Dell xps 9343 bios
  • bachir2004
    • Feb 2015
    • 437
    • maroc
    Dell xps 9343 bios
    Anyone,please has a dump for dell xps 9343?cannot manage to have the bios from hdr file.attached dump,dell bios update and hdr file.
    • 20737
    Re: Dell xps 9343 bios
    Try this bios,it has the extracted hdr bios update merged with your dump,and ME ver 10.0.55.3000 .Flash the bios again from the exe if you want to update the ME to 10.0.55.3002 .
    • bachir2004
      • Feb 2015
      • 437
      • maroc
      thanks,i will try it.
      • bachir2004
        • Feb 2015
        • 437
        • maroc
        Problem solved,merged original dump with extracted bios from yours.weird but this unit came with 8 beeps (lcd screen fault).it is the second dell with the same fault fixed this way(first one was was a vostro second generation)many thanks smdflea!!!
        • balobi
          • Jan 2015
          • 88
          • phillippines
          helpbuid or cleanme on dell XPS 13 9343 la-b441p r1.0 bios
          need build or cleanme on dell xps 13 9343 la-b441p r1.0 bios
          model: dell xps 13 9343
          service tag#: GZ48Z52
          board code: la-b441p r1.0 bios
          issue: no display
          auploaded file is the orig bin file with no display.
          many thanks in advance.
          • hoaca388
            Badcaps
            • Jan 2022
            • 11661
            Re: helpbuid or cleanme on dell XPS 13 9343 la-b441p r1.0 bios
            model: Dell xps 13 9343
            service tag#: Gz48z52
            board code: La-b441p r1.0 bios
            issue: No display
            Many thanks in advance.
            xps 13 9343
            • brontobyte
              • Jul 2021
              • 85
              • Romania
              Dell XPS 13 9343 P54G / La-b441p Bios request
              Hello friends,
              I have some issues with XPS 13
              Motherboard la-b441p rev 1.0
              I have no display, caps-lock works, display test works.
              I think there's a bios or cpu issue.
              Service TAG: 6CPR462
              • hoaca388
                Badcaps
                • Jan 2022
                • 11661
                Re: Dell XPS 13 9343 P54G / La-b441p Bios request
                Originally posted by brontobyte
                hello friends,
                i have some issues with xps 13
                motherboard la-b441p rev 1.0
                i have no display, caps-lock works, display test works.
                Service tag: 6cpr462
                xps 13 9343
                • brontobyte
                  • Jul 2021
                  • 85
                  • Romania
                  Thanks! Is not working. maybe is another problem
                  • hardware1
                    • Sep 2021
                    • 2930
                    • N/A
                    Try this one.
                    all donations are welcome,
                    • dqtech
                      Badcaps
                      • Jul 2018
                      • 630
                      • N/A
                      thank you
                      • chinsuckseed
                        • Dec 2022
                        • 9
                        • Thailand
                        KIndly help mod DELL XPS 9343 from my dump to support NVME boot would be highly appreciated, BEST REGARDS CHIN https://drive.google.com/file/d/1TKs...usp=share_link
                        • chinsuckseed
                          • Dec 2022
                          • 9
                          • Thailand
                          I have already attached DXE file but i can't modify via UEFITool cuz of "checkProtectedRanges: AMI protected range [2A0000h:5E1600h] hash mismatch, opened image may refuse to boot" BIOS VERSION A20 MTKS. and APRRECIATED
                          • nusch
                            • Jan 2024
                            • Poland
                            SPI dump attached, Service tag: 382M893, board LA-J143P
                            the 3 orange LED blinks happening. Initially the computer'st BIOS self detected corruption of itself and attempted to recover. However it was failing at the very end mentioning it can't downgrade. I indeed disabled downgrade possibility in past but don't understand the reason was this should prevent flashing with same version. Neither full self-revovery or providing it on USB worked and after some attempts it corrupted completely.
                            The verified dump attached, BIOS section is completely broken, - at its offset it seems to be overwriten with the same content at 0x00 so UEFI Tool or any other doesn't recognize it at all. I'm looking for fixed image preserving service tag and other custom things but also toward understanding what could cause above issues.
                            Also before all above the bootloader on NVMe disk got corrupted, wondering how can I assure this is not hardware issue
                            Regards
                            Badcaps Electronics Repair Forum & Schematic Search
                              SMDFlea commented
                              Editing a comment
                              Thread merged,attachment added. Link removed. Post the laptop service tag
                              You MUST:
                              • Provide the full machine model number, serial number (or Service tag, SNID) and the board model number (see https://www.badcaps.net/forum/showthread.php?t=88758 ) ,The serial number, make, full model number, motherboard model and revision (except QR codes) must be written/typed at your request as per the rules. Not as a picture, part of the file name and so on.
                          • hoaca388
                            Badcaps
                            • Jan 2022
                            • 11661
                            Regards
                            XPS 13 9310
                            • mikeybass
                              by mikeybass
                              04-23-2025, 04:30 PM
                            • trix11
                              Dell Precision T1650 MT Workstation bricked after BIOS update
                              by trix11
                              I have a Dell Precision T1650 MT workstation (of the following spec.) that was bricked yesterday when attempting to update the BIOS from A27 to A28 per:
                              - https://www.dell.com/support/home/en...-t1650/drivers > Dell Precision T1650 System BIOS
                              - Dell Precision T1650 mid tower Workstation
                              - Xeon E3-1225 V2
                              - 32Gb PC3-12800E RAM
                              - 4Tb SATA HDD
                              - motherboard: Dell part: 0C3YXR CN-0C3YXR-72200-39C-01GR-A02
                              I see now that others have experienced like issues e.g.:
                              - https://www.dell.com/community/Prec...
                              10-24-2022, 10:35 PM
                            • lalle-
                              Dell G5 SE 5505 - "Invalid memory installed" after BIOS update.
                              by lalle-
                              Hello!
                              I have a problem with a Dell G5 SE 5505 laptop that I hope someone can give me a few pointers on.
                              [OK, it's not really a laptop, I'm running the motherboard on my desktop with only cooling, RAM and an M2 drive attached.]
                              I had some performance issues, so I decided to update my BIOS from 1.7.0 to the latest version, 1.20.0.
                              The computer restarted and the update dit not want to continue without a battery connected, even though I used dell's method of bypassing this requirement.
                              I tried updating to a custom BIOS from Reddit user Satori_Nori https://www...
                              08-11-2024, 02:01 PM
                            • zenius
                              by zenius
                              12-08-2024, 06:13 AM
                            • Julian Bailey
                              BIOS update wont complete - Dell Latitude 7420
                              by Julian Bailey
                              Hi all
                              Anyone come across this issue where a BIOS flash will only part complete?
                              It will update the system BIOS and Primary EC BIOS fine but fails to update the Intel TBT Retimer, Intel TBT Retimer 2 and ME Firmware.
                              NVMe m.2 drive isnt detected in the BIOS, but you can get into the BIOS fine and it all works in there as intended.
                              The drive works fine in another laptop.
                              Link to a video I made of what its doing here:
                              Any ideas on how to overcome this?
                              Cheers...
                              06-02-2025, 01:39 PM
