this is his orignal with administrator password
Asus X205TA Bios Lock
Tags: None
Re: Asus X205TA Bios Lock
Hello
The binary offered by MURTAZA 527 is not suitable for my laptop.
I am looking for a Bios with Admin pass for ASUS X205TAW.
The current bios is 203 as of 04/23/2019.
I cannot install an older version with WinFlash.
Thanks for your help.Comment
post the backup copy of the original laptop bios.Due to a lack of donations, server free space at a critical level, and possible closure of Bios Requests all donations are welcome, click:
Every donation made will go towards server fees and maintenance costs.Comment
right, bottom "quote '," manage attashments "... etc ..Due to a lack of donations, server free space at a critical level, and possible closure of Bios Requests all donations are welcome, click:
to extract the bios, I have to unsolder the chips.
Or do you have another solution.
The laptop was flashed with WinFlash under W10, bios 203 on this site:
https://www.asus.com/supportonly/X205TA/HelpDesk_BIOS/
Tell me if this is not enough for you
Thank you for your help.Comment
https://www.youtube.com/watch?v=DWWigscuQDYDue to a lack of donations, server free space at a critical level, and possible closure of Bios Requests all donations are welcome, click:
Yes, I have enough to unsolder and reprogram, but I wanted to avoid this solution (the equipment is in the attic ...).
Can't you change the bios I downloaded so I can flash with WinFlash.?
Maybe the protect code is not in this update section.Comment
Check if you`re running win10 32bit or 64bit - https://www.howtogeek.com/howto/2172...ndows-answers/
Post your full laptop model number as wellComment
Run flash programming tool FPT from the command line with this command and post the backup in a zip or rar
FPTw.exe -bios -d biosreg.binAttached FilesComment
by razor_amdWith ASUS, not everything is quite so simple. I will show you my way. It may be longer or harder but it is the right way to do it in my humble opinion.
This is the picture of 3 similar ASUS motherboards, all of them being X555LD...-
Channel: BIOS Requests ONLY!
by grimacelordHello,
Anyway, I took dumps of both chips and then downloaded the latest update for this motherboard from ASUS's website...-
by jbonavitaHi, my laptop wont boot at all
Some issues
Things I tried
1- Update / clear ME: Took the non working bios, made a backup, and did this: https://www.badcaps.net/forum/troubl...theory/trouble...-
by throwaway327ASUS ROG Ally X - (Handheld Gaming PC)
Model No: RC72LA
Serial No: SBNVKD001014459
I used a tool called 'Smokeless-UMAF' to access usually hidden settings in the bios. I tweaked one or two 'safe' things but made the mistake of tweaking a lot of settings under 'USB/Thunderbolt Configurations' when I didn't know what they did. For...-
by ArtMovHi guys, i have a problem , my bios resets disabled overclocking lock setting to enable after reboot, please tell me which function can be responsible for restoring the stock config for this option, loading parameters from nvram and so on, like bios ,protection, from asus. My bios made me angry) Set default parameter to disable in amibcp 5 , doesn't help(
1. I made overclocking lock disabled the default in amibcp
2. I changed the varoffset to the wrong one, but it led to the programmer, it was very tedious and nervous, I really regretted it, my chip is on the back of the...-
03-31-2023, 01:30 PM -
- Loading...
