Panasonic CF-54 Bios Password
  • AAAC
    • Jan 2020
    • 457
    • Mexico
    #181
    Re: Panasonic CF-54 Bios Password
    @bpoindex
    Hi, is better if you use the Original BIOS, otherwise if you use any of the compatible posted files you will still need to clean ME Region.
    Here's your Original file, with password removed.
    • bpoindex
      • Jan 2023
      • 10
      Thanks much. BIOS password is GONE.
      • ax00493
        • Jan 2023
        • Czech
        #183
        Could someone please decrypt the admin password from my bios dump?
        • AAAC
          • Jan 2020
          • 457
          • Mexico
          #184
          @ax00493
          Only file patch is available for CF-54.
          • spidero77
            • Jan 2023
            • 5
            Hi, could someone help, ...
            I have a bios-locked CF-54 - MK3 -
            I don't know, if I am doing all correct
            the command AFUWINx64 /O delivers me a 8MB File
            instead of 16MB
            and how can I upload the new file to ROM/bios?
            best regards
            spider
            • peste
              • 12346
              • ROMANIA
              #186
              instead of 16MB
              best regards
              spider
              what programmer do you have??
              • spidero77
                • Jan 2023
                • 5
                the computer CF-54 is booting into windows/HD,
                and I thought, I can use the software AfuWin64 for reading and writing the bios, can't I?
                I have no hardware-programmer, do I really need it, or is there a possibility to delete the password (make Bios unlocked)
                best regards
                Spider
                • peste
                  • 12346
                  • ROMANIA
                  #188
                  best regards
                  Spider
                  you need an SPI programmer otherwise it won't work.. and post the original bios here..
                  • greem
                    • Jan 2023
                    • 5
                    Panasonic CF-54 Operating Time in BIOS
                    My two CF-54 have now been unlocked of BIOS PW.
                    Everything went great, thanks for the support here!!!
                    Does anyone know also yet, how and where to change or reset the operating time in the bios?
                    I would be happy for a tip.
                    Thanks again!
                    • bpoindex
                      • Jan 2023
                      • 10
                      Panasonic CF-54 MK3 Bios Password
                      I'd like to ask forum experts to help with another password removal. This is BIOS from CF-54 MK3 using CH341. Machine will not boot to disk, only asking for password. Thank you.
                      • peste
                        • 12346
                        • ROMANIA
                        #191
                        Re: Panasonic CF-54 MK3 Bios Password
                        try...
                        • bpoindex
                          • Jan 2023
                          • 10
                          Thank you, the password is removed. I do not know if related but appears the BIOS update (from L17 to L25) is hanging at reboot from Windows. Getting longer than usual pause before Aptio Setup BIOS update screen, warns about not shutting down and then does not proceed update nor reboot. Any ideas?
                          • bpoindex
                            • Jan 2023
                            • 10
                            Have tried the L25 BIOS update three times, same behaviour with stopping at update screen.
                            These two updates worked:
                            -Embedded Controller V3.00L13 to V3.00L14
                            -ME Firmware 11.8.60.3561 to 11.8.82.3838
                            Also, I notice under Panasonic PC Setting Utility / PC Information Viewer / Setup the line :
                            BIOS V3.00L17
                            BIOS Configuration 0014-FFFF-00D5
                            Sample ID ÿÿÿÿÿÿÿÿÿÿÿÿÿÿ < Do not see this line on similar machine
                            Embedded Controller V3.00L14
                            • adroidk
                              • Nov 2020
                              • poland
                              #194
                              Originally posted by hoaca388
                              Here
                              Hello everyone.
                              Is there anyone here to help me unlock bios password and hard drive password on Panasonic Toughbook CF-54CU005E2?
                              • peste
                                • 12346
                                • ROMANIA
                                #195
                                Originally posted by adroidk
                                Hello everyone.
                                try..
