I need a dump for lenovo thinkpad t560 .the original is corrupted.
Thinkpad t560 bios dump
Tags: None
Re: Thinkpad t560 bios dump
Here it is.Attached FilesComment
Try this and reply.Attached FilesComment
No change.the story of the mobo:someone has tried to clear the bios password by shorting the legs of the winbond w25q128(spi1),and result, the mobo does not start anymore.Comment
bios locked i need to unlock it help
sn R90L491Y
MTM 20FJS19305Attached FilesComment
Lenovo T560 Me Region clean request
Hello everyone. Can you someone clean me region in my BIOS dump for Lenovo T560? I will be grateful. Thanks.Attached FilesComment
Re: Lenovo T560 Me Region clean request
I tried to clean it for you but:
ME Analyzer detected an error when opening it.
Error: Detected MFS File 538 > Chunk 17189 not in Total Chunk Index/Data Area!
And FIT won't open it at all.
Can you read bin again? and compare it with hex editor to see if they are the same, no use uploading same one.Comment
Its definitely a corrupt ME FW. The way to fix it is to find another T560 dump and manually edit in the ME region with a hex editor,then clean it , or copy the DMI info (if any) to a another T560 dump .Comment
Thank you for reply. I was thinking, that only I have this problem. I tried to load this BIOS dump to other versions of Image Flash Tool, but I always got error message. Unfortunately I have not another BIOS dump. The reason why I need make the Me Region clean is long time notebook startup. After press power button I need to wait for 10-15 seconds to show Lenovo logo and then I can go to BIOS. Maybe you have 100% working BIOS dump for this model? Thanks.Comment
Lenovo ThinkPad T560 448.06D04.0021 bios
I need a bios for the Lenovo T560.
I'm adding a backup from a broken laptop that won't boot.Attached FilesComment
Re: Lenovo ThinkPad T560 448.06D04.0021 bios
Attached FilesDue to a lack of donations, server free space at a critical level, and possible closure of Bios Requests all donations are welcome, click:
Every donation made will go towards server fees and maintenance costs.Comment
try..Attached FilesDue to a lack of donations, server free space at a critical level, and possible closure of Bios Requests all donations are welcome, click:
by trepachkaHello, I have this ThinkPad P1 Gen 4 that has what I perceive corrupted bios. Computer charges and upon pressing the power button, the keyboard lights up briefly, both fans begin to spin and the cpu gets warm. However, I get no post. I do get color palette cycling all sorts of colors on the screen when I press Fn-Cntrl-Power key combo at the same time (standard Lenovo screen test). So, this tells me the issue is with bios. All voltages are present including CPU, GPU and memory voltages.
The bios file is a little tricky. I believe it has 2 identical 256Mb chips next to each other (photo...-
Channel: BIOS Requests ONLY!
Today, 12:57 AM -
by AhariHi all,
I...-
by Loki_FidoHi everyone, hope everyone's having a great day.
I have a Lenovo Thinkpad X1 Yoga Gen 3 for repair. (20LES3T900)
I looked in every corner and the laptop seems fine. Its pulling 500mA but no display, no noise, nothing.
So I assume its a BIOS issue. I downloaded the BIOS with CH341A and opened it on ME Analyser and didn't receive any errors.
Does this mean the BIOS is fine? making it a hardware issue?
I downloaded fresh BIIOS from the Lenovo site and used Hex Editor replace the Lenovo's BIOS into my BIOS region. But the file size ended up being...-
by James194ztHi,
My daughter has accidentally managed to kill her Acer gaming desktop it has a blank screen after updating and when you press the power button the fans spin, light comes on and it makes 1 long and 1 short beep and no attempt to boot.
All basic troubleshooting has been done we replaced CPU, GPU and RAM from a working machine and no joy, I also noticed a post on here with the same issue and it was the BIOS. I am pretty sure also because it was doing a BIOS update that stopped it working, she knocked the keyboard out by accident during the update and the screen just went...-
by FalconPunchHello everyone, I happen to have a Microsoft Surface Pro X 1876 in my hands. It was brought to me by a friends which happen to have taken off the bios chip to test another motherboard. Upon putting back the bios chip on the original motherboard, The PC is stucked on Windows logo and won t boot to bios or anything. I suspect that the changes of bios chip somehow corrupted the firmware inside. Is the hypothesis correct?
Also i extracted the bios inside the chip which was on Winbond 25R128JWPQ you can find the file attached if you can fix it (if possible, I would like some insight on...-
- Loading...
