Re: Macbook A1707 bios dump needed...
try..
Macbook A1707 820-00928-A bios dump needed...
Hi, can you help me pls, this bios is locked , i need to unlock it 820-00928-A, Thanks So muchAttached FilesLast edited by patocodu; 02-02-2022, 04:29 PM.Leave a comment:
Attached FilesLeave a comment:
hello brothers is it possible to clean ME of this bios? 820-00928 macbook pro, thanksAttached FilesLeave a comment:
this file at startup asks for 6-digit codeLeave a comment:
Hi, anyone has bios for macbook pro A1707 touch bar board ID: 820-00281-A ?Leave a comment:
Why the macbook when flashing the bios, is starting very slow?Leave a comment:
because the macbook when flashing the bios, is leaving very slow?Leave a comment:
I need the bios chip locationLeave a comment:
you are welcome
if you have locked bios ..post hereLeave a comment:
macbook A1707 touchbar bios dump urgently needed... board ID: 820-00928-ATags: None
by leonemax81Hi guys I have a Macbook a1707 with motherboard 820-00281, without liquid damage that behaves strangely, with the battery connected the Macbook does not turn on and the USBC meter stops at 5v in loop, when I disconnect the battery the Macbook turns on and works fine, I have already tried to replace the battery twice without success, as soon as I connect the black cable of the battery the Macbook does not turn on, it stops at 5v and in loop.
by re-atariHello all, as the title says, I'm very much in need of a valid firmware dump of a Anycubic Photon 5.5 3D resin printer. It's stored in a Winbond 25Q32, so it's 4Mbyte.
Here's a little background for my request. A few weeks ago I bought this 3D printer from a guy who had moved on to a PLA printer. I got it at a vey reasonable price, as it was in a defective state. The seller told me that he had experienced a power failure during a firmware upgrade, after which the printer appeared to be dead. He thought the firmware was corrupted in such a way that the printer was now bricked. As he... -
by soflesHello there
I have problem with Macbook Pro 15" 2017, model 2017, MB code 820-00928.
I bought it as broken with some artefacts on the screen, first I thought that this is problem with ribbon cable but after inspectiing ribbon cable I know it is fine. I tried to reinstall macOs and then I figured out that this must be something with GPU as installation freezes at the end (when drivers are loaded). I installed Windows and was able to install every each of drivers except GPU driver, as soon as I tried to install GPU driver - black screen and restart.
...11-21-2024, 05:25 AM -
by rednix01Hi everyone,
I accidentally bricked my NUC7i5BNH after disabling the option to boot from USB, and now it's not showing any display at all. I tried the USB recovery method, but unfortunately, it didn't work.
Local repair shops are quoting around $150 just to flash the EEPROM, but considering the unit is only worth about $75 these days, that’s not really an option. So I'm hoping to learn how to flash the chip myself. But to get started, I need a working BIOS dump for the NUC7i5BNH.
I did come across a post with a dump for the NUC7i7BNH, but I wasn't sure...-
by Robin21Hello,
I'm replacing NAND (Upgrade 256GB to 1TB) and need a favor from someone who have this motherboard – 820-00928. I haven't checked resistant to the ground before replacing chips and after I've placed new chips I've notice low resistance on L9370 (number 1 on my attached picture) next to the U9310 (S2FPS04X01). 0,3 - 0,2 Ohm.
If someone will be so kind and could check this resistance I'll be pleased.
Thank you in advance!... - Loading...
