Asus X510UNR
  • asem18
    • Oct 2016
    • 112
    • my workshop
    Asus X510UNR
    Please Bios for Asus X510UNR Rev 3.0..thank you
    • 22191
    Re: Asus X510UNR
    Post your bios backup here .
    • AK LAPTOP
      • Aug 2017
      • 3
      • india
      Re: Asus X510UNR
      here its working bios
      • AK LAPTOP
        • Aug 2017
        • 3
        • india
        Re: Asus X510UNR
        here its working bios Asus s x510
        • lecong1986
          • Mar 2017
          • 19
          • vietnam
          Re: Asus X510UNR
          why file only 5.824mb
          • abbassink
            • Aug 2015
            • 83
            • iran
            Re: Asus X510UNR
            tested 100% ok
            • technician37
              • Aug 2018
              • 30
              • philippines
              Re: Asus X510UNR
              Originally posted by abbassink
              tested 100% ok
              thankyou
              • honglongyb
                • Jul 2015
                • 12
                • viet nam
                who can clear ME for me - X510UNR
                this dump more than 30 second to display asus logo. thank alot
                • peste
                  • Dec 2016
                  • 13853
                  • ROMANIA
                  Re: who can clear ME for me
                  try..
                  • honglongyb
                    • Jul 2015
                    • 12
                    • viet nam
                    Originally posted by peste
                    try..
                    thanks it done
                    • mferna14
                      • Jun 2018
                      • 1048
                      Re: ASUS X510U (MB X510UNR Rev: 3.0) not display at all
                      Ok, attached is the ORIGINAL BIOS de-soldered BIOS Chip from the motherboard Any help will be greatly appreciated. Thanks
                      • peste
                        • Dec 2016
                        • 13853
                        • ROMANIA
                        Originally posted by mferna14
                        ok, attached is the original bios de-soldered bios chip from the motherboard any help will be greatly appreciated. Thanks
                        try..
                        • mferna14
                          • Jun 2018
                          • 1048
                          try..
                          With this BIOS update the motherboard turns on, I can see the Keyboard Power LED lit, but the amps on the ampmeter is stuck to 0.03, no movement at all & CPU is cold., With my previous BIOS file it would take around .40 ~ .20 amps up & down fluctating & the CPU used to get warm & then fan turned on. I think that the re-build BIOS is not updated well.
                            • 22191
                            Post a good clear picture of the white sticker on the ram slot .
                            • mferna14
                              • Jun 2018
                              • 1048
                              Re: Asus X510UNR
                              There is NO Sticker on under the memory or on the memory slot. Please check this photos, might help in getting the correct BIOS. Thanks for the cooperation.
                                • 22191
                                Re: Asus X510UNR
                                If the bios hasn`t been flashed or updated with the wrong one then the bios posted by @peste should be ok.Try this one anyway .
                                  • 22191
                                  Re: Asus X510UNR
                                  If you post the serial number one of the members who works for asus service might post an F1 engineering bios
                                  • mferna14
                                    • Jun 2018
                                    • 1048
                                    Re: Asus X510UNR
                                    This is the correct Serial # at the back of the Laptop... Thanks for all the help
                                    S. No: JBN0CX00T610447
                                    • mferna14
                                      • Jun 2018
                                      • 1048
                                      Re: Asus X510UNR
                                      Thanks "SMDFlea" I really appreciate your help. Now with the BIOS file you send me, all came back to normal, I see the fan running, CPU getting warm & the motherboard taking 0.40 amp which I think is right, but still no display. I can clearly view that the backlight turns on & off & it goes throught the initial septup process like all ASUS do, but I cannot get the image on the screen., Even with the External monitor NO Display. I am assuming still it's the BIOS issue as I can even measure that all voltages are present on the motherboard to turn on. Thank in advance.
                                      • mferna14
                                        • Jun 2018
                                        • 1048
                                        Re: Asus X510UNR
                                        Is someone there to update this BIOS for me??? The notebook is not giving any display.. Other than this notebook turns on fine & I notice LCD backlight turns on. Thanks
                                        • razor_amd
                                          by razor_amd
                                          12-15-2020, 07:07 PM
                                        • grimacelord
                                          by grimacelord
                                          07-10-2025, 02:52 PM
                                        • TyMercer
                                          Can I flash a working BIOS from one computer to another of the same make, model, etc?
                                          by TyMercer
                                          Apologies if this is the wrong forum, but I'm not looking for a specific BIOS file, I'm trying to understand how one makes a clean BIOS file. So here's the background. I have 2 HP EliteDesk 800 g2 mini 35w pcs. One is working fine; the other doesn't have display out or working USB's nor does it have any flashing error lights. The CPU does get worm enough to cause the fan to spin up, so I think it's posting, but I just don't know. I had it working at one point but trouble started when I tried to put in a drive caddy that had a cooling fan on it. I thought it would be compatible but wasn't...
                                          11-13-2025, 09:39 PM
                                        • rayshine03121408
                                          I Need Working BIOS for ASUS E410MA R7.1
                                          by rayshine03121408
                                          Good Day Masters! Anyone have working bios for ASUS E410MA? i tried reading the BIOS Chip and the programmer cant detect it i think the bios chip is dead... i already tried 2 programmer but same still cant detect the chip. Thanks in Advance
                                          Model: ASUS E410MA-TB.CL464BK
                                          SN: N8N0CX06E199324
                                          BoardModel: E410MA R7.1
                                          08-26-2025, 05:36 AM
                                        • oussamahasnaoui
                                          i need working bios for Asus x71SL
                                          by oussamahasnaoui
                                          i need working bios for Asus x71SL the laptop work but it freez when enter to bios...
                                          11-15-2025, 05:18 PM
