Please unlock me bios dump from HP 650 G1
  • amd2000
    • Feb 2015
    • 5
    • romania
    #41
    Re: Please unlock me bios dump from HP 650 G1
    clear admin password. thanks
    • Markus1741
      • Sep 2020
      • 948
      • N/A
      #42
      You can try this ...
      • disorder
        • Sep 2015
        • 156
        • france
        #43
        hello guys,
        i need some help to remove password from a probook 650 g1. here is the dump file.
        i hope you can help
        edit : sn : 5CG44251DS
        sorry
          • 21936
          Originally posted by disorder
          hello guys,
          i hope you can help
          Thread merged. Please read the updated rules, type and post the laptop serial number https://www.badcaps.net/forum/troubl...before-posting
          • disorder
            • Sep 2015
            • 156
            • france
            #45
            hello, i've edit my post for sn
            since i've tried to flash bios after hpunlocker , with ch341a 1.18 and asprogrammer but they say me that the lenght of my files is too high (as the original dump too now). 1.30 of ch341a didn't notice that.
            how can i fix this problem please? can you create a validate bios with the file i sent ? thank you sir
            • hoaca388
              Badcaps
              • Jan 2022
              • 12332
              #46
              Here
              • disorder
                • Sep 2015
                • 156
                • france
                #47
                hello
                try your file but got same issues as all my files : white steady power led and blinking amber light, no post , no fan.
                it is possible to create a new bios file from a known good one and my sn ?
                • disorder
                  • Sep 2015
                  • 156
                  • france
                  #48
                  some ,news, i finally fix the laptop : take a bios file in this topic and replace the specific data of mine with the file you send (sn, sku, build) with HxD
                  now all works fine
                  thank you for help
                  • Loli Popu
                    • Sep 2024
                    • 13
                    • ALBANIA
                    #49
                    Hello guys i have Hp PROBOOK 650 G1,this laptop has bios password.I read the bios with ch341 v1.18 also i am using a clip.The ch341 software detected the chip like w25q128bv ,the bios chip in the motherboard has code w25q128fv. I read the bios and verified the bios without a problem,also i made 2 backups of the original bios.I used "rcunlocker" to remove the bios password .I flashed the unlocked bios from rcunlocker and turned laptop on,still had a password on it,i tried several time but no success .Then when i did the last flash the laptop doesn't power on ,only power button light up and nothing else.I flashed again the original bios and still the laptop doesnt power on ,only power buton lights up.I dont know where the problems is ,or what mistake i have done .
                    Can someone help ?
                    Serial:5CG61840YD
                    Product9S33AV
                    PCID:A3009DD10203
                    Thanks!
                      SMDFlea commented
                      Editing a comment
                      thread merged.
                  • hoaca388
                    Badcaps
                    • Jan 2022
                    • 12332
                    #50
                    Can someone help ?
                    Serial:5CG61840YD
                    Product9S33AV
                    PCID:A3009DD10203
                    Thanks!
                    Look around the bios chip pins to see if you have accidentally damaged your machine.
                    • Loli Popu
                      • Sep 2024
                      • 13
                      • ALBANIA
                      #51
                      I just checked and it looks good ,the bios chip legs look connected in the board ,they have some scracht from clip but no other damage.Also white steady power led and blinking amber light, no post , no fan spinning .Maybe the bios file is damaged or idk 😔.I think i have the same problem like Disorder user .
                      • hoaca388
                        Badcaps
                        • Jan 2022
                        • 12332
                        #52
                        Replace the bios chip (if you are sure there is no further hardware damage).
                        • Loli Popu
                          • Sep 2024
                          • 13
                          • ALBANIA
                          #53
                          Finally i was able to flash the original bios and laptop comes to life ,but still the admin bios password is there ,can you remove the password please?I tried with rcunlocker but didnt work ,idk why .
                          • Ahari
                            by Ahari
                            I...
                            08-13-2025, 06:12 AM
                          • mkdj
                            by mkdj
                            Dear all,
                            10-19-2025, 04:41 AM
                          • Habble7
                            by Habble7
                            Suspected Cause:
                            Troubleshooting Attempts:
                            05-22-2025, 07:28 AM
                          • haitham sharabati
                            [Request] Clean BIOS dump for HP 15-da2007ne (8XF55EA#ABV) - N4000 - BIOS Lock
                            by haitham sharabati
                            Hello engineers 😀,
                            I’m kindly requesting a clean and unlocked BIOS dump for the following HP laptop, as it’s bricked after flashing SP152727. The system now keeps rebooting, and the original issue was an Administrator / Power-On Password that I can no longer access.😏
                            🔧 Device Info:
                            - Model: HP 15-da2007ne
                            - Product Number: 8XF55EA#ABV
                            - Serial Number: CND0338P0D
                            - CPU: Intel Celeron N4000
                            - EC/BIOS Chip: [Add chip number from the motherboard or BIOS chip]
                            💀 Problem:😅
                            - Device shows “Administrator Password”...
                            08-07-2025, 04:54 AM
                          • Citymin
                            by Citymin
                            S/N : 5RNK9FFT70...
                            08-05-2025, 05:12 AM
