hp pavilion x360 bios bin need
  • m1ch43lzm
    • Mar 2019
    • 1126
    • Peru
    #281
    Originally posted by kamkooltech
    can some one help me extract this file, i downloaded it from hp and my system complained fail to extract
    it for
    board number: DUCKY TGL UMA 203035-2 448.0MM04.0021
    S/N;8CG1323X5H
    How to extract: https://www.badcaps.net/forum/troubl...-file?t=121948
    How to find right BIOS version: https://www.badcaps.net/forum/troubl...flash?t=122195
    In short for the 2nd guide: search for $BID with hex editor
    What you need is BID 088BC, HP for whatever reason mixed BIOS updates for AMD and Intel on the same page, you have to expand the category "BIOS-System Firmware", then "HP Notebook System BIOS Update (Intel Processors)" , the other BIOS updates under "BIOS" category are for "HP Notebook System BIOS Update (AMD Processors)"
    Of course you shouldn't flash a BIOS for AMD CPU on an Intel CPU laptop (yours is Intel)...
    The correct BIOS is sp163283.exe
    Run the .exe, It will extract several variants, yours is 088BC.bin
    DMI is empty on yours (no model name, SKU, build ID, feature byte), it only has a Win key, is it a replacement motherboard? I transfered it anyway, you should fill the rest with BCU
    Here it is, with your Win key inserted
    HP Pavilion x360 Convertible 15-er0077nr (33K64UA)
    BID 088BC
    DMI 500000-50103F
    BIOS ver. F.28
    Fill the rest with HP BCU
    Code:
    Serial Number :  8CG1323X5H
    SKU Number :  33K64UA#ABA
    Product name:  HP Pavilion x360 Convertible 15-er0xxx
    Feature byte: 3K6b7K7MaBapaqasawbCbVbhcbdUdpdqfPhZm9.BG
    Build ID: 21WWDU1T603#SABA#DABA
    Board CT number: (on a sticker on the motherboard CT: )
    Additional info: sp163057.exe extracts fine on my HP laptop, it extracts 088F1.bin but it isn't the correct BIOS for you anyway (it's for AMD CPU, Ryzen 4000 series - Renoir)...
    When you can't extract an HP BIOS update, you can try running it on a virtual machine
    • kamkooltech
      kamkooltech
      • Jun 2019
      • 132
      • nigeria
      #282
      BID 088BC
      DMI 500000-50103F
      BIOS ver. F.28
      Code:
      thank you very much my brother
      • mainah njoroge
        • Aug 2017
        • 38
        • kenya
        #283
        Hallo can someone clear password for my file for
        hp pavillion x360 14-es0033dx
        sn 8CG3463P7H
        Nittany RPL 8L 213224-1Q
        • peste
          • 13924
          • ROMANIA
          #284
          sn 8CG3463P7H
          bios extracted from HP website update for HP ENVY x360 2-in-1 Laptop 14-es0033dx (7H9Y1UA)
          DMI + KEYWIN 680000 - 68103F
          • mainah njoroge
            • Aug 2017
            • 38
            • kenya
            #285
            the above file keyboard doesnt respont all keboard keys pliss clear my password
            • m1ch43lzm
              • Mar 2019
              • 1126
              • Peru
              #286
              Try, BIOS extracted from HP website, DMI inserted
              BID 08BF7
              BIOS ver. F.09
              S/N 8CG3463P7H
              If keyboard doesn't work properly, check for hardware problem
