Asus X510UNR
  • asem18
    • Oct 2016
    • 112
    • my workshop
    Asus X510UNR
    Please Bios for Asus X510UNR Rev 3.0..thank you
    • 21692
    Re: Asus X510UNR
    Post your bios backup here .
    • AK LAPTOP
      • Aug 2017
      • india
      Re: Asus X510UNR
      here its working bios
      • AK LAPTOP
        • Aug 2017
        • india
        Re: Asus X510UNR
        here its working bios Asus s x510
        • lecong1986
          • Mar 2017
          • 19
          • vietnam
          Re: Asus X510UNR
          why file only 5.824mb
          • abbassink
            • Aug 2015
            • 83
            • iran
            Re: Asus X510UNR
            tested 100% ok
            • technician37
              • Aug 2018
              • 30
              • philippines
              Re: Asus X510UNR
              Originally posted by abbassink
              tested 100% ok
              thankyou
              • honglongyb
                • Jul 2015
                • 12
                • viet nam
                who can clear ME for me - X510UNR
                this dump more than 30 second to display asus logo. thank alot
                • peste
                  • 13451
                  • ROMANIA
                  Re: who can clear ME for me
                  try..
                  • honglongyb
                    • Jul 2015
                    • 12
                    • viet nam
                    Originally posted by peste
                    try..
                    thanks it done
                    • mferna14
                      • Jun 2018
                      • 1046
                      Re: ASUS X510U (MB X510UNR Rev: 3.0) not display at all
                      Ok, attached is the ORIGINAL BIOS de-soldered BIOS Chip from the motherboard Any help will be greatly appreciated. Thanks
                      • peste
                        • 13451
                        • ROMANIA
                        Originally posted by mferna14
                        ok, attached is the original bios de-soldered bios chip from the motherboard any help will be greatly appreciated. Thanks
                        try..
                        • mferna14
                          • Jun 2018
                          • 1046
                          try..
                          With this BIOS update the motherboard turns on, I can see the Keyboard Power LED lit, but the amps on the ampmeter is stuck to 0.03, no movement at all & CPU is cold., With my previous BIOS file it would take around .40 ~ .20 amps up & down fluctating & the CPU used to get warm & then fan turned on. I think that the re-build BIOS is not updated well.
                            • 21692
                            Post a good clear picture of the white sticker on the ram slot .
                            • mferna14
                              • Jun 2018
                              • 1046
                              Re: Asus X510UNR
                              There is NO Sticker on under the memory or on the memory slot. Please check this photos, might help in getting the correct BIOS. Thanks for the cooperation.
                                • 21692
                                Re: Asus X510UNR
                                If the bios hasn`t been flashed or updated with the wrong one then the bios posted by @peste should be ok.Try this one anyway .
                                  • 21692
                                  Re: Asus X510UNR
                                  If you post the serial number one of the members who works for asus service might post an F1 engineering bios
                                  • mferna14
                                    • Jun 2018
                                    • 1046
                                    Re: Asus X510UNR
                                    This is the correct Serial # at the back of the Laptop... Thanks for all the help
                                    S. No: JBN0CX00T610447
                                    • mferna14
                                      • Jun 2018
                                      • 1046
                                      Re: Asus X510UNR
                                      Thanks "SMDFlea" I really appreciate your help. Now with the BIOS file you send me, all came back to normal, I see the fan running, CPU getting warm & the motherboard taking 0.40 amp which I think is right, but still no display. I can clearly view that the backlight turns on & off & it goes throught the initial septup process like all ASUS do, but I cannot get the image on the screen., Even with the External monitor NO Display. I am assuming still it's the BIOS issue as I can even measure that all voltages are present on the motherboard to turn on. Thank in advance.
                                      • mferna14
                                        • Jun 2018
                                        • 1046
                                        Re: Asus X510UNR
                                        Is someone there to update this BIOS for me??? The notebook is not giving any display.. Other than this notebook turns on fine & I notice LCD backlight turns on. Thanks
                                        • razor_amd
                                          by razor_amd
                                          12-15-2020, 07:07 PM
                                        • grimacelord
                                          by grimacelord
                                          07-10-2025, 02:52 PM
                                        • rayshine03121408
                                          I Need Working BIOS for ASUS E410MA R7.1
                                          by rayshine03121408
                                          Good Day Masters! Anyone have working bios for ASUS E410MA? i tried reading the BIOS Chip and the programmer cant detect it i think the bios chip is dead... i already tried 2 programmer but same still cant detect the chip. Thanks in Advance
                                          Model: ASUS E410MA-TB.CL464BK
                                          SN: N8N0CX06E199324
                                          BoardModel: E410MA R7.1
                                          08-26-2025, 05:36 AM
                                        • fauxkalel
                                          ASUS Vivobook P1504F X512FA (MB X512FF) Working BIOS with DMI/SN
                                          by fauxkalel
                                          MB X512FF rev. 2.2
                                          i have laptop which during BIOS Update from Windows Update in some way broke dump -not working sound, Intel OED code 10 ("fw did not send fw ready notification").
                                          I need clean dump with inserted SN and other DMI data from my BIOS and sticker. Not sure if Win key is in BIOS.
                                          Is there way to build BIOS from update file? I tried extract it in many ways and find paterns from original dump but i think its not so easy like some time ago.. xD
                                          SN: L1NXCV10B90903C...
                                          10-29-2024, 03:34 AM
                                        • ferah831208
                                          help with bios decompose for Asus s5506ma
                                          by ferah831208
                                          I have an Asus s5506ma that was bricked after a Windows update supposedly when it was updating bios. It seems to be a meteorlake Intel CPU core ultra, I cannot find too much info regarding this hardware, anyone have info about if it contains Intel ME engine and if there is any tool for disassemble spi image like we do with all CSME or TXE versions using the appropriate Intel ME tool? The problem is original bios file Asus provides, has bios guard protection, I downloaded the latest update for Ami_pfat_extractor from plomatov (previous versions of AMI bios guard extractor doesn't work),with that...
                                          08-24-2025, 05:35 PM
