Bios : embedded windows key question
  • vanrepair
    • Oct 2018
    • 10
    • canada
    Hi guys, I'm kinda new in the board level repair stuff. I recently did a bios flash on an asus laptop and a clean install of windows 10 but I don't have a key for it. From what I understand, the windows key is now embedded in the bios. I still have a dump of the old bios. Is there a way to extract the key? Or if I'm way off please help enlighten me Thanks
  • vinceroger69
    • Mar 2012
    • 6714
    Re: Bios : embedded windows key question
    ShowKeyPlus should work
    http://m.majorgeeks.com/files/details/showkeyplus.html
    • vanrepair
      • Oct 2018
      • 10
      • canada
      Thanks for the reply. Unfortunately I don't have the hd with the original windows install. I only have the bios dump I took before I flashed the new bios. That utility won't help me out.
        • 20561
        Post the original bios backup ,and tell us what the laptop model number is.
        • goontron
          5000!
          • Dec 2011
          • 4108
          • US
          I can try and pull it out of the BIOS dump. Ive not tested my method on 10 though.
          Follow the white rabbit.
          • petehall347
            • Jan 2015
            • 4426
            • United Kingdom
            is there not a sticker like in the olden days ?
            • ktmmotocross
              Boardkiller
              • Feb 2014
              • 3574
              • slovakia
              just google
              https://superuser.com/questions/6379...ux-environment
              see the comments
              • mcplslg123
                • Jun 2015
                • 7262
                • india
                with win8 and 10, there is no serial number sticker anymore. Those good days ended with win7.
                • MJ-meo-dmt
                  • May 2016
                  • 186
                  • South Africa
                  Simply take the old/original dump and then open it up in a good Hex Editor that supports wild card searches so then do something like this.
                  ?????-?????-?????-?????-????? that is the wild card search. The key should pop right out Done this so many times.
                  What I do is I usually put the old/original key in the same place as the old one so that the original key is with the new flashed bios. Sometimes its not that easy you have to redo checksums but sometimes it just works.... Getting it out is simple.
                  I think neoEditor on windows had wildcard search but its a 30days free software i think....
                  Goodluck
                  while alive { live(toFullest=true) }
                    • 20561
                    Theres a good post on elvikom about recovering win 8 keys. https://www.elvikom.pl/sposob-na-uzy...os-t35874.html
                    • vanrepair
                      • Oct 2018
                      • 10
                      • canada
                      Thank you all for your replies. I downloaded ultra edit and found the key at line 00223ae0h for the asus x541u. Unfortunately the new windows install rejected the key. I read somewhere that it's not enough to simply have the key. You also also need a backup of the encrypted MSDM table. This case was for a different computer but I'm guessing it applies globally to Windows 8+. Anyhow I'm not motivated enough to figure how to combine the 2 firmwares I have to get the key working. This was a cheap computer I picked up on craigslist to get my hands dirty. I was able to desolder the bios chip, read it, program it and solder it back on and got it booting. I'm happy with the result. Cheers
                      Edit: I've attached the original bios dump for any of the curious
                        • 20561
                        You just needed to put the key at line 00223ae0h in the new bios.
                        • palady
                          • Jan 2014
                          • 20
                          • si
                          search HEX pattern:
                          01 00 00 00 00 00 00 00 01 00 00 00 00 00 00 00 1D 00 00 00
                          • Vesko356
                            by Vesko356
                            08-11-2023, 03:27 AM
                          • abel2b
                            Hello, Can anybody help with how to recover DMI and Windows Key from HP 14-DQ1004LA Bios
                            by abel2b
                            Can someone teach me how to edit New *.bin with DMI and Windows Keys from broken bios.
                            where should I look (OFFSET) in old dump?
                            What must be copied to make new functional bios?
                            MY machine is:
                            HP 14-DQ1004LA
                            S.N: 5CD0080M17
                            Background: Tea was spilled on my notebook accidently I imediatly, turned off, unplugged and opened to disconnect battery, I cleaned everything thoroughly, I checked all power supply coils for shorts and all good, except Vcore coil ohms at 0.1 ohms, but I searched around and it seems it is ok. I powered up the board , and all voltages...
                            06-30-2025, 09:54 AM
                          • iZakre
                            HP Pavilion 15 bc400ns - Complete Black Screen - Only video on live usb
                            by iZakre
                            Hello everybody!
                            To put you in context I recently replaced the battery from my HP Pavilion 15 bc400ns with a used one, everything was going good. The same day, I decided to update the BIOS, everything went good. The thing occurred after I let the battery drain iddling on Windows 11 for the second time to calibrate it that the screen did not turn on again, the computer was on but the screen did not turn, like it would not wake from hibernation. I decided to restart the computer but got no video.
                            The thing is that I had installed TeamViewer and could log into the computer...
                            02-19-2023, 02:27 PM
                          • jbonavita
                            by jbonavita
                            Some issues
                            Things I tried
                            04-29-2025, 09:38 PM
                          • zenius
                            by zenius
                            12-08-2024, 06:13 AM
