need bios for asus rog GL552vx
  • gilasenak
    • Nov 2009
    • 15
    • Malaysia
    HI
    I need bios for asus rog GL552vx.
    Problem is fan spinning but no display.
    PLEASE HELP
  • marcin02152
    • Oct 2014
    • 134
    • Polska
    Re: need bios for asus rog GL552vx
    try
    https://www.badcaps.net/forum/showthread.php?t=78797
    • gilasenak
      • Nov 2009
      • 15
      • Malaysia
      Already try. Not working.
      • mcplslg123
        • Jun 2015
        • 7262
        • india
        post your bios backup here so that it can be rebuilt with asus update.
        • gilasenak
          • Nov 2009
          • 15
          • Malaysia
          Here is the bios dump
          • Claudiomfa
            • Nov 2015
            • 455
            • Portugal
            try and report
            • gilasenak
              • Nov 2009
              • 15
              • Malaysia
              Flash and the laptop power up. Thank you so much Claudiomfa.
              • gilasenak
                • Nov 2009
                • 15
                • Malaysia
                After a while..the laptop have another symptom..its run for around 30 minutes suddenly no picture but have backlight..
                • Claudiomfa
                  • Nov 2015
                  • 455
                  • Portugal
                  Try this cleared ME file
                  • gilasenak
                    • Nov 2009
                    • 15
                    • Malaysia
                    Ok. I'll try it. Tqvm
                    • gilasenak
                      • Nov 2009
                      • 15
                      • Malaysia
                      Tested the bios..but still the same problem no picture have backlight. Any suggestion?
                      • gilasenak
                        • Nov 2009
                        • 15
                        • Malaysia
                        My laptop model is asus rog gl552v-x(kbl)dm409t
                        • gilasenak
                          • Nov 2009
                          • 15
                          • Malaysia
                          Board version
                          GL552vxk
                          Rev 2.0
                            • 20788
                            Board version
                            GL552vxk
                            Rev 2.0
                            Try this one .
                            • Claudiomfa
                              • Nov 2015
                              • 455
                              • Portugal
                              Check with this file and report
                                • 20788
                                That bios will not work.The chipset support is set to Intel H110 Desktop,and ME version is PRD EXTR . The previous bios you posted at #9 the chipset is set to Intel Z170 Desktop . What tool are you using intel easy clean ? .Its always more reliable to use FIT manually using the guide at win-raid.
                                • Claudiomfa
                                  • Nov 2015
                                  • 455
                                  • Portugal
                                  I use lbe for clear me
                                    • 20788
                                    I don`t use lbe so i`m not famiiar with the ME settings.
                                    • Claudiomfa
                                      • Nov 2015
                                      • 455
                                      • Portugal
                                      Sometimes i use FIT too, but with lbe it was more easy to do. The problem are the chipset selection, this is what are save on me region dump downloaded.
                                      • gilasenak
                                        • Nov 2009
                                        • 15
                                        • Malaysia
                                        Try this one .
                                        Its work for awhile..boot up installed windows..
                                        then black screen with backlight..reboot..fan spinning black screen.
                                        • razor_amd
                                          by razor_amd
                                          12-15-2020, 07:07 PM
                                        • grimacelord
                                          by grimacelord
                                          07-10-2025, 02:52 PM
                                        • throwaway327
                                          by throwaway327
                                          Model No: RC72LA
                                          Serial No: SBNVKD001014459
                                          06-18-2025, 05:52 PM
                                        • jbonavita
                                          by jbonavita
                                          Some issues
                                          Things I tried
                                          04-29-2025, 09:38 PM
                                        • lrouw84
                                          by lrouw84
                                          Hi there,
                                          01-28-2023, 01:31 PM
