Guest - Try our new boardview, Bios, & schematic search. Over 1.1 million files for download!
Macbook A1707 820-00928-A bios dump needed...
Please, anyone can help me with this file, only black screen macbook pro a1707 emc3162, serial c02tx3m6htd5Attached FilesPremium supporters get full download access and other benefits.
try..Attached FilesPremium supporters get full download access and other benefits.
Dear everyone Im looking for the bios above, this comes in EFI lock, please remove and send me the clear BIN, thank you.Attached FilesPremium supporters get full download access and other benefits.
You MUST:- Provide the full machine model number, serial number (or Service tag, SNID) and the board model number (see https://www.badcaps.net/forum/showthread.php?t=88758 ) ,The serial number, make, full model number, motherboard model and revision (except QR codes) must be written/typed at your request as per the rules. Not as a picture, part of the file name and so on.
tryAttached FilesPremium supporters get full download access and other benefits.
Hello somebody can help me with Clean ME ?
heelo friends
i have A1707 MDM LOCK CAN YOU PLZ HELP FOR REMOVE ?
A1707
EMC 3162
SN C02W37M3HTD6
NEED INSTRACTION TOO
YHANK YOULeave a comment:
try thisAttached FilesPremium supporters get full download access and other benefits.
Could someone help me clean ME region on this macbook pro?
A1707 EMC 3162 Touch bar
MB:820-00928-A
SN:C02VM1PWHTD7
laptop is in boot loop, same on external boot device and internet recovery. tnxLast edited by SMDFlea; 04-30-2024, 02:56 PM. Reason: Thread merged, do not post a request in multiple threads !Leave a comment:
MB:820-00928-A
SN:C02VM1PWHTD7
laptop is in boot loop, same on external boot device and internet recovery. tnxAttached FilesPremium supporters get full download access and other benefits.
try..seifaldenn Thank you! Unfortunately, that produces the same result as with my cleaning tries: Fans spin, but only 20v/250mA (without battery), and cpu stays cool. With the original bios, cpu and fans turn on, "normal" booting current, but no chime (no POST).
Any hints on what to try next?Attached FilesPremium supporters get full download access and other benefits.
Any hints on what to try next?Leave a comment:
try
Serial number C02TW15MHTDF (as was visible in the dump file); board number is 820-00928 (as for all A1707).
Thank you!Leave a comment:
Post the logic board number,and type and post the serial number please.Hi,
have this a1707 MacBook Pro, bought from Kleinanzeigen (like Craigs List). PCH had the glass blown away; replaced the PCH and the power switch before that, and have booting current (like 1-1.6 A as usual), but no chime and screen stays black.
Figured I need to clean ME, but failed to do that using MuertoGB's tool.
May some soul be so kind and clean the me region on the attached SPI-ROM image?
by CG_DionysosHello,
I am looking for the boardview file and the matching schematics (PDF) for the following MacBook Pro:- Model: A1707
- 15-inch, Mid 2017
- 3.1 GHz Core i7
- 16 GB RAM
- Radeon Pro 560
- 1 TB SSD
- Board number: 820-00928-A
Thanks in advance!
Greetings from Germany...-
Channel: Schematic Requests ONLY!
09-16-2025, 06:43 AM -
by leonemax81Hi guys I have a Macbook a1707 with motherboard 820-00281, without liquid damage that behaves strangely, with the battery connected the Macbook does not turn on and the USBC meter stops at 5v in loop, when I disconnect the battery the Macbook turns on and works fine, I have already tried to replace the battery twice without success, as soon as I connect the black cable of the battery the Macbook does not turn on, it stops at 5v and in loop.
by re-atariHello all, as the title says, I'm very much in need of a valid firmware dump of a Anycubic Photon 5.5 3D resin printer. It's stored in a Winbond 25Q32, so it's 4Mbyte.
Here's a little background for my request. A few weeks ago I bought this 3D printer from a guy who had moved on to a PLA printer. I got it at a vey reasonable price, as it was in a defective state. The seller told me that he had experienced a power failure during a firmware upgrade, after which the printer appeared to be dead. He thought the firmware was corrupted in such a way that the printer was now bricked. As he... -
by jesihi all techs
require some help on this 820-00281-A macbook motherboard came in dead and the pch bga U1100 (SR2NH), u5000 , Q7056 , U7000 and bios U6100 ,looks like these have been tampered with ..also the battery is swollen..
adapter usb c 20.5v 4.7a 96w , i persume it should power on mb without battery..
update:
when adapter plugged in , power switch which 3.3v on it , when power button pressed both fans come on after 6 secs for about 20secs approx then goes off , nothing on the display stays as blank.. the voltage at the usbc out start from...08-23-2025, 02:35 PM -
by soflesHello there
I have problem with Macbook Pro 15" 2017, model 2017, MB code 820-00928.
I bought it as broken with some artefacts on the screen, first I thought that this is problem with ribbon cable but after inspectiing ribbon cable I know it is fine. I tried to reinstall macOs and then I figured out that this must be something with GPU as installation freezes at the end (when drivers are loaded). I installed Windows and was able to install every each of drivers except GPU driver, as soon as I tried to install GPU driver - black screen and restart.
...11-21-2024, 05:25 AM - Loading...
