Nuc7i5BNH Bios Dump Needed
  • rednix01
    • Jun 2025
    • usa
    I accidentally bricked my NUC7i5BNH after disabling the option to boot from USB, and now it's not showing any display at all. I tried the USB recovery method, but unfortunately, it didn't work.
    Local repair shops are quoting around $150 just to flash the EEPROM, but considering the unit is only worth about $75 these days, that’s not really an option. So I'm hoping to learn how to flash the chip myself. But to get started, I need a working BIOS dump for the NUC7i5BNH.
    I did come across a post with a dump for the NUC7i7BNH, but I wasn't sure if it would be compatible with my model, so I thought it’d be best to ask directly.
    If anyone has a BIOS dump or advice, I’d really appreciate the help. Thanks so much in advance!
    Best regards,
    RedNix
  • peste
    • 13678
    • ROMANIA
    Originally posted by rednix01
    Best regards,
    RedNix
    post the contents of the bios chip even if it is corrupted..
    you need an SPI programmer...here is a video for example..https://www.youtube.com/watch?v=DWWi...nnel=ThisIsHow
    post S/N, full name and model, motherboard model, etc.
    • DynaxSC
      by DynaxSC
      11-17-2023, 10:56 AM
    • TacticalFahrrad
      [REQUEST] Fujitsu Lifebook E5513 – Full BIOS Dump Needed (.bin)
      by TacticalFahrrad
      I extracted the official BIOS update package from Fujitsu (contains FJNB2FD.CAP, ~18.7 MB) and tried tools like UEFIExtract, but it seems to only contain...
      06-30-2025, 04:09 AM
    • vinaypundith
      Razer RZ09-01682 Blade Stealth 13 2016 BIOS dump needed
      by vinaypundith
      I have this laptop that does boot but it's on an older BIOS that has issues with Secure Boot, and I cannot use the normal Razer BIOS updater because for some reason the serial number is missing / got deleted somehow (Common issue on this model, from what I've read). I got a dump of the BIOS chip (or at least what I think is the BIOS chip), and its 16MB in size - the files from the Razer BIOS update are 8MB. (There's two 8MB files, am I supposed to combine these somehow? Or combine with an Intel ME firmware? I have no idea).
      So, I'm looking for a BIOS dump for this machine - a 16MB one....
      08-03-2024, 12:32 PM
    • James Maxwell
      HP DM1-4000er Bios Dump needed
      by James Maxwell
      I badly need bios dump for HP DM1-4000er,
      Model: HP DM1-4000er
      Motherboard: DA0NM9MB6D0 REV.D
      Product: QJ490EA#ACB
      Please help. My bios chip burned so I don't have the old bios anymore. I need bios dump before I can install the replacement.
      10-28-2024, 05:38 PM
    • mkdj
      by mkdj
      Dear all,
      10-19-2025, 04:41 AM