                                • adroidk
                                  • Nov 2020
                                  • poland
                                  #196
                                  Originally posted by peste
                                  try..
                                  The patient is alive! Hard drive still locked. Bios works flawlessly! Great bows and thanks. ziękuję:
                                  • bpoindex
                                    • Jan 2023
                                    • 10
                                    Originally posted by AAAC
                                    @bpoindex
                                    @AAAC or other expert, can you please explain “clean ME region”? On my cf-54 mk3 (which password was removed but cannot update bios), I will attempt to copy updated bios from similar machine, changing serial number and cleaning ME region. Thank you.
                                    • AAAC
                                      • Jan 2020
                                      • 457
                                      • Mexico
                                      #198
                                      @bpoindex
                                      Some laptops have a custom BIOS for a Service Center for example, these have hard-coded passwords sometimes, so you must use the same BIOS. Don't know if it's your case, but check the laptop bottom cover and do a web search of the complete model number.
                                      • bpoindex
                                        • Jan 2023
                                        • 10
                                        @bpoindex
                                        Did not find much on CF-54J2878VM search except offer for Russian BIOS chip. The sibling purchased with this one had no password, same model but take BIOS update fine. I'm considering copying BIOS from one of these
                                        • bpoindex
                                          • Jan 2023
                                          • 10
                                          In process…one question, is it required to write protect when finished copying? If so what value should SREG contain? Thank you
                                          • outsider
                                            Panasonic FZ-G1 MK5 - BIOS password returning
                                            by outsider
                                            Hello
                                            I removed the BIOS password thanks to the help of one of the friends of this forum.
                                            https://www.badcaps.net/forum/troubl...61#post3637661
                                            The batch from which the password was removed works correctly but... after some time, the BIOS password is set again, I reprogrammed the batch with the removed password, it's ok, there is no password, I set my password, ok, I can enter the BIOS with my password but...
                                            06-17-2025, 12:51 AM
                                          • zenius
                                            by zenius
                                            12-08-2024, 06:13 AM
                                          • traxformania
                                            TONGFANG "GM7TG7P" Bios Password Problem?
                                            by traxformania
                                            I'm using TONGFANG "GM7TG7P" model laptop for over 3 years and i'm entering the same bios administrator password everyday. My laptop has Aptio BIOS (American Megatrends, AMI).
                                            But today it's not accepting my password. I'm %100 sure i'm entering the correct password.
                                            I'm trying to reset my bios without success.
                                            I tried :
                                            -I removed the BIOS battery and main battery. Waited for a long time but it didn't work. They already stated in the user manual that the password will not be reset even if the batteries...
                                            11-15-2023, 07:32 AM
                                          • Nopslide
                                            HP Omen 15-dh0052nf power-on & bios password
                                            by Nopslide
                                            Hello everyone, I come here to tell you my problem regarding the power-on password. It is not a bios reset demand, and i can't have any access to windows. This is the bios and power-on password that is blocking all other things.
                                            My Omen 15-dh0052nf purchased second-hand was configured with the bios password upon purchase (very simple password :P ).
                                            Having decided to sell it in order to get something more powerful, I reset all BIOS settings and set a blank administrator password. But the power-on password cannot be changed to a blank one so I let the actual password set....
                                            04-01-2024, 04:27 PM
                                          • AquaMan Ua
                                            Problem with PANASONIC CF53 laptop after changing BIOS settings
                                            by AquaMan Ua
                                            Hello. I am asking you for a hint on how to solve the problem with my touchbook Panasonic CF53-2 standart model. After setting up the BIOS, the laptop displays the wrong image until Windows loads. (More precisely, it displays, but distorted, instead of the Panasonic image immediately after turning it on, it displays what is in photo #1 in the attached file) Then the image appears when Windows starts loading and then there are no problems with the screen until the reboot. If you enter the BIOS, just a black screen. If you connect an external screen, the image on it is the same as on the built-in...
                                            05-17-2025, 09:40 AM
