Panasonic CF-54 Bios Password
  • medinfo
    • May 2016
    • 328
    • Morocco
    Panasonic Toughbook CF-54 mk1
    Bios = 16 Mb
    i need a clean bios plz
    Last edited by SMDFlea; 04-03-2023, 09:22 AM. Reason: Attachments cleanup,server space low.
  • medinfo
    • May 2016
    • 328
    • Morocco
    Re: Panasonic CF-54 Bios Password
    Problem fixed
    • mshobra90
      • egypt
      thanks bro
      • oluwaseun109
        • Jan 2020
        • Nigeria
        Hi guy kindly help me out on how it was used. urgent thanks.
        • oluwaseun109
          • Jan 2020
          • Nigeria
          Originally posted by medinfo
          Problem fixed
          How was it used please
          • oluwaseun109
            • Jan 2020
            • Nigeria
            Bios = 16 Mb
            How do i use it please. thanks.
            • RethoricalCheese
              • Mar 2013
              • 1517
              • Estonia
              So how does posting 3 times in 10 minutes help?
              Make a dump of your bios, clear out AMITSESetup sections and write it back.
              • oluwaseun109
                • Jan 2020
                • Nigeria
                Am sorry if my post look much can you please help me with the procedure of how to make a dumb of my bios
                Thanks.
                Hi my Toughbook CF-54 has a bios lock but I forgot what it was mm
                the serial number is CF-54AY006ZZ kindly help me out on the unlocking.
                Thanks.
                • chriszzler
                  • Jul 2020
                  • 6
                  • South Africa
                  Good day ,
                  Could someone please remove the bios password from my bios dump or supply me with the password , and also maybe teach me how to do it ? i have tried using a hex editor and changing the Amitsetup directory which contains the encrypted password with no success.
                  Kind regards
                  • rioreno
                    • Feb 2009
                    • 540
                    • Indonesia
                    Originally posted by chriszzler
                    Good day ,
                    Kind regards
                    try this... and goodluck
                    • chriszzler
                      • Jul 2020
                      • 6
                      • South Africa
                      Thank you for the effort , i get an error "43 - error: problem erasing flash" , did i do something wrong , how can i fix this ?
                      • rioreno
                        • Feb 2009
                        • 540
                        • Indonesia
                        i am not sure how to give explained to you... because i always t to desoldering chip instead using afuwin,,,,
                        just check how to flash using afuwin fromm this thread...
                        https://gist.github.com/en4rab/55088...omment-3276663
                        • chriszzler
                          • Jul 2020
                          • 6
                          • South Africa
                          Thank you for your assistance , seems as if it is locked , i updated the bios recently and might be the cause. Could you please share how you edited the rom ?
                          • chriszzler
                            • Jul 2020
                            • 6
                            • South Africa
                            Could someone please decrypt my bios password from my bios dump ? I cannot flash to the bios chip as it does not allow me to.
                            Panasonic CF-54D3961T2
                            Kind regards
                              • 20433
                              Kind regards
                              You need to make a full backup with an SPI programmer.Its the only way.
                              • chriszzler
                                • Jul 2020
                                • 6
                                • South Africa
                                I have attached the full backup , here is the password hex as well from the AMITSetup:
                                5B 86 B6 FF 11 89 6C B0 C7 2B 22 81 7D A4 D8 70
                                33 AE 8E 4E E9 F7 44 74 9F DE FA 5C 55 D3 B0 71
                                0B 29 66 02 C1 B9 1C B6 77 16 D2 A9 2D 3D 88 D0
                                E3 63 3E F7 99 8A F4 1D 4F B1 AA 44 05 D8 60 6B
                                Let me know if i can add any more info.
                                • tooko
                                  • Nov 2014
                                  • 38
                                  • france
                                  I have a Panasonic toughbook CF-54, I need to remove BIOS password. I have just read the MX25L12873f. Can someone remove password please ?
                                  Best regards
                                  • rioreno
                                    • Feb 2009
                                    • 540
                                    • Indonesia
                                    Best regards
                                    this..goodluck and please confirm
                                    • tooko
                                      • Nov 2014
                                      • 38
                                      • france
                                      Finally I had paid someone to do it, i was under pressure to do it. But I have tested yours rioreno and it works like a charm.
                                      thanks !
                                      Best regards
                                      • meskellil
                                        • Jan 2020
                                        • 8
                                        • casa
                                        I tried to flash with the bin that ( rioreno ) posted:TOUGHBOOKCF54_UNLOCK.rar (6.40 MB) but it don't work
                                        Can someone remove password ?
                                        I have read the MX25L12873f on my laptop .
                                        THANKS
                                        • outsider
                                          Panasonic FZ-G1 MK5 - BIOS password returning
                                          by outsider
                                          Hello
                                          I removed the BIOS password thanks to the help of one of the friends of this forum.
                                          https://www.badcaps.net/forum/troubl...61#post3637661
                                          The batch from which the password was removed works correctly but... after some time, the BIOS password is set again, I reprogrammed the batch with the removed password, it's ok, there is no password, I set my password, ok, I can enter the BIOS with my password but...
                                          06-17-2025, 12:51 AM
                                        • zenius
                                          by zenius
                                          12-08-2024, 06:13 AM
                                        • traxformania
                                          TONGFANG "GM7TG7P" Bios Password Problem?
                                          by traxformania
                                          I'm using TONGFANG "GM7TG7P" model laptop for over 3 years and i'm entering the same bios administrator password everyday. My laptop has Aptio BIOS (American Megatrends, AMI).
                                          But today it's not accepting my password. I'm %100 sure i'm entering the correct password.
                                          I'm trying to reset my bios without success.
                                          I tried :
                                          -I removed the BIOS battery and main battery. Waited for a long time but it didn't work. They already stated in the user manual that the password will not be reset even if the batteries...
                                          11-15-2023, 07:32 AM
                                        • Nopslide
                                          HP Omen 15-dh0052nf power-on & bios password
                                          by Nopslide
                                          Hello everyone, I come here to tell you my problem regarding the power-on password. It is not a bios reset demand, and i can't have any access to windows. This is the bios and power-on password that is blocking all other things.
                                          My Omen 15-dh0052nf purchased second-hand was configured with the bios password upon purchase (very simple password :P ).
                                          Having decided to sell it in order to get something more powerful, I reset all BIOS settings and set a blank administrator password. But the power-on password cannot be changed to a blank one so I let the actual password set....
                                          04-01-2024, 04:27 PM
                                        • AquaMan Ua
                                          Problem with PANASONIC CF53 laptop after changing BIOS settings
                                          by AquaMan Ua
                                          Hello. I am asking you for a hint on how to solve the problem with my touchbook Panasonic CF53-2 standart model. After setting up the BIOS, the laptop displays the wrong image until Windows loads. (More precisely, it displays, but distorted, instead of the Panasonic image immediately after turning it on, it displays what is in photo #1 in the attached file) Then the image appears when Windows starts loading and then there are no problems with the screen until the reboot. If you enter the BIOS, just a black screen. If you connect an external screen, the image on it is the same as on the built-in...
                                          05-17-2025, 09:40 AM
