Hi guys, I'm kinda new in the board level repair stuff. I recently did a bios flash on an asus laptop and a clean install of windows 10 but I don't have a key for it. From what I understand, the windows key is now embedded in the bios. I still have a dump of the old bios. Is there a way to extract the key? Or if I'm way off please help enlighten me
Bios : embedded windows key question
Re: Bios : embedded windows key question
ShowKeyPlus should work
http://m.majorgeeks.com/files/details/showkeyplus.html -
Post the original bios backup ,and tell us what the laptop model number is.Comment
I can try and pull it out of the BIOS dump. Ive not tested my method on 10 though.Things I've fixed: anything from semis to crappy Chinese $2 radios, and now an IoT Dildo....
Follow the white rabbit.Comment
just google
https://superuser.com/questions/6379...ux-environment
see the commentsComment
Simply take the old/original dump and then open it up in a good Hex Editor that supports wild card searches so then do something like this.Hi guys, I'm kinda new in the board level repair stuff. I recently did a bios flash on an asus laptop and a clean install of windows 10 but I don't have a key for it. From what I understand, the windows key is now embedded in the bios. I still have a dump of the old bios. Is there a way to extract the key? Or if I'm way off please help enlighten me
?????-?????-?????-?????-????? that is the wild card search. The key should pop right out
Done this so many times.
What I do is I usually put the old/original key in the same place as the old one so that the original key is with the new flashed bios. Sometimes its not that easy you have to redo checksums but sometimes it just works.... Getting it out is simple.
I think neoEditor on windows had wildcard search but its a 30days free software i think....
Goodluckwhile alive { live(toFullest=true) }Comment
Theres a good post on elvikom about recovering win 8 keys. https://www.elvikom.pl/sposob-na-uzy...os-t35874.htmlComment
Thank you all for your replies. I downloaded ultra edit and found the key at line 00223ae0h for the asus x541u. Unfortunately the new windows install rejected the key. I read somewhere that it's not enough to simply have the key. You also also need a backup of the encrypted MSDM table. This case was for a different computer but I'm guessing it applies globally to Windows 8+. Anyhow I'm not motivated enough to figure how to combine the 2 firmwares I have to get the key working. This was a cheap computer I picked up on craigslist to get my hands dirty. I was able to desolder the bios chip, read it, program it and solder it back on and got it booting. I'm happy with the result. Cheers
Edit: I've attached the original bios dump for any of the curiousAttached Filesif you find these attachements useful please consider making a small donation to the site
You just needed to put the key at line 00223ae0h in the new bios.Comment
by Vesko356First of all thanks to all of our members who have posted previously all methods posted here.
Operating system and OS version.If...-
Channel: BIOS Requests ONLY!
by abel2bCan someone teach me how to edit New *.bin with DMI and Windows Keys from broken bios.
where should I look (OFFSET) in old dump?
What must be copied to make new functional bios?
MY machine is:
HP 14-DQ1004LA
S.N: 5CD0080M17
Background: Tea was spilled on my notebook accidently I imediatly, turned off, unplugged and opened to disconnect battery, I cleaned everything thoroughly, I checked all power supply coils for shorts and all good, except Vcore coil ohms at 0.1 ohms, but I searched around and it seems it is ok. I powered up the board , and all voltages...-
by 0xxHi folks,
My son clicked “Update and Shutdown” on a Razer Blade 14 (2022, RZ09-0427), closed the lid, disconnected the charger, and put the laptop in his backpack. The next day, it wouldn’t boot: only the green LED blinked, no fans, no keyboard backlight, no display. The chassis does get warm, so the CPU/GPU seems to get power.
What I’ve tried so far: disconnecting the main battery, CMOS reset with power drain (30s), using a different power adapter, and connecting to the monitor - same result.
I assumed that Windows Update was interrupted due to closing... -
by iZakreHello everybody!
To put you in context I recently replaced the battery from my HP Pavilion 15 bc400ns with a used one, everything was going good. The same day, I decided to update the BIOS, everything went good. The thing occurred after I let the battery drain iddling on Windows 11 for the second time to calibrate it that the screen did not turn on again, the computer was on but the screen did not turn, like it would not wake from hibernation. I decided to restart the computer but got no video.
The thing is that I had installed TeamViewer and could log into the computer... -
by jbonavitaHi, my laptop wont boot at all
Some issues
Things I tried
1- Update / clear ME: Took the non working bios, made a backup, and did this: https://www.badcaps.net/forum/troubl...theory/trouble...-
- Loading...
