Please unlock me bios dump from HP 650 G1
  • amd2000
    • Feb 2015
    • 5
    • romania
    #41
    Re: Please unlock me bios dump from HP 650 G1
    clear admin password. thanks
    • Markus1741
      • Sep 2020
      • 843
      • N/A
      #42
      You can try this ...
      • disorder
        • Sep 2015
        • 156
        • france
        #43
        hello guys,
        i need some help to remove password from a probook 650 g1. here is the dump file.
        i hope you can help
        edit : sn : 5CG44251DS
        sorry
          • 20769
          Originally posted by disorder
          hello guys,
          i hope you can help
          Thread merged. Please read the updated rules, type and post the laptop serial number https://www.badcaps.net/forum/troubl...before-posting
          • disorder
            • Sep 2015
            • 156
            • france
            #45
            hello, i've edit my post for sn
            since i've tried to flash bios after hpunlocker , with ch341a 1.18 and asprogrammer but they say me that the lenght of my files is too high (as the original dump too now). 1.30 of ch341a didn't notice that.
            how can i fix this problem please? can you create a validate bios with the file i sent ? thank you sir
            • hoaca388
              Badcaps
              • Jan 2022
              • 11683
              #46
              Here
              • disorder
                • Sep 2015
                • 156
                • france
                #47
                hello
                try your file but got same issues as all my files : white steady power led and blinking amber light, no post , no fan.
                it is possible to create a new bios file from a known good one and my sn ?
                • disorder
                  • Sep 2015
                  • 156
                  • france
                  #48
                  some ,news, i finally fix the laptop : take a bios file in this topic and replace the specific data of mine with the file you send (sn, sku, build) with HxD
                  now all works fine
                  thank you for help
                  • Loli Popu
                    • Sep 2024
                    • 13
                    • ALBANIA
                    #49
                    Hello guys i have Hp PROBOOK 650 G1,this laptop has bios password.I read the bios with ch341 v1.18 also i am using a clip.The ch341 software detected the chip like w25q128bv ,the bios chip in the motherboard has code w25q128fv. I read the bios and verified the bios without a problem,also i made 2 backups of the original bios.I used "rcunlocker" to remove the bios password .I flashed the unlocked bios from rcunlocker and turned laptop on,still had a password on it,i tried several time but no success .Then when i did the last flash the laptop doesn't power on ,only power button light up and nothing else.I flashed again the original bios and still the laptop doesnt power on ,only power buton lights up.I dont know where the problems is ,or what mistake i have done .
                    Can someone help ?
                    Serial:5CG61840YD
                    Product9S33AV
                    PCID:A3009DD10203
                    Thanks!
                      SMDFlea commented
                      Editing a comment
                      thread merged.
                  • hoaca388
                    Badcaps
                    • Jan 2022
                    • 11683
                    #50
                    Can someone help ?
                    Serial:5CG61840YD
                    Product9S33AV
                    PCID:A3009DD10203
                    Thanks!
                    Look around the bios chip pins to see if you have accidentally damaged your machine.
                    • Loli Popu
                      • Sep 2024
                      • 13
                      • ALBANIA
                      #51
                      I just checked and it looks good ,the bios chip legs look connected in the board ,they have some scracht from clip but no other damage.Also white steady power led and blinking amber light, no post , no fan spinning .Maybe the bios file is damaged or idk 😔.I think i have the same problem like Disorder user .
                      • hoaca388
                        Badcaps
                        • Jan 2022
                        • 11683
                        #52
                        Replace the bios chip (if you are sure there is no further hardware damage).
                        • Loli Popu
                          • Sep 2024
                          • 13
                          • ALBANIA
                          #53
                          Finally i was able to flash the original bios and laptop comes to life ,but still the admin bios password is there ,can you remove the password please?I tried with rcunlocker but didnt work ,idk why .
                          • Habble7
                            by Habble7
                            Suspected Cause:
                            Troubleshooting Attempts:
                            05-22-2025, 07:28 AM
                          • DynaxSC
                            by DynaxSC
                            11-17-2023, 10:56 AM
                          • grimacelord
                            Trying To Find UUID In BIOS Dump - HP 14-dq0055dx
                            by grimacelord
                            This laptop is the same laptop I was working on in this thread and I wasn't sure if I should post a new topic or post in that thread because I already solved the issue that thread was discussing and this is a completely different issue although it is dealing with the same laptop. I decided to make a new thread since it's a new issue, but please move if I made a mistake.
                            Motherboard model number: DA0PAMB46A1 REV: A
                            Secondary motherboard model number: 0PAB
                            SKU: 685K4UA
                            Serial number is: 5CD3223BJP
                            Recently reflashed this laptop with latest BIOS and once...
                            05-07-2024, 08:06 AM
                          • DynaxSC
                            Who has a MSI Z590 PRO WIFI - Need BIOS dump ?
                            by DynaxSC
                            I need a BIOS dump for MSI Z590 PRO WIFI from a real physical board, along with MAC address and serial no.
                            It must be a dump from a physical board, as it contains personalized data eg. MAC Address, UUID, Serial no.
                            I have a board which has lost the BIOS contents, I have the MAC and serial to this board, and need to insert it into the another BIOS image. To do it, I need to have a real image from a real board, as the images from the MSI site are without this data. The only way to find where MAC/UUID/Serial is located in the BIOS is to have a bios...
                            11-06-2022, 05:22 PM
                          • TacticalFahrrad
                            [REQUEST] Fujitsu Lifebook E5513 – Full BIOS Dump Needed (.bin)
                            by TacticalFahrrad
                            I extracted the official BIOS update package from Fujitsu (contains FJNB2FD.CAP, ~18.7 MB) and tried tools like UEFIExtract, but it seems to only contain...
                            06-30-2025, 04:09 AM
