Panasonic CF-54 Bios Password
  • Milchgl_s
    • Sep 2025
    • 6
    • Deutschland
    #641
    my fault, bin size was 12 bit to big and it somehow messed it up. Tried other bin now i got into the bios. Wrong Model and Serial Nummer but its booting into bios so far.
    • peste
      • 13793
      • ROMANIA
      #642
      try again..
      • Milchgl_s
        • Sep 2025
        • 6
        • Deutschland
        #643
        So after i found out my read with the clamp was faulty I found another one with the same Modelnumber. Now its working with a other Serialnumber. Does somebody know Where in the Bin can I find the serial to change it? Best Regards
        • javimoro
          • Sep 2025
          • España
          #644
          Hi. I need the password for:
          CF-54CU005E2
          5JTCA29484
          • peste
            • 13793
            • ROMANIA
            #645
            CF-54CU005E2
            5JTCA29484
            post the original contents of the bios chip..
            • javimoro
              • Sep 2025
              • España
              #646
              This is what I have achieved by entering user mode.
              • peste
                • 13793
                • ROMANIA
                #647
                The bios chip must be unsoldered from the board before writing or reading..
                do not use the clip, you may have errors..if you do not have anything to unsolder it with,
                solder wires between the programmer and the bios chip..
                you need an SPI programmer...here is a video for example..https://www.youtube.com/watch?v=DWWi...nnel=ThisIsHow
                • sonsy
                  • Mar 2017
                  • 71
                  • Serbia
                  #648
                  Greetings. I have one panasonic cf-54 mk2 with locked bios. After the fill with 00 field after amitsesetup, the bios unlocks, but I have a problem with charging the battery and recognizing the capacity. If someone can unlock this bios for me in some other way than the classic deletion of the field under amitsesetup, I would be grateful. Here is the bios dump:​
                    SMDFlea commented
                    Editing a comment
                    The Serial number,SNID or Service Tag must be posted with every bios request !
                • sonsy
                  • Mar 2017
                  • 71
                  • Serbia
                  #649
                  Here is serial number: 9ATCC02984
                  MODEL NUMBER: CF-54EY147TG
                  ORIGINAL bios dump:​
                  • shiyab
                    • Sep 2023
                    • 1658
                    • india
                    #650
                    ORIGINAL bios dump:
                    hi try
                    • sonsy
                      • Mar 2017
                      • 71
                      • Serbia
                      #651
                      Originally posted by shiyab
                      hi try
                      Thank you friend for your effort. I writed this bios but it makes no difference to my dump where I deleted all fields under amitsesetup. Maybe it's a coincidence that the battery suddenly started causing problems, that it's not a matter in the bios.
                      • Maxpower3
                        Bad Veteran
                        • Feb 2018
                        • 1356
                        • France
                        #652
                        If the covers are not in place, the battery will not work on some Panasonics.
                        • sedat88
                          • Jul 2025
                          • 15
                          • Deutschland
                          #653
                          hey guys i need hgelp i reset passwort myself but but my panasonic cf 54 dont boot anymore.
                          can anybody check my file?
                          Model: CF-54DY024NG
                          S/N: 6DTSA61616
                          • shiyab
                            • Sep 2023
                            • 1658
                            • india
                            #654
                            Model: CF-54DY024NG
                            S/N: 6DTSA61616
                            hi try
                            • sedat88
                              • Jul 2025
                              • 15
                              • Deutschland
                              #655
                              hi try
                              thank u i burn my chip....
                              • mazharhussain
                                • Jul 2025
                                • 8
                                • UNITED KINGDOM
                                #656
                                Hi Team please help me unlock this file for
                                panasonic cf-52
                                MODEL NUMBER: CF-52VDC1FDE
                                SEIAL NUMBER: 3ETCA66448
                                kind regards,
                                mazhar.
                                • danito
                                  • Jun 2016
                                  • 1198
                                  #657
                                  panasonic cf-52
                                  kind regards,
                                  mazhar.
                                  try
                                  • imran421
                                    • Apr 2020
                                    • 83
                                    please remove the bios password
                                    cf-54F5
                                    SN 8FTTA40956
                                    • sedat88
                                      • Jul 2025
                                      • 15
                                      • Deutschland
                                      #659
                                      Here try...
                                      • Maxpower3
                                        Bad Veteran
                                        • Feb 2018
                                        • 1356
                                        • France
                                        #660
                                        cf-54F5
                                        SN 8FTTA40956
                                        try
                                        sedat88
                                        Winols cleaned too much
                                        +50 horsepower but risk of breaking a connecting rod
                                        Click image for larger version  Name:	image.png Views:	0 Size:	9.7 KB ID:	3744779
                                        • outsider
                                          Panasonic FZ-G1 MK5 - BIOS password returning
                                          by outsider
                                          Hello
                                          I removed the BIOS password thanks to the help of one of the friends of this forum.
                                          https://www.badcaps.net/forum/troubl...61#post3637661
                                          The batch from which the password was removed works correctly but... after some time, the BIOS password is set again, I reprogrammed the batch with the removed password, it's ok, there is no password, I set my password, ok, I can enter the BIOS with my password but...
                                          06-17-2025, 12:51 AM
                                        • zenius
                                          by zenius
                                          12-08-2024, 06:13 AM
                                        • traxformania
                                          TONGFANG "GM7TG7P" Bios Password Problem?
                                          by traxformania
                                          I'm using TONGFANG "GM7TG7P" model laptop for over 3 years and i'm entering the same bios administrator password everyday. My laptop has Aptio BIOS (American Megatrends, AMI).
                                          But today it's not accepting my password. I'm %100 sure i'm entering the correct password.
                                          I'm trying to reset my bios without success.
                                          I tried :
                                          -I removed the BIOS battery and main battery. Waited for a long time but it didn't work. They already stated in the user manual that the password will not be reset even if the batteries...
                                          11-15-2023, 07:32 AM
                                        • longmt1990
                                          Panasonic Cf-w5 bios password remove
                                          by longmt1990
                                          Hi, i have a Panasonic Cf-W5 with the bios password, I tried remove cmos but problem didnot solve.
                                          I uploaded the picture after remove cmos battery, It look like this is a Phoenix bios. The bios dump file in the link i attached
                                          Please help me remove bios password.
                                          Thank you so much
                                          07-06-2025, 10:50 PM
                                        • Nopslide
                                          HP Omen 15-dh0052nf power-on & bios password
                                          by Nopslide
                                          Hello everyone, I come here to tell you my problem regarding the power-on password. It is not a bios reset demand, and i can't have any access to windows. This is the bios and power-on password that is blocking all other things.
                                          My Omen 15-dh0052nf purchased second-hand was configured with the bios password upon purchase (very simple password :P ).
                                          Having decided to sell it in order to get something more powerful, I reset all BIOS settings and set a blank administrator password. But the power-on password cannot be changed to a blank one so I let the actual password set....
                                          04-01-2024, 04:27 PM
