Dell xps 9343 bios
Dell xps 9343 bios
Anyone,please has a dump for dell xps 9343?cannot manage to have the bios from hdr file.attached dump,dell bios update and hdr file.Tags: None -
Re: Dell xps 9343 bios
Try this bios,it has the extracted hdr bios update merged with your dump,and ME ver 10.0.55.3000 .Flash the bios again from the exe if you want to update the ME to 10.0.55.3002 .Attached Filesif you find these attachements useful please consider making a small donation to the site
Problem solved,merged original dump with extracted bios from yours.weird but this unit came with 8 beeps (lcd screen fault).it is the second dell with the same fault fixed this way(first one was was a vostro second generation)many thanks smdflea!!!Comment
helpbuid or cleanme on dell XPS 13 9343 la-b441p r1.0 bios
need build or cleanme on dell xps 13 9343 la-b441p r1.0 bios
model: dell xps 13 9343
service tag#: GZ48Z52
board code: la-b441p r1.0 bios
issue: no display
auploaded file is the orig bin file with no display.
many thanks in advance.
Re: helpbuid or cleanme on dell XPS 13 9343 la-b441p r1.0 bios
xps 13 9343Attached Filesif you find these attachements useful please consider making a small donation to the site
https://www.badcaps.net/donateComment
Dell XPS 13 9343 P54G / La-b441p Bios request
Hello friends,
I have some issues with XPS 13
Motherboard la-b441p rev 1.0
I have no display, caps-lock works, display test works.
I think there's a bios or cpu issue.
Service TAG: 6CPR462Attached Filesif you find these attachements useful please consider making a small donation to the site
Re: Dell XPS 13 9343 P54G / La-b441p Bios request
Thanks! Is not working. maybe is another problemComment
Try this one.Attached Filesif you find these attachements useful please consider making a small donation to the site
all donations are welcome,
>>>>> click on this link to donate via PayPal. <<<<<
----------------------------------------------------------------------------------------------------------------------------------------------------------------------Comment
KIndly help mod DELL XPS 9343 from my dump to support NVME boot would be highly appreciated, BEST REGARDS
CHIN https://drive.google.com/file/d/1TKs...usp=share_link
I have already attached DXE file but i can't modify via UEFITool cuz of "checkProtectedRanges: AMI protected range [2A0000h:5E1600h] hash mismatch, opened image may refuse to boot" BIOS VERSION A20 MTKS. and APRRECIATEDComment
SPI dump attached, Service tag: 382M893, board LA-J143P
the 3 orange LED blinks happening. Initially the computer'st BIOS self detected corruption of itself and attempted to recover. However it was failing at the very end mentioning it can't downgrade. I indeed disabled downgrade possibility in past but don't understand the reason was this should prevent flashing with same version. Neither full self-revovery or providing it on USB worked and after some attempts it corrupted completely.
The verified dump attached, BIOS section is completely broken, - at its offset it seems to be overwriten with the same content at 0x00 so UEFI Tool or any other doesn't recognize it at all. I'm looking for fixed image preserving service tag and other custom things but also toward understanding what could cause above issues.
Also before all above the bootloader on NVMe disk got corrupted, wondering how can I assure this is not hardware issue
RegardsAttached Filesif you find these attachements useful please consider making a small donation to the site
Badcaps Electronics Repair Forum & Schematic SearchLast edited by nusch; 04-18-2024, 04:15 AM.Comment
Thread merged,attachment added. Link removed. Post the laptop service tag
RULES UPDATE for BIOS requests/offers AVOID BANNING, READ BEFORE POSTING
You MUST:- Provide the full machine model number, serial number (or Service tag, SNID) and the board model number (see https://www.badcaps.net/forum/showthread.php?t=88758 ) ,The serial number, make, full model number, motherboard model and revision (except QR codes) must be written/typed at your request as per the rules. Not as a picture, part of the file name and so on.
XPS 13 9310SPI dump attached, Service tag: 382M893, board LA-J143P
Regards
by capoplaysHey everyone,
I recently bought a Dell G15 5515 with an AMD Ryzen 7 5800H and 3060 RTX. The BIOS chip on it was dead, and my hardware guy replaced the chip. After that, everything was working fine.
The BIOS is currently at version 1.22.1, and I wanted to update it. I downloaded the latest BIOS version from Dell Support using my ST: FQZMYJ3, but when I tried to run it, it says "unsupported system." I asked my tech guy what he did, and he said he took the chip from another board and flashed it onto mine.
When I check the BIOS using the F12 menu Flash...-
Channel: BIOS Requests ONLY!
by mikeybassHi, I hope some one has some advice for me. I searched the forums but didn't see anything relevant. I acquired two identical Dell 9010 Mid Tower computers from a business office upgrade (they were going to throw them out). Both of them have the same motherboard (00F82W). One of them works flawlessly. The other one had a corrupted BIOS. I tried flashing numerous main BIOS and EC files from the internet, but none of them worked. I decided to copy the main BIOS and EC from the working 9010 computer and successfully flashed the corrupted BIOS. This got the computer able to boot again and run norm...
04-23-2025, 04:30 PM -
by trix11I have a Dell Precision T1650 MT workstation (of the following spec.) that was bricked yesterday when attempting to update the BIOS from A27 to A28 per:
- https://www.dell.com/support/home/en...-t1650/drivers > Dell Precision T1650 System BIOS
- Dell Precision T1650 mid tower Workstation
- Xeon E3-1225 V2
- 32Gb PC3-12800E RAM
- 4Tb SATA HDD
- motherboard: Dell part: 0C3YXR CN-0C3YXR-72200-39C-01GR-A02
I see now that others have experienced like issues e.g.:
- https://www.dell.com/community/Prec...-
by lalle-Hello!
I have a problem with a Dell G5 SE 5505 laptop that I hope someone can give me a few pointers on.
[OK, it's not really a laptop, I'm running the motherboard on my desktop with only cooling, RAM and an M2 drive attached.]
I had some performance issues, so I decided to update my BIOS from 1.7.0 to the latest version, 1.20.0.
The computer restarted and the update dit not want to continue without a battery connected, even though I used dell's method of bypassing this requirement.
I tried updating to a custom BIOS from Reddit user Satori_Nori https://www... -
- Loading...
