenius
    12-08-2024, 06:13 AM
  • traxformania
    TONGFANG "GM7TG7P" Bios Password Problem?
    by traxformania
    I tried :
    -I removed the BIOS battery and main battery. Waited for a long time but it didn't work. They already stated in the user manual that the password will not be reset even if the batteries...
    11-15-2023, 07:32 AM
  • tlindi
    Toughbook CF-18KHH65LE (Customer Special Configuration) Supervisor Password needed remove HDD locking and BIOS Access ...
    by tlindi
    Sublect line continuation: ... Jaguar IDS PC aka Panasonic
    Ack
    Ack
    01-30-2025, 04:26 AM
  • Soumana Sanou
    ā€œHP ProBook 11 G2 BIOS password reset request – Need SMC.bin
    by Soumana Sanou
    Hello,šŸ˜‡šŸ˜‡šŸ˜‡
    I need help unlocking the BIOS password on my HP ProBook 11 G2 laptop.
    šŸ”§ Model: HP ProBook 11 G2
    šŸ“¦ Serial Number: 8CG72478MY
    šŸ†” UUID: 6F5ED686-5532-11E7-A2E2-911C6404E011
    šŸ”’ BIOS Status: Locked with password
    The laptop is no longer under warranty and HP refused to help me.
    I’m looking for a custom SMC.bin file.
    I don't have a CH341A programmer, so it's difficult for me to provide a BIOS file.
    Thanks a lot for your help!šŸ™šŸ™šŸ™...
    06-17-2025, 04:04 PM
  • Nopslide
    by Nopslide
    04-01-2024, 04:27 PM
