bios dump elitebook 840 g3
  • peste
    • Dec 2016
    • 13132
    • ROMANIA
    #381
    Re: bios dump elitebook 840 g3
    Originally posted by thandazile85@gmail.com
    hi guys i need bios bin for 840 g3
    post the original laptop bios
    • vpiru1
      • Oct 2020
      • 4
      • Portugal
      #382
      Re: HP ELITEBOOK 840 G3 (6050A2892401-MB-A01) remove Bios password
      looks like hpunlocker tool rar file is corrupted, at least i can't unrar it.
      is there any other place to download it besides (https://www.badcaps.net/forum/showpo...43&postcount=1 )
      • peste
        • Dec 2016
        • 13132
        • ROMANIA
        #383
        update winrar or use 7zip ..
        • vpiru1
          • Oct 2020
          • 4
          • Portugal
          #384
          thx, 7zip worked fine.
          • vpiru1
            • Oct 2020
            • 4
            • Portugal
            #385
            and btw, does the tool clear the power on password? that's my problem.
            • 5chematic
              • Jun 2019
              • 77
              HP EliteBook 850 G3 corrupted extracted image
              I was dumping an image when my programmer was flipped over just a tiny bit. as the result of that micro accident, I got a corrupted image. I extracted the image 2 times and then compared both copies and they are different.
              I've tried to make one image from both, but did not worked. then I grabbed another image from another hp which is the same model and then tried to edit the serial but cannot get a working image.
              Could anyone help me?
              Thanks in advance
              • Bonzas
                • 472
                • Indonesia
                #387
                Re: HP EliteBook 850 G3 corrupted extracted image
                try this
                • 5chematic
                  • Jun 2019
                  • 77
                  Thank you so much Martha, let me try and let you know. thank you again.
                  • 5chematic
                    • Jun 2019
                    • 77
                    Martha, I get a loop of three long beeps and two short beeps The same as before, Please help.
                    • Claudiomfa
                      • Nov 2015
                      • 455
                      • Portugal
                      #390
                      3 long beeps and 2 short beeps means:
                      Indicates potential memory failure.
                      Reseat memory.
                      Correct memory configuration (correct DIMM placement and size/type matching).
                      Test with known good memory.
                      Replace affected component.
                      • zerocool87
                        • Oct 2020
                        • deutschland
                        #391
                        Re:elitebook 840 g3 lock
                        hello please help me to unlock my bios attached my bios dump
                        • 5chematic
                          • Jun 2019
                          • 77
                          Reseat memory.
                          Hello Claudio,
                          Thank you for your comment.
                          Let me explain what happened...
                          I was dumping the image of the bios chip from the laptop.
                          Then out of nowhere my programmer flipped over just a bit, and very slowly while I was extracting the image from the chip. I never thought the bios image could get corrupted just by that tiny flip, but it happened.
                          Then after I encounter the issue I removed the chip again and made another copy, I mean, I extracted the chip again. and I noticed that the image was not the same. I compared them and both copies were not the same. there is a tiny difference in both images.
                          I was removing the bios password from the image as usual. now all I want is to get a working copy of the bios.
                            • 21395
                            Re: elitebook 840 g3 lock
                            Use the HP unlocker tool - https://www.badcaps.net/forum/showthread.php?t=79956
                              • 21395
                              The bios at post #2 has initialised ME firmware,which means that it would need cleaning , or just search the forum for an 850 G3 bios with clean ME firmware.
                                • 21395
                                Thanks in advance
                                ok ,try this bios .
                                • 5chematic
                                  • Jun 2019
                                  • 77
                                  Hello SMDFlea, Thank you so much for this achievement. the image worked fine. after I turned the hp on, the bios was updated automatically. does this means that I should not worry about any serial number, and so on? Thank you again SMFlea.
                                  I also wanted to add that Claudio was right. after I installed the new bios image, the beep was still there. then remembered what Claudio mentioned on post #5. so what I did is move one stick of ram to the other slot and that took care the beeping sound. Thank You Claudio.
                                  • newjan
                                    • Mar 2016
                                    • 67
                                    • Egypt
                                    #397
                                    i need dumo work with 840 g3 coz i lost my backup
                                    • peste
                                      • Dec 2016
                                      • 13132
                                      • ROMANIA
                                      #398
                                      what motherboard model ?? give you more details about laptop ...
                                      • newjan
                                        • Mar 2016
                                        • 67
                                        • Egypt
                                        #399
                                        6050a2822301-mb-a01
                                        • peste
                                          • Dec 2016
                                          • 13132
                                          • ROMANIA
                                          #400
                                          6050a2822301-mb-a01
                                          try..
                                          • Ahari
                                            by Ahari
                                            I...
                                            08-13-2025, 06:12 AM
                                          • Habble7
                                            by Habble7
                                            Suspected Cause:
                                            Troubleshooting Attempts:
                                            05-22-2025, 07:28 AM
                                          • haitham sharabati
                                            [Request] Clean BIOS dump for HP 15-da2007ne (8XF55EA#ABV) - N4000 - BIOS Lock
                                            by haitham sharabati
                                            Hello engineers 😀,
                                            I’m kindly requesting a clean and unlocked BIOS dump for the following HP laptop, as it’s bricked after flashing SP152727. The system now keeps rebooting, and the original issue was an Administrator / Power-On Password that I can no longer access.😏
                                            🔧 Device Info:
                                            - Model: HP 15-da2007ne
                                            - Product Number: 8XF55EA#ABV
                                            - Serial Number: CND0338P0D
                                            - CPU: Intel Celeron N4000
                                            - EC/BIOS Chip: [Add chip number from the motherboard or BIOS chip]
                                            💀 Problem:😅
                                            - Device shows “Administrator Password”...
                                            08-07-2025, 04:54 AM
                                          • Citymin
                                            by Citymin
                                            S/N : 5RNK9FFT70...
                                            08-05-2025, 05:12 AM
                                          • DynaxSC
                                            by DynaxSC
                                            11-17-2023, 10:56 AM
