HP Probook 650 G2 won't turn on after bios chip replacement
  • capon5153
    • Apr 2019
    • 21
    • Belgium
    hello,
    i have an HP Probook 650 G2 , i have replaced the chip with another one because my bios was locked and i didnt know the password.
    it was working fine until i had to replace the bios chip.
    now its not turning on only the fan spins at high speed but i get no display at all.
    does someone have an idea of what it could be?
    thanks in advance
  • khaahk
    • Dec 2013
    • 776
    • Estonia
    Re: HP Probook 650 G2 won't turn on after bios chip replacement
    And what was the content of the other chip?
    Did you put it back with same orientation?
    • capon5153
      • Apr 2019
      • 21
      • Belgium
      what do you mean by content?
      i have just ordered an new and already programmed chip on ebay.
      i have put it back with same orientation. only the ground connection of the motherboard got broken. but i have jumped it with a jumper cable to the ground of the motherboard. can this be the reason?
      • khaahk
        • Dec 2013
        • 776
        • Estonia
        Not sure how good are these preprogrammed chips, i mean the content. Put the old one back and if it is ok then try to solve it with seller.
        • capon5153
          • Apr 2019
          • 21
          • Belgium
          the problem is that i dont have the old chip anymore, i cant find it.
          • khaahk
            • Dec 2013
            • 776
            • Estonia
            2 options come to mind:
            1. Buy spi programmer, save the content of the bought chip and try to find correct one online (this forum has many threads with that model).
            2. Buy another chip from ebay and hope for the best.
            Loosing the original content makes your task harder, there might be different mainboards used in the same model of notebook that is why having the original dump is a good reference point when searching for correct bios.
            • capon5153
              • Apr 2019
              • 21
              • Belgium
              hi, i have already ordered an spi programmer im waiting for it to arrive will try your suggestions..thanks
              • capon5153
                • Apr 2019
                • 21
                • Belgium
                i also have an fully working hp probook 450.. would it work if i took the bios chip from it and put it to the probook 650 G2??
                • MIDOX
                  • Jul 2018
                  • 32
                  • ALGERIA
                  No dont work
                  • capon5153
                    • Apr 2019
                    • 21
                    • Belgium
                    hello,
                    i have found my original chip and i think i have managed to read it with my ch341a programmer, can someone please unlock it??
                    • xs1100s
                      • Oct 2019
                      • Spain
                      The content of that file is blank. You did not read anything.
                      • rediii
                        h???, spurrrn
                        • Mar 2018
                        • 487
                        • somewhere in europe
                        hello,
                        thanks in advance
                        are you sure, that nothing got knocked off the board (i.e. resistor) while changing the chip?
                        • BADJACK80
                          • Mar 2020
                          • 21
                          • Erde
                          I have a similar problem. I have an HP ProBook 650 G2. Unfortunately I don't have a dump from this notebook. I have uploaded a biosfile from the Internet with the ch341a. The notebook now starts up again but I cannot change the SKU, SN ...... because it is in MPM "Lock" mode. I've tried several things but nothing has worked so far. I would have all the data like SKU, BoardID and model. Maybe you can feed the existing bios with the appropriate data and I will then flash the customized biosfile.
                          Sorry for my bad English. Unfortunately I did everything with the translator
                          • lapfix
                            • Mar 2020
                            • 2733
                            • my workshop
                            Can you give us your serial/pcid/BID !maybe we can know your right bios
                            • BADJACK80
                              • Mar 2020
                              • 21
                              • Erde
                              SN/ 5CG6514SCH pcid = T4J10ET#ABD BID/ PFKCQ00WB561EA
                              I hope you mind pcid is ProductID
                              • peste
                                • Dec 2016
                                • 12859
                                • ROMANIA
                                try this..
                                https://www.youtube.com/watch?v=9T57ktw8n3Y
                                • BADJACK80
                                  • Mar 2020
                                  • 21
                                  • Erde
                                  I had already tried that, unfortunately without success. I worked through the individual points, but the Dos window closed again without changing anything.
                                  • peste
                                    • Dec 2016
                                    • 12859
                                    • ROMANIA
                                    look, that's what I tried and it worked.
                                    https://www.youtube.com/watch?v=rP3A3HWM_-Q
                                    • lapfix
                                      • Mar 2020
                                      • 2733
                                      • my workshop
                                      it's a little difficult to give you your bios dump without the old one , can you give us the motherboard identification
                                      • BADJACK80
                                        • Mar 2020
                                        • 21
                                        • Erde
                                        I have already tried the HP BiosConfigTool. That unfortunately did not work. Since the device is probably still in MPM "lock mode". I have already renamed the FSMC.bin to SMC.bin but then I get an error message when booting. I have now attached the pictures of the individual error messages.
                                        Image 1 = current error message with the biosfile from the Internet
                                        Image 2 = error message from wndmifit64
                                        Image 3 - 5 = model and board names of the laptop
                                        I will also attach the dump from the internet with which the laptop "runs".
                                        :::: EDIT :::::
                                        Image 6 = Errormessage HPBiosConfigUT.
