Razer RZ09 Bios
  • Claudiomfa
    • Nov 2015
    • 455
    • Portugal
    Re: Razer RZ09 Bios
    Originally posted by scarabson
    My programmer can't read or write that chip. I think it needs more voltage that the 3.3v it uses. Here is the datasheet for U49.
    what programmer do you have?
    • scarabson
      • Mar 2020
      • 12
      Re: Razer RZ09 Bios
      This CH341a programmer is what I have
      • Claudiomfa
        • Nov 2015
        • 455
        • Portugal
        Re: Razer RZ09 Bios
        I think that your programmer supports this chip. you can use the AsProgrammer software and select mx25l1006e. this chips is 3.3v
        • scarabson
          • Mar 2020
          • 12
          Re: Razer RZ09 Bios
          Yeah that's what I've been using but I cannot get the chip to read. I have selected the correct chip from the dropdown menu but still no luck.
          • Claudiomfa
            • Nov 2015
            • 455
            • Portugal
            Re: Razer RZ09 Bios
            Possibly your chip may be dead. You can use chip MX25L8006E if you have one in stock
            • scarabson
              • Mar 2020
              • 12
              Re: Razer RZ09 Bios
              I don't have soldering equipment or the skills to do it myself. I'll probably need someone else to repair it.
              • Claudiomfa
                • Nov 2015
                • 455
                • Portugal
                #27
                Re: Razer RZ09 Bios
                The best way is to take off the chip and programming them outside of the board. This is your problem for the programmer not detecting the chip
                • scarabson
                  • Mar 2020
                  • 12
                  Re: Razer RZ09 Bios
                  Thanks for your help, I think I'll just have to wait and let someone more knowledgeable than me repair the computer. I'm not very experienced with this type of work and I don't want to damage the board trying to de-solder any chips. I was hoping I could just reprogram them with the test clip but it seems that is not enough.
                  • wantas
                    • Dec 2020
                    Re: Razer RZ09 Bios
                    did anyone have a BIOS Dump for RZ09-03135? I must to reflash my Bios and EC...
                    • qayyum786
                      • Aug 2018
                      • 1959
                      • INDIA
                      #30
                      Re: Razer RZ09 Bios
                      Originally posted by wantas
                      hello,
                      did anyone have a bios dump for rz09-03135? I must to reflash my bios and ec...
                      chck post #1 and #6 posted by smdflea
                        • 22176
                        Re: Razer RZ09 Bios
                        Here, click on the link in the pdf to download the bios, then extract the exe using 7-zip or winrar .The full bios is in the extracted folder .
                        https://cdn.badcaps-static.com/pdfs/...c2651e044b.pdf
                        http://drivers.razersupport.com//ind...&nav=0,350,933
                        • joutrade
                          • May 2015
                          • 24
                          • united kingdom
                          #32
                          Re: Razer RZ09 Bios
                          hello, after install and rewrite the charlotte bin file on razer 15 rz09-2886 , the laptop work find but can not recognize the graphic card, the serial number neither the SKU in the bios page. any idea how to make it read the serial and graphic again ? I have noticed that the serial is there in the emc chip but still can not read it from the bios page. any idea?
                          • qayyum786
                            • Aug 2018
                            • 1959
                            • INDIA
                            #33
                            Re: Razer RZ09 Bios
                            if you have your original backup than post here some one will fix it
                            • joutrade
                              • May 2015
                              • 24
                              • united kingdom
                              #34
                              Re: Razer RZ09 Bios
                              Thank you. file attached ( original bin )
                              • joutrade
                                • May 2015
                                • 24
                                • united kingdom
                                #35
                                Re: Razer RZ09 Bios
                                Sorry, File has been attached again
                                  • 22176
                                  Re: Razer RZ09 Bios
                                  The bios you posted is from an Alienware 15 R2 (P42F002)
                                  • joutrade
                                    • May 2015
                                    • 24
                                    • united kingdom
                                    #37
                                    Re: Razer RZ09 Bios
                                    Thank you for reply. The bios has been taken of razer 15 2019 . it has been dismantled by myself and it is defiantly not an Alienware. but whatever do you have any idea how to solve that. razer or Alienware. !?
                                      • 22176
                                      Re: Razer RZ09 Bios
                                      Check the motherboard part number, "C2_MB FCS V4.0" .If thats what it is then try the 02886 bios at post #6 .
                                        • 22176
                                        Re: Razer RZ09 Bios
                                        Post this "emc" chip backup. Does the serial match the one on the case ?
                                        • joutrade
                                          • May 2015
                                          • 24
                                          • united kingdom
                                          #40
                                          Re: Razer RZ09 Bios
                                          Yes the serial in the EC match the one on the case
                                          • vinaypundith
                                            Razer RZ09-01682 Blade Stealth 13 2016 BIOS dump needed
                                            by vinaypundith
                                            I have this laptop that does boot but it's on an older BIOS that has issues with Secure Boot, and I cannot use the normal Razer BIOS updater because for some reason the serial number is missing / got deleted somehow (Common issue on this model, from what I've read). I got a dump of the BIOS chip (or at least what I think is the BIOS chip), and its 16MB in size - the files from the Razer BIOS update are 8MB. (There's two 8MB files, am I supposed to combine these somehow? Or combine with an Intel ME firmware? I have no idea).
                                            So, I'm looking for a BIOS dump for this machine - a 16MB one....
                                            08-03-2024, 12:32 PM
                                          • 0xx
                                            2022 Razer Blade 14 (RZ09-0427) won’t boot after Windows update, only the green LED blinks - overheated or BIOS?
                                            by 0xx
                                            Hi folks,
                                            My son clicked “Update and Shutdown” on a Razer Blade 14 (2022, RZ09-0427), closed the lid, disconnected the charger, and put the laptop in his backpack. The next day, it wouldn’t boot: only the green LED blinked, no fans, no keyboard backlight, no display. The chassis does get warm, so the CPU/GPU seems to get power.
                                            What I’ve tried so far: disconnecting the main battery, CMOS reset with power drain (30s), using a different power adapter, and connecting to the monitor - same result.
                                            I assumed that Windows Update was interrupted due to closing...
                                            09-14-2025, 03:46 PM
                                          • Awdev
                                            Razer Blade 15 (2019) RZ09-03006E92 need BIOS Image
                                            by Awdev
                                            S/N is BY2011A72401766
                                            Full name: RZ09-03006E92-R3U1 Razer Blade 15” (2019) | RZ09-03006
                                            MB Model is: DA530-MB
                                            Dump is below, Laptop can do EC Reset but cannot boot. Suspect its BIOS or EC....
                                            10-18-2025, 02:13 AM
                                          • macabook
                                            by macabook
                                            🧩 Initial Issue
                                            07-24-2025, 02:17 PM
                                          • cr4zychriss
                                            by cr4zychriss
                                            • Rebrand: PC Specialist
                                            11-14-2025, 04:04 PM
