bios dump elitebook 840 g3
I have notebook, that has a problem "HP bios version mismatch". Bios tries to update himself, but it's in a loop. If anyone can correct Bios, to the right version. Ive tried to flash it from antoher 840 G3, and thought i can change then the serial, but, it doesent eaven shows hp logo - blank screen.
HP EliteBook 840 G3
L3C65AV
5CG82188D9
Boot Block Version: 01.44
System BIOS Version: 01.47
I think i need system BIOS version 01.44 ? If anyone can help me.
Thank you
HP EliteBook 840 G3
L3C65AV
5CG82188D9
Thank you
Mọi khoản quyên góp cho badcaps đều được hoan nghênh, hãy nhấp vào liên kết này để quyên góp. Cảm ơn tất cả những người ủng hộ----------------------------------------------------------------------------------------------------------------------------------------------------------------Comment
Good morning
I will need the bios file for an elitbook 840 G3 with motherboard number 6050A2892401-MB-A01 with the two files Main + EC
THANKSComment
Please read the rules.Serial number,backup etc..
corrupted bios you can fix plss
hp g3 840
SN-5CG70144VNAttached FilesComment
HP EliteBook 840 G3 Base Model Notebook PC
hello 840 G3 6050a2822301-mb-a01
pls fix bios just turn fan
sn 5CG834541ZAttached FilesComment
HELLO Guys , i Need your help please.
HP ELITEBOOK G3
MB : 6050A2892401-A01
sn/5CG7471RJL
REMAINS BLACK ? THAT'S AN BIOS ISSUE FOR SURE.
THX U FOR HELPComment
HP EliteBook 840 G3 Notebook PC
HELLO , i Need your help please.
HP ELITEBOOK 840G3
sn 5CG8234BST
RCUnlocker, HPUnlocker
it didn’t work, the board doesn’t start
use BCU to fill these DMI info:
Serial Number: 5CG8234BST
Product #/SKU: L3C67AV
CT Number: PFLAA00WBAX0QX
Description: HP EliteBook 840 G3
BuildID: 15WWCSET601#SABY#DABY
Feature Byte: 3X476J6S6b757B7H7M7Q7W7m7saBaEapaqauawbUbhcAdUdpdqfSgd.Tm
MAC Address : 10:62:E5:97:9B:BBAttached FilesComment
First boot press f10 reset bios to factory defaults and exit.
MAC Address : 10:62:E5:97:9B:BBComment
by Habble7The Samsung S49CG934SU monitor does not power on - no LED indicator activity and no response to power button. However, when 21V power is connected, it immediately draws 0.8A of current with no display output. The motherboard processor gets warm, and there is continuous reading activity from the W25Q128BV BIOS chip.
Suspected Cause:
Troubleshooting Attempts:
by DynaxSCHi, I have an MSI PRO B660M-G DDR4 board with damaged BIOS and i need a bios dump from a real board, along with MAC, UUID and Serial Number info (eg. a BIOS screenshot and pictures from the board stickers).
I need to reconstruct the bios on my board, based on another bios image form a real board - meaning a bios image containing MAC address, UUID and Serial number. A stock BIOS is not suffiecient, as it is impossible to discover where the MAC, UUID and SerialNumber are stored. Tried with a similar board, but there are too much differences, and the stock BIOS is missing a lot of...11-17-2023, 10:56 AM -
by GuestHello,
I have an EliteBook 850 G5. After a Windows update, including a BIOS update, the notebook turns on, but the screen remains black, and the fans spin at high speed—nothing else happens.
I assume the BIOS update failed, so I searched for the BIOS chip.
I found a Winbond chip located between the RAM and the hard drive, which has a size of 32 MB.
However, the BIOS update available on HP's website is only 17 MB in size. I used the update version that was previously installed when the notebook was still working.
Can the corrupted...-
Channel: BIOS Requests ONLY!
by grimacelordThis laptop is the same laptop I was working on in this thread and I wasn't sure if I should post a new topic or post in that thread because I already solved the issue that thread was discussing and this is a completely different issue although it is dealing with the same laptop. I decided to make a new thread since it's a new issue, but please move if I made a mistake.
Motherboard model number: DA0PAMB46A1 REV: A
Secondary motherboard model number: 0PAB
SKU: 685K4UA
Serial number is: 5CD3223BJP
Recently reflashed this laptop with latest BIOS and once...-
by DynaxSCHi,
I need a BIOS dump for MSI Z590 PRO WIFI from a real physical board, along with MAC address and serial no.
It must be a dump from a physical board, as it contains personalized data eg. MAC Address, UUID, Serial no.
I have a board which has lost the BIOS contents, I have the MAC and serial to this board, and need to insert it into the another BIOS image. To do it, I need to have a real image from a real board, as the images from the MSI site are without this data. The only way to find where MAC/UUID/Serial is located in the BIOS is to have a bios...-
11-06-2022, 05:22 PM -
- Loading...
