Please Bios for Asus X510UNR Rev 3.0..thank you
Asus X510UNR
Re: Asus X510UNR
Post your bios backup here . -
Re: Asus X510UNR
here its working bios Asus s x510Attached FilesComment
who can clear ME for me - X510UNR
this dump more than 30 second to display asus logo. thank alotAttached FilesLast edited by SMDFlea; 06-20-2021, 08:45 AM.Comment
Re: who can clear ME for me
try..Attached FilesDue to a lack of donations, server free space at a critical level, and possible closure of Bios Requests all donations are welcome, click:
Every donation made will go towards server fees and maintenance costs.Comment
Re: ASUS X510U (MB X510UNR Rev: 3.0) not display at all
Ok, attached is the ORIGINAL BIOS de-soldered BIOS Chip from the motherboard Any help will be greatly appreciated. ThanksAttached FilesLast edited by SMDFlea; 08-16-2021, 11:48 AM.Comment
With this BIOS update the motherboard turns on, I can see the Keyboard Power LED lit, but the amps on the ampmeter is stuck to 0.03, no movement at all & CPU is cold., With my previous BIOS file it would take around .40 ~ .20 amps up & down fluctating & the CPU used to get warm & then fan turned on. I think that the re-build BIOS is not updated well.Comment
Re: Asus X510UNR
Re: Asus X510UNR
If you post the serial number one of the members who works for asus service might post an F1 engineering biosComment
Re: Asus X510UNR
Thanks "SMDFlea" I really appreciate your help. Now with the BIOS file you send me, all came back to normal, I see the fan running, CPU getting warm & the motherboard taking 0.40 amp which I think is right, but still no display. I can clearly view that the backlight turns on & off & it goes throught the initial septup process like all ASUS do, but I cannot get the image on the screen., Even with the External monitor NO Display. I am assuming still it's the BIOS issue as I can even measure that all voltages are present on the motherboard to turn on. Thank in advance.Comment
Re: Asus X510UNR
Is someone there to update this BIOS for me??? The notebook is not giving any display.. Other than this notebook turns on fine & I notice LCD backlight turns on. ThanksComment
by razor_amdWith ASUS, not everything is quite so simple. I will show you my way. It may be longer or harder but it is the right way to do it in my humble opinion.
This is the picture of 3 similar ASUS motherboards, all of them being X555LD...-
Channel: BIOS Requests ONLY!
by grimacelordHello,
Anyway, I took dumps of both chips and then downloaded the latest update for this motherboard from ASUS's website...-
Good Day Masters! Anyone have working bios for ASUS E410MA? i tried reading the BIOS Chip and the programmer cant detect it i think the bios chip is dead... i already tried 2 programmer but same still cant detect the chip. Thanks in Advance
Model: ASUS E410MA-TB.CL464BK
SN: N8N0CX06E199324
BoardModel: E410MA R7.1-
by fauxkalelHello,
ASUS Vivobook P1504F X512FA
MB X512FF rev. 2.2
i have laptop which during BIOS Update from Windows Update in some way broke dump -not working sound, Intel OED code 10 ("fw did not send fw ready notification").
I need clean dump with inserted SN and other DMI data from my BIOS and sticker. Not sure if Win key is in BIOS.
Is there way to build BIOS from update file? I tried extract it in many ways and find paterns from original dump but i think its not so easy like some time ago.. xD
SN: L1NXCV10B90903C...-
by ferah831208I have an Asus s5506ma that was bricked after a Windows update supposedly when it was updating bios. It seems to be a meteorlake Intel CPU core ultra, I cannot find too much info regarding this hardware, anyone have info about if it contains Intel ME engine and if there is any tool for disassemble spi image like we do with all CSME or TXE versions using the appropriate Intel ME tool? The problem is original bios file Asus provides, has bios guard protection, I downloaded the latest update for Ami_pfat_extractor from plomatov (previous versions of AMI bios guard extractor doesn't work),with that...
- Loading...
