Panasonic CF-54 Bios Password
  • bpoindex
    • Jan 2023
    • 10
    Re: Panasonic CF-54 Bios Password
    So not booting with copied w/changed sn. Is this result of me area not cleared? If so, please tell me that process. Thank you.
    • bpoindex
      • Jan 2023
      • 10
      Panasonic CF-54 MK3 Bios Password
      After copying another similar machine BIOS, I was wrong about not booting-simply had forgotten to replace memory. Even though I searched/replaced serial number, the donor BIOS machine serial number showed up. Additionally, the ME Firmware was not present. When I tried to run the batch file to write ME Firmware, it would fail. I fiddled with batch file to bypass checks with no sucess and I also ran update exe from cmd. Maybe with more time, could get this to take but I went back to the PW removed BIOS provided to me by @peste. Same as before:
      "Have tried again the L25 BIOS update, same behaviour with stopping at update screen.
      These two updates worked:
      -Embedded Controller V3.00L13 to V3.00L14
      -ME Firmware 11.8.60.3561 to 11.8.82.3838
      Also, I notice under Panasonic PC Setting Utility / PC Information Viewer / Setup:
      BIOS V3.00L17
      BIOS Configuration 0014-FFFF-00D5
      Sample ID ÿÿÿÿÿÿÿÿÿÿÿÿÿÿ < Do not see this line on similar machine
      Embedded Controller V3.00L14
      I'd appreciate any suggestions to correct the L25 update issue. Thanks again.
      • thaochua1982
        • Feb 2021
        • 25
        • ho chi minh
        #203
        i have a cf-54 i5 7300 with password in bios
        can someone help me to remove password?
        thanks alot
        • peste
          • 12593
          • ROMANIA
          #204
          thanks alot
          try..
          • thaochua1982
            • Feb 2021
            • 25
            • ho chi minh
            #205
            Originally posted by peste
            try..
            thanks alot,i will try it
            • thaochua1982
              • Feb 2021
              • 25
              • ho chi minh
              #206
              try..
              it worked.thanks alot
              • mi6oki
                • Feb 2023
                #207
                I have a CF-54 and I don't know what information is required to reset the BIOS password?
                • alihomee
                  • Dec 2012
                  • 1574
                  • malaysia
                  #208
                  need to remove password ori file is attached
                  • peste
                    • 12593
                    • ROMANIA
                    #209
                    try..
                    • alihomee
                      • Dec 2012
                      • 1574
                      • malaysia
                      #210
                      try..
                      it works perfectly.............................u are champ
                      • Sebi123
                        • Mar 2023
                        • Deutschland
                        #211
                        Hello Guys,
                        i have a Toughbook CF-54 Model No. CF54CY004EG and Serial No. 6ATCa41920..
                        After a "load setup defaults" in bios, the toughbook surprises me with a bios password, which was not used before. Unfortunately the setup defaults switch my boot devices, so I can boot only via USB Stick. For this reason I can dump bios via freedos programm only. I tried some afudos vesions without success. Flashrom asks for the right Flash-Chip, have no clue how to find this out.
                        I read this hole thread and the "how to" thead carefully.
                        My question is:
                        How can i dump the bios?
                        Thank you!
                        Greets. Sebi
                        I read all the bios stuff ca
                        • Kakajee13
                          • Sep 2020
                          • 23
                          • Pakistan
                          #212
                          Hello
                          please help me to unlock CF54 bios password
                            VIP Moderator
                            • Aug 2018
                            • 4386
                            • Bulgaria 🇧🇬
                            #213
                            Originally posted by Kakajee13
                            Hello
                            Did you tried already to remove the password, or it was someone else's job?
                            Become a Badcaps supporter
                            Thanks to all supporters.
                            • Kakajee13
                              • Sep 2020
                              • 23
                              • Pakistan
                              #214
                              its the old one. Thanks its done .
                                VIP Moderator
                                • Aug 2018
                                • 4386
                                • Bulgaria 🇧🇬
                                #215
                                its the old one.
                                No, it's not the old one. I saw, I saw that someone tried already.
                                Well, it wasn't a very successful attempt, but he still tried. That's why I asked if it was you, or someone else.
                                • Kakajee13
                                  • Sep 2020
                                  • 23
                                  • Pakistan
                                  #216
                                  laptop same. New dump file only
                                  • lenovo270
                                    • Mar 2023
                                    • 11
                                    • japan
                                    #217
                                    I have a CF-54 with a password in the BIOS.
                                    Can someone help me remove the password?
                                    Thank you very much
                                    • droopy234
                                      • Feb 2023
                                      • 8
                                      • rus
                                      #218
                                      hi dear, please help me pass dekete
                                      • WhateverGDR
                                        • Nov 2021
                                        • 22
                                        • Whereever
                                        #219
                                        Try attachment.
                                        • AAAC
                                          • Jan 2020
                                          • 458
                                          • Mexico
                                          #220
                                          @droopy234
                                          Seems like you used a software utility to read the BIOS, so file is empty (FFh) from 0h to A00000h (first 10MB), in this address range is where the Descriptor, GbE and ME Regions are located. So basically your file is just a dump of the BIOS Region.
                                          We use a software utility to read a BIOS when the password can be recovered from it, for a CF-54 you need a FULL bios backup obtained using a SPI programmer.
                                          • outsider
                                            Panasonic FZ-G1 MK5 - BIOS password returning
                                            by outsider
                                            Hello
                                            I removed the BIOS password thanks to the help of one of the friends of this forum.
                                            https://www.badcaps.net/forum/troubl...61#post3637661
                                            The batch from which the password was removed works correctly but... after some time, the BIOS password is set again, I reprogrammed the batch with the removed password, it's ok, there is no password, I set my password, ok, I can enter the BIOS with my password but...
                                            06-17-2025, 12:51 AM
                                          • zenius
                                            by zenius
                                            12-08-2024, 06:13 AM
                                          • traxformania
                                            TONGFANG "GM7TG7P" Bios Password Problem?
                                            by traxformania
                                            I'm using TONGFANG "GM7TG7P" model laptop for over 3 years and i'm entering the same bios administrator password everyday. My laptop has Aptio BIOS (American Megatrends, AMI).
                                            But today it's not accepting my password. I'm %100 sure i'm entering the correct password.
                                            I'm trying to reset my bios without success.
                                            I tried :
                                            -I removed the BIOS battery and main battery. Waited for a long time but it didn't work. They already stated in the user manual that the password will not be reset even if the batteries...
                                            11-15-2023, 07:32 AM
                                          • longmt1990
                                            Panasonic Cf-w5 bios password remove
                                            by longmt1990
                                            Hi, i have a Panasonic Cf-W5 with the bios password, I tried remove cmos but problem didnot solve.
                                            I uploaded the picture after remove cmos battery, It look like this is a Phoenix bios. The bios dump file in the link i attached
                                            Please help me remove bios password.
                                            Thank you so much
                                            07-06-2025, 10:50 PM
                                          • Nopslide
                                            HP Omen 15-dh0052nf power-on & bios password
                                            by Nopslide
                                            Hello everyone, I come here to tell you my problem regarding the power-on password. It is not a bios reset demand, and i can't have any access to windows. This is the bios and power-on password that is blocking all other things.
                                            My Omen 15-dh0052nf purchased second-hand was configured with the bios password upon purchase (very simple password :P ).
                                            Having decided to sell it in order to get something more powerful, I reset all BIOS settings and set a blank administrator password. But the power-on password cannot be changed to a blank one so I let the actual password set....
                                            04-01-2024, 04:27 PM
