Razer RZ09 Bios
Hi, Sure I have attached the files here.Attached FilesComment
Hi, unfortunately its just a BIOS file and I need EC BIOS actually,
try this one - https://www.badcaps.net/forum/troubl...33#post3629033Comment
Need bios: Product No: RZ09-03009
Motherboard number : DA530-MB FCS V6.0
backup bios no Display fan spin normallyAttached FilesComment
The laptop serial number, SNID or service tag must be posted with every bios request - https://www.badcaps.net/forum/troubl...before-posting
RZ09-03009 bios
https://mysupport.razer.com/app/answ...tail/a_id/3643
Bios update - https://rzr.to/CaOyK
Extract RazerUpdater_v1.1.1.2_D3-BIOS0103.exe with 7-zip or WinRAR ,bios is DANA3_0103.bin (16,384KB)Comment
Please have a loot at his bios.
The laptop does charge te battery, there's 3.3V present, but that's it.
While checking in HxD it appears that the dump is almost empty. I did find the windows licence key though.
Razer RZ09-0370BGA3
S/N BY2132M39604052Attached FilesComment
Your backup is the EC not bios. The bios is 16MB
bios update https://rzr.to/ymagCg
Extract the exe with 7-zip or WinRAr ,the name of the bios is P1106.romComment
I'll find the other chip and get it dumped. But how is the windows licence key in the EC? It's a GigaDevice 25Q64CSIG, which indeed is smaller than 16MB
It turns out the bios is not to blame.
The content of this 8MB chip could be suspect? I do see the ITE EC warm up ever so slightly when I connect the power adapter. I did reflow this BGA chip to check if it would make a temporary difference.
The mentioned GigaDevice chip does contain the identity of this laptop. Could someone fix this with a known good? If that doesn't work I sadly have to let the laptop go unrepaired.Comment
Hi everyone, I'm looking for a verified EC Bios Dump for a laptop, the original EC was corrupted after a different technician flashed an incompatible file, if anyone has a good dump for this model, i would greatly appreciate it.
RZ09-0351
RZ09-03519E11
Hi. Anyone can help with my vbios please? The graphics card is not detected in device manager or bios. On the forums people write that the vbios should be in .rom file which is confusing for me because after connecting the ch341a the programmer recognizes and reads the .bin file 2mb. I am attaching a photo of the motherboard and the VBIOS that I desoldered + bin file
Razer Blade 15 Advanced 2021
model: RZ09-0409
serial: BY2144M60001081
motherboard: CH570
PLEASE HELP 🙏🙏🙏Comment
94.04.54.00.20 Razer RTX 3070 Mobile 8 GB
by vinaypundithI have this laptop that does boot but it's on an older BIOS that has issues with Secure Boot, and I cannot use the normal Razer BIOS updater because for some reason the serial number is missing / got deleted somehow (Common issue on this model, from what I've read). I got a dump of the BIOS chip (or at least what I think is the BIOS chip), and its 16MB in size - the files from the Razer BIOS update are 8MB. (There's two 8MB files, am I supposed to combine these somehow? Or combine with an Intel ME firmware? I have no idea).
So, I'm looking for a BIOS dump for this machine - a 16MB one....-
Channel: BIOS Requests ONLY!
by 0xxHi folks,
My son clicked “Update and Shutdown” on a Razer Blade 14 (2022, RZ09-0427), closed the lid, disconnected the charger, and put the laptop in his backpack. The next day, it wouldn’t boot: only the green LED blinked, no fans, no keyboard backlight, no display. The chassis does get warm, so the CPU/GPU seems to get power.
What I’ve tried so far: disconnecting the main battery, CMOS reset with power drain (30s), using a different power adapter, and connecting to the monitor - same result.
I assumed that Windows Update was interrupted due to closing... -
by AwdevS/N is BY2011A72401766
Full name: RZ09-03006E92-R3U1 Razer Blade 15” (2019) | RZ09-03006
MB Model is: DA530-MB
Dump is below, Laptop can do EC Reset but cannot boot. Suspect its BIOS or EC....-
by macabookHello everyone,
đź§© Initial Issue- Board powers on (fans spin, keyboard lights up and can be adjusted, caps lock led lights), but no display or backlight
- External display (HDMI) shows
07-24-2025, 02:17 PM -
by gettindabeltHello I have a Razer book model rz09-03571em1 that had a bad bios update a while back that put it out of commission. I have a chip programmer but am having a hard time locating the actual BIOS chip on the motherboard. I already have the BIOS file, but I was wondering if anyone could help me identify the chip or has any information on writing a new BIOS. Pictures of the board will be attached....
- Loading...
