bios dump elitebook 840 g3
  • xzm
    • Feb 2011
    • 28
    #61
    Re: I need a bios and ec dump for 840 G3
    Please for unlock bios password for 840 G3. I uploaded here locked dump in attach '840 G3 locked.rar'. Thank you in advance.
    • ssspunkyyy
      • Jun 2018
      • 3
      • Norway
      #62
      Re: HP Elite book 840 G3 need bios urgently
      Originally posted by imranromi
      Post complete file need 16mb.Use bios programmer and save.
      Ah, so you need the bios dump. Well, unfortunately for me, I don't have a programmer..
      Any other options?
      • Th3_uN1Qu3
        Believe in
        • Jul 2010
        • 6031
        • Romania
        #63
        Re: bios dump elitebook 840 g3
        Try this and reply i try new methods.
        Thank you very much. I just unlocked a 840 G3 myself with this file, it worked perfectly.
        I did clean the ME before flashing. I always do that unless the file has Clean ME in its name, it never hurts doing it twice.
        A working TV? How boring!
        • Marco_compucell
          • Feb 2012
          • 63
          • South Africa
          #64
          Hello can someone pleas help me to remove Bios password
          Thank You
            • 20318
            Try this one .
            • Marco_compucell
              • Feb 2012
              • 63
              • South Africa
              #66
              Thank you SMDFlea will try it on Monday
              • Marco_compucell
                • Feb 2012
                • 63
                • South Africa
                #67
                Thank You SMDflea it works
                • servis_null
                  • Oct 2014
                  • 82
                  • Croatia
                  #68
                  Hi to all,
                  I need pass remove from bios dump.
                  elitebook 840 g3 mb: 6050A2822301-MB-A01
                  thnx
                    • 20318
                    Originally posted by servis_null
                    Hi to all,
                    thnx
                    Try this one.
                    • Ahnenerbe
                      • Apr 2018
                      • Ukraine
                      #70
                      SMDFlea can You also help me with this disaster as much as possible.
                      - Thnx!
                      m.b.: 6050A2892401-A01
                      • servis_null
                        • Oct 2014
                        • 82
                        • Croatia
                        #71
                        Originally posted by SMDFlea
                        Try this one.
                        Thnx SMDFlea, works great. Thnx again
                          • 20318
                          - Thnx!
                          Try this one
                          • salawayon
                            • Nov 2012
                            • 568
                            • philippines
                            #73
                            Re: HP 840 G3 bios needed
                            got another unit with same issue... motherboard model is the same with the first one...
                            i attached my backup... thanks...
                            • dimkka
                              • May 2013
                              • 16
                              • moldova
                              #74
                              • dimkka
                                • May 2013
                                • 16
                                • moldova
                                #75
                                Thank You
                                • sourcebf
                                  • Jul 2016
                                  • 431
                                  • N/A
                                  #76
                                  thank you
                                  here you go
                                  • salawayon
                                    • Nov 2012
                                    • 568
                                    • philippines
                                    #77
                                    anyone could remove the bios password?
                                    thanks...
                                    • dimkka
                                      • May 2013
                                      • 16
                                      • moldova
                                      #78
                                      Originally posted by sourcebf
                                      here you go
                                      i use the file upstair, all not working. (no display)
                                        • 20318
                                        Try this one .
                                        • sourcebf
                                          • Jul 2016
                                          • 431
                                          • N/A
                                          #80
                                          I used your original file, and remove the password from it
                                          after programming the new dump wait laptop takes few seconds to post
                                          • Habble7
                                            by Habble7
                                            Suspected Cause:
                                            Troubleshooting Attempts:
                                            05-22-2025, 07:28 AM
                                          • DynaxSC
                                            by DynaxSC
                                            11-17-2023, 10:56 AM
                                          • Guest
                                            Elitebook 850 G5 BIOS bricked
                                            by Guest
                                            I have an EliteBook 850 G5. After a Windows update, including a BIOS update, the notebook turns on, but the screen remains black, and the fans spin at high speed—nothing else happens.
                                            I assume the BIOS update failed, so I searched for the BIOS chip.
                                            I found a Winbond chip located between the RAM and the hard drive, which has a size of 32 MB.
                                            However, the BIOS update available on HP's website is only 17 MB in size. I used the update version that was previously installed when the notebook was still working.
                                            Can the corrupted...
                                            03-24-2025, 01:21 AM
                                          • grimacelord
                                            Trying To Find UUID In BIOS Dump - HP 14-dq0055dx
                                            by grimacelord
                                            This laptop is the same laptop I was working on in this thread and I wasn't sure if I should post a new topic or post in that thread because I already solved the issue that thread was discussing and this is a completely different issue although it is dealing with the same laptop. I decided to make a new thread since it's a new issue, but please move if I made a mistake.
                                            Motherboard model number: DA0PAMB46A1 REV: A
                                            Secondary motherboard model number: 0PAB
                                            SKU: 685K4UA
                                            Serial number is: 5CD3223BJP
                                            Recently reflashed this laptop with latest BIOS and once...
                                            05-07-2024, 08:06 AM
                                          • DynaxSC
                                            Who has a MSI Z590 PRO WIFI - Need BIOS dump ?
                                            by DynaxSC
                                            I need a BIOS dump for MSI Z590 PRO WIFI from a real physical board, along with MAC address and serial no.
                                            It must be a dump from a physical board, as it contains personalized data eg. MAC Address, UUID, Serial no.
                                            I have a board which has lost the BIOS contents, I have the MAC and serial to this board, and need to insert it into the another BIOS image. To do it, I need to have a real image from a real board, as the images from the MSI site are without this data. The only way to find where MAC/UUID/Serial is located in the BIOS is to have a bios...
                                            11-06-2022, 05:22 PM
