I need the HP zbook 17 g5 DUMP BIOS, thank you.
  • amiralipay
    • Oct 2022
    • 17
    • iran
    #61
    Hi
    My bios error endpoint
    Plz fix
    SN:
    5CD926C7CY
    Tnx
    • hoaca388
      Badcaps
      • Jan 2022
      • 11813
      #62
      Originally posted by amiralipay
      Hi
      Plz fix
      SN:
      5CD926C7CY
      Tnx
      error endpoint
      • Francisco.s
        • 686
        • Spain
        #63
        Hi, need bios for HP ZBOOK 17 G6 DA0XW3MBAH0 REV H
        It makes boot loop but no imagen, with win + esc keys, it tries to read the pendrive, but pendrive stops blinking for a few seconds and loops again.
        Seems not to be any bios for this motherboard, but many for DAXW3EMBAF0.
        Serial number: 5 C D 9 4 4 9 J V D
        Thanks for your help.
        • peste
          peste commented
          Editing a comment
          post merged..next time look for a thread with the name and model, motherboard model of the laptop, and post there, if you can't find it, then make a new thread..
      • hoaca388
        Badcaps
        • Jan 2022
        • 11813
        #64
        HP ZBook 17 G5 Mobile Workstation
        • Francisco.s
          • 686
          • Spain
          #65
          Thanks hoaca388, this bios works!!!
          Now this laptop has video and boots from ssd or usb. Can't believe it. I have tried many dumps and none of them worked till now.
          I shows an error now about Endpoint Security, but this seems easy to solve.
            SMDFlea commented
            Editing a comment
            Posts moved to G5 thread from G6.... .Try to post in the correct thread please....
        • kevin_23
          • Jul 2025
          • 6
          • Spain
          #66
          Good morning and delighted to be part of this community, I have purchased an old business laptop, a HP ZBook 17 G5 system model with the Intel(R) Xeon(R) E-2176M CPU @ 2.70GHz, 2712 Mhz, 6 main processors, 12 logical processors, BIOS version and date HP Q70 BIOS version and date Ver. 01.29.01, 09/24/2024 SMBIOS version 3.1, the BIOS is password locked, I cannot access the BIOS to change parameters, my question is if in this model the BIOS can be unlocked without having to open the laptop or on the contrary, do you have to solder or something? Thank you very much
          • peste
            peste commented
            Editing a comment
        • AHSAN TARIQ
          • Jan 2025
          • 66
          • Pakistan
          #67
          no bro is if in this model the BIOS can be unlocked open the laptop or on the contrary, yes you have to solder or something like desldering a chip and you nedd programmer to re write a bios
          • kevin_23
            • Jul 2025
            • 6
            • Spain
            #68
            Thank you for the information, it's a shame, I don't dare to desolder, thank you.
            • kevin_23
              • Jul 2025
              • 6
              • Spain
              #69
              I've opened the cover and found the BIOS chip and the EC chip. If I buy the WSON8 8x6 and SOIC8 chips, what should I do next? Isn't it too inconvenient? Can I do it without soldering, or does this PC have an option with WSON8 8x6 and SOIC8 chips?
              • peste
                • Dec 2016
                • 12880
                • ROMANIA
                #70
                The bios chip must be unsoldered from the board before writing or reading..
                do not use the clip, you may have errors..if you do not have anything to unsolder it with,
                solder wires between the programmer and the bios chip..
                you need an SPI programmer...here is a video for example..https://www.youtube.com/watch?v=DWWi...nnel=ThisIsHow
                post S/N, full name and model, motherboard model, product number,etc.
                • kevin_23
                  • Jul 2025
                  • 6
                  • Spain
                  #71
                  I have no idea how to solder or desolder, I would ruin it. With clip is possible?
                  • peste
                    • Dec 2016
                    • 12880
                    • ROMANIA
                    #72
                    you can charge whatever your laptop is..
                    • kevin_23
                      • Jul 2025
                      • 6
                      • Spain
                      #73
                      Forgive my insistence, it may be very tedious, but with the programmer and the clip without having to use a soldering iron, do you think it would be possible or is it impossible? With WSON8 8x6 and SOIC8 chips, the bad thing, I don't see any tutorial without having to solder.
                      • Ahari
                        by Ahari
                        I...
                        08-13-2025, 06:12 AM
                      • Habble7
                        by Habble7
                        Suspected Cause:
                        Troubleshooting Attempts:
                        05-22-2025, 07:28 AM
                      • haitham sharabati
                        [Request] Clean BIOS dump for HP 15-da2007ne (8XF55EA#ABV) - N4000 - BIOS Lock
                        by haitham sharabati
                        Hello engineers 😀,
                        I’m kindly requesting a clean and unlocked BIOS dump for the following HP laptop, as it’s bricked after flashing SP152727. The system now keeps rebooting, and the original issue was an Administrator / Power-On Password that I can no longer access.😏
                        🔧 Device Info:
                        - Model: HP 15-da2007ne
                        - Product Number: 8XF55EA#ABV
                        - Serial Number: CND0338P0D
                        - CPU: Intel Celeron N4000
                        - EC/BIOS Chip: [Add chip number from the motherboard or BIOS chip]
                        💀 Problem:😅
                        - Device shows “Administrator Password”...
                        08-07-2025, 04:54 AM
                      • Citymin
                        by Citymin
                        S/N : 5RNK9FFT70...
                        08-05-2025, 05:12 AM
                      • loopster
                        Need help cleaning ME region on Zbook 17 G1 bios dump
                        by loopster
                        Hello guys,
                        could I please get some help cleaning the ME region of the attached Zbook 17 G1 bios dump (CH341a, neoprogrammer, chip-desoldered, dumped twice, identical checksum)?
                        Symptoms, delayed BIOS post (ca. 45 secs.) keyboard not working, touchpad not working, booting linux live, console says "Management engine not configured".
                        I tried following the ME firmware cleaning guide, but whatever Flash Image Tool version I try, I get the same error:
                        Error 10: Failed to open with processed commands.
                        Unable to open file: C:\Users\Elitebook...
                        06-16-2024, 09:57 AM
