Asus X205TA Bios Lock
  • Murtaza527
    • May 2018
    • 257
    • Malaysia
    this is his orignal with administrator password
  • Andrew_R
    Banned
    • Jun 2018
    • 91
    • Poland
    Re: Asus X205TA Bios Lock
    Password is :
    - Admin Password - 2**0
    Check PM .
    • Murtaza527
      • May 2018
      • 257
      • Malaysia
      thanks
      • weslay
        • Sep 2017
        • 31
        • France
        Hello
        The binary offered by MURTAZA 527 is not suitable for my laptop.
        I am looking for a Bios with Admin pass for ASUS X205TAW.
        The current bios is 203 as of 04/23/2019.
        I cannot install an older version with WinFlash.
        Thanks for your help.
        • peste
          • Dec 2016
          • 12973
          • ROMANIA
          Originally posted by weslay
          Hello
          post the backup copy of the original laptop bios.
          • weslay
            • Sep 2017
            • 31
            • France
            I'm not sure I understood your answer.
            I am attaching you the current bios on this laptop.
            • weslay
              • Sep 2017
              • 31
              • France
              sorry; i dont know how to attach my file.
              • weslay
                • Sep 2017
                • 31
                • France
                the link is :
                https://www.asus.com/supportonly/X205TA/HelpDesk_BIOS/
                • peste
                  • Dec 2016
                  • 12973
                  • ROMANIA
                  the bios extracted from the bios chip that the laptop has.
                  right, bottom "quote '," manage attashments "... etc ..
                  • weslay
                    • Sep 2017
                    • 31
                    • France
                    to extract the bios, I have to unsolder the chips.
                    Or do you have another solution.
                    The laptop was flashed with WinFlash under W10, bios 203 on this site:
                    Tell me if this is not enough for you
                    Thank you for your help.
                    • peste
                      • Dec 2016
                      • 12973
                      • ROMANIA
                      what you posted is the update on the site ... I can download it too, that's what I need, and you have an SPI programmer ..
                      https://www.youtube.com/watch?v=DWWigscuQDY
                        • 21201
                        So you can boot into windows ok ?
                        • weslay
                          • Sep 2017
                          • 31
                          • France
                          Yes, I have enough to unsolder and reprogram, but I wanted to avoid this solution (the equipment is in the attic ...).
                          Can't you change the bios I downloaded so I can flash with WinFlash.?
                          Maybe the protect code is not in this update section.
                          • weslay
                            • Sep 2017
                            • 31
                            • France
                            SMDFlea ......Yes I can boot on windows.
                              • 21201
                              Check if you`re running win10 32bit or 64bit - https://www.howtogeek.com/howto/2172...ndows-answers/
                              Post your full laptop model number as well
                              • weslay
                                • Sep 2017
                                • 31
                                • France
                                windows is 32bits
                                Front Label :X205TA
                                Label on PCB : 6NL0730-MB6013-210 X205TAW
                                back side label: X205TA FD0077TS
                                Aptio Setup (2013)
                                V203
                                GOP 7.2.1013
                                EC Version G5BT0C00
                                Serial : FANLCX132005427
                                  • 21201
                                  Run flash programming tool FPT from the command line with this command and post the backup in a zip or rar
                                  FPTw.exe -bios -d biosreg.bin
                                  • weslay
                                    • Sep 2017
                                    • 31
                                    • France
                                    I'm sorry, I don't understand which command to place with Fptw -......
                                    In order to retrieve the image from the bios.
                                    • weslay
                                      • Sep 2017
                                      • 31
                                      • France
                                      if I pa
                                      • weslay
                                        • Sep 2017
                                        • 31
                                        • France
                                        if I pass the command Fptw -D backup.bin
                                        Flash device Found
                                        ----------------- 8192KB
                                        then, I have an error 26
                                        • razor_amd
                                          by razor_amd
                                          12-15-2020, 07:07 PM
                                        • grimacelord
                                          by grimacelord
                                          07-10-2025, 02:52 PM
                                        • jbonavita
                                          by jbonavita
                                          Some issues
                                          Things I tried
                                          04-29-2025, 09:38 PM
                                        • throwaway327
                                          by throwaway327
                                          Model No: RC72LA
                                          Serial No: SBNVKD001014459
                                          06-18-2025, 05:52 PM
                                        • ArtMov
                                          [HELP] Asus g732lv ami bios overclocking lock reseting after reboot
                                          by ArtMov
                                          Hi guys, i have a problem , my bios resets disabled overclocking lock setting to enable after reboot, please tell me which function can be responsible for restoring the stock config for this option, loading parameters from nvram and so on, like bios ,protection, from asus. My bios made me angry) Set default parameter to disable in amibcp 5 , doesn't help(
                                          1. I made overclocking lock disabled the default in amibcp
                                          2. I changed the varoffset to the wrong one, but it led to the programmer, it was very tedious and nervous, I really regretted it, my chip is on the back of the...
                                          03-31-2023, 01:30 PM
